327 timing hei regapped plugs
Discussion in 'The Hokey Ass Message Board' started by larry woods, Jan 15, 2011.
  1. larry woods
    larry woods
    from venice fl
    so i read the thread a few weeks ago re regapping plugs w/ hei. when i got home i regapped the plugs in my 327 to .045 and now have developed skip underload. i am having an old fart moment. what do i need to do with timing and regapped plugs. at first hought it was ****py gas from sitting too long but at this point? thanx larry
  2. gladeparkflyer
    gladeparkflyer
    my 1st thought would be if thats all you changed, go back to your initial gap and see if the problem goes away...
  3. burnout2614
    burnout2614
    How long has it been sitting with that gas? If you are already running lean, opening up the gap MAY make it skip but unlikely. If the gas is over 3 months old swap it. How much timing are you running? peace
  4. troylee
    troylee
    I always use the .045 for electronic and .035 for point rule. May be the carb or something in the distributor?
  5. Toymaker
    Toymaker
    from Fresno,CA
    If you regapped old plugs your "Spark" could now be traveling up the insulator around the electrode due to carbon, oil build up etc. and causing a stumble under load. By increasing the gap you have now increase the resistance for your spark to make the jump across the gap under a load. If plugs are new check other areas like wires, cap, rotor etc.
  6. 55 gasser pickup
    55 gasser pickup
    from utah
    check the easy stuff first.Once i didn't put a wire on a plug all the way and it didn't miss all the time but it would skip every so often when idoling.Stupid but hey it happends
  7. mt shasta steve
    mt shasta steve
    Both my cars have HEI, and when I checked, both had .035 gap. Cleaned plugs and reset gap to .045 and noticed an immediate smoother idle. And better pull under acceleration. A "skip" won't be caused by plug gap. As has been mentioned, I would look for a bad wire, bad plug, or bad connection.
  8. Badhabit
    Badhabit
    Toymaker has it right, I think the resistance has increased causing spark leak. Even though you notice it under load, try running the car with the hood open in a very dark garage. Look for spark jumping. If you have an automatic, have someone brake torque it in gear to create a load. I've run HEI plug gaps at .060, some have run at .080 with a CD box. You are running your HEI at 12 volts, right?
  9. Used HEI stock GM? .045 is too much, go back to about .040 and drive it again.
    You time it the same way you would if you had points.
  10. GMC BUBBA
    GMC BUBBA
    Some wild answers here for sure.
    Plug gap goes with combustion chamber and engine design NOT the ignition system. A 327 needs .035 not the .045, the 045 just askes for increased energy thats not needed with the combustion design.
    Longer burn times were mandated by lean air fuel ratios, most hot rods are not lean for sure...
  11. gearheadbill
    gearheadbill
    Listen to Bubba....Bubba knows!!
  12. carcrazyjohn
    carcrazyjohn
    from trevose pa
    18436572 and also redo the timing . I would set it at 45 ,
