Who's running a mustang Radiator and SBC???
Discussion in 'The Hokey Ass Message Board' started by chaddilac, Jan 17, 2011.
  1. chaddilac
    chaddilac
    Anyone out there running a sbc 350 with a 2 core mustang radiator.... I've mocked up my frontend with the 2 core radiator that was used, and now I'm trying to get this thing done for Lonestar and was thinking if the 2 core will work fine, then I'll use it. Sure could use that extra cash towards vinyl instead of a 3 row radiator....
    Let me know before I go getting the inlet moved!! :D
    Thanks Fellas!!!!
  2. ive heard lots of folks running them. i decided to spend the money on building the stock a one into a custom radiator cause i didnt liek teh look of a mustang radiator. it looks like its ment for somthing other than a hot rod when they are in a hot rod.
  3. 2 core wouldn't do a very good job keeping a 289 cool let alone a Fire Breathing 350 Chevy >>>>.
  4. chaddilac
    chaddilac
    Yea I agree, but I just had to stay with a budget. I would much rather had used my stock A radiator and got it recored to my size, but man $350 went a long ways for other parts!!
  5. chaddilac
    chaddilac
    I'm running a large elec fan with a fan shroud too 5X.... :)
  6. AstroZombie
    AstroZombie
    Chad, I used a Mustang radiator and a 307 in a T bucket that I built awhile back. I never had any overheating issues. Also had a flex fan and no shroud.... You should be ok, but might want to save up for the 3 core after you do the round up. You're on a roll man!!!
  7. chaddilac
    chaddilac
    Thanks AZ!! Yea I figured, what the heck I got it. I'll try it and if it crumbles under pressure it's easy enough to grab one from the parts house have the inlet moved and slap it back in!! :D
  8. GrungyGary
    GrungyGary
    I used one....with a '57 chevy fan that i had to cut 1" off all four blades to clear the top radiator hose. It ran very cool.... cruised around all day in 105 degree temp and it wouldnt get hot unless i held it at 4000 rmps for too long.... but it cooled right down when i got back to cruising rmps
  9. chop32
    chop32
    Ive got an Mustang A/C (3 row core) radiator infront of the 350 in my '32 Ford Pickup. With a 12" mechanical fan (all that will fit) it runs cool on the highway, but the temp starts to come up as soon as you get into any traffic. The 12" electric fan helps to keep the temp down to 205-210 on a warm day...on a hot day all bets are off!
  10. chaddilac
    chaddilac
    Chop32, that's why I'm gonna run a 16" fan with a shroud! :)
    GrungyGary, was that a two row radiator you're talking about?
  11. captmullette
    captmullette
    ran one in my 27 roadster, 355 , big cam no shroud, never had any problems, now i 've got one iin my 31 that im building...... we will see....
  12. rosswo
    rosswo
    from minnesota
    have a 2 core in my 33 chev. very small mech fan (13")probably, no shroud and sits real low on radiator.always overheated in traffic,put a small 10 in electric fan at top of rad as a pusher fan and helped a lot.should work for a while for ya
  13. raidmagic
    raidmagic
    My dad has one on his 283 T-bucket, it runs so cool most the time you don't even have to turn on the fan.
  14. youngster
    youngster
    from Minnesota
    Just curious, which Mustang radiator are you using? I use the one for a '66 from Autozone ($135) and didn't have to move the inlet moved. BTW, I have yet to have any problems with it even in parades.
    Ron
  15. captmullette
    captmullette
    same one im using in both of mine.....
  16. A cooper radiator has an "R" value about a third of an aluminum radiator. When someone says they have an aluminum radiator and brag about it I usually try to keep my mouth shut. I think advertising sells.
  17. alwayzarat
    alwayzarat
    Chad,
    The T I have uses a 65' mustang radiator and a Hayden electric fan. I had to use a catch can too, becasue over time enough coolant would spit out that it would get low. I think that is inherant to the fact that the motor sits higher than the radiator. It also has a model A grill. I think it looks great. I can take all the pictures you want of it if you need them.
  18. hrm2k
    hrm2k
    Chad, My T has a Mustang radiator with an electric fan that pushes from the front. My car doesn't over heat. It does get around 200 when you are on the highway at speed. As soon as you are back on side roads with stop and go, the temp goes back down to around 175.
  19. alwayzarat
    alwayzarat
    The fan mine uses mounts behind the radiator. Temp doesn't go above 180* most of the time. If it's really hot, it may push 190*
  20. Jimv
    Jimv
    i ran a mustang rad(2 core with a remote ****** cooler) in mt T bucket with a 400sbc, a 195o thermo & it always ran at that temp.Only problem was it hung down a little low & i took the bottom of it off going over a speed bump!!lol.Didn't cool to good after that!
    JimV
  21. chaddilac
    chaddilac
    Thanks Jimv I saw you had posted that on another thread and it gave me hope!! :)
    Alwayzarat, is your's a 2 row?
    How bout you HRM2K?
  22. hrm2k
    hrm2k
    I thought I might have hi-jacked your thread so I took mine off the post. I just changed the fill system to a modified Moroso unit. I'm hoping this will stop my having to monitor the coolant level before every drive. Here is the new stuff.
    For what it is worth, that Mustang unit should handle most streetable small blocks.....or so I have been told.
    BTW, I have filled the oil fill hole you can see with a 1.250 freeze plug. Now I have to fill the oil through the breather on the drivers side
  23. chaddilac
    chaddilac
    thanks HRM2K... that's a 2 row right?
  24. Nice fab work Chad !! You have nothing to lose and if you need the 3 core it'll fit right in. I've just had bad exp with these in the past >>>>.
  25. SinisterCustom
    SinisterCustom
    The 3 row Mustang radiator in "Trouble Maker" was $100 off Ebay new.....
  26. edweird
    edweird
    i dont remember the size, but i had one in my 37 chevy with a stock 305. it ran real cool all the time.
  27. chaddilac
    chaddilac
    thanks Engine Pro.... I'm just gonna run it like it is!! :D
  28. hrm2k
    hrm2k
    yes
  29. Chad
    I got a Mustang V-8 radiator for a '65. I don't remember how many rows it is but its not real thick. It cools the 307 in my jeep just fine.
  30. Hey !!! Of all of these Mustang Radiators out there any of them got Date Codes in the top tank ?? I'm looking for the 65 2 cores that fit 4-speed cars !!! Cash buyer !! >>>>.
