Cleaning off with no water....
Discussion in 'The Hokey Ass Message Board' started by Kustom Chief, Jan 15, 2011.
  1. Kustom Chief
    Kustom Chief
    So I got my new ranchero delivered on Thursday night. From the trip it is covered in road grime and salt. I don't have access to a hose, as everything is shut off for the winter. Anyone have any recommendations on getting this **** off the car?
    Is there something that I can spray and wipe it off?
    Thanks
  2. CutawayAl
    CutawayAl
    from MI
    There are spray bottle cleaners, but I think that's asking for trouble on a car that's really dirty. If you don't have buckets and access to water I would just leave it dirty until you do have water.
  3. slickhale
    slickhale
    from Phoenix
    warm soapy water in one of those pump garden sprayers
  4. 19Fordy
    19Fordy
    If you have an air compressor and a portable sandblaster siphon unit, fill it with water instead of sand and spray off dirt, etc. Better yet, use the sand blaster and siphon water out of a 5 gallon plastic pail. You could use a pressure washer but that requires a water hose.
  5. poncho62
    poncho62
    Go to the car wash.....you need to be worried more about whats under the car than on it.......
  6. schwerko
    schwerko
    from bristol ct
    Wipe it down with some snow....
  7. BIGJERR
    BIGJERR
    from IOWA
    Go to one of those "They do it all" car washes.......For $20 it gets washed,vac out and towel & blown dry............jerr
  8. Kustom Chief
    Kustom Chief
    The car was on a trailer so it wasn't driven. It just has a film on it. I guess a nice snow wash and a rag dry will do most of it. I will make a go for it.
    Larry
  9. Dan Timberlake
    Dan Timberlake
    There's grit in the film, and I think rubbing with snow will still potentially scratch the finish. Gently Flowing soapy water is the first step on paint, and my reading gl***es. Rubbing with anything comes later.
  10. highboy_04
    highboy_04
    from Kansas
    you are worried about the car being dirty.......so taking a rag and scratching the **** out of the paint when you smear around the road grime is better......
  11. Big Bad Dad
    Big Bad Dad
    :confused:How much trouble is it to turn the water hose back on for a quick wash job?
    Should be easier than all, of this other stuff. If you cant turn the outside water on, hook it up to your washing machine connection, you can even get hot water that way! :D
  12. dudley32
    dudley32
    Drive with Grime...I think that will eventually become patina...d32
    :D :D
  13. Kustom Chief
    Kustom Chief
    It isn't my house....I rent the garage. I took care of it.
