Help: Radiator grill ride height?
Discussion in 'The Hokey Ass Message Board' started by Dave L, Jan 16, 2011.
what ride height looks best?
Poll closed Jan 19, 2011.
  1. #1
    3 vote(s)
    5.8%
  2. #2
    7 vote(s)
    13.5%
  3. #3
    5 vote(s)
    9.6%
  4. #4
    37 vote(s)
    71.2%
  1. Dave L
    Dave L
    from Idaho
    Trying to figure out the Radiator grill ride height so i can get the proper size radiator.
  2. tb33anda3rd
    tb33anda3rd
    i think i like picture 4 but the fence in the background and angled view are distracting.
  3. thunderbirdesq
    thunderbirdesq
  4. propwash
    propwash
    from Las Vegas
    should be even/level with the front edge of the cowl, perhaps just a shade lower, NEVER higher. That appears to be #2 and #3 inversely to the previous comments
  5. F&J
    F&J
    number 4, but like was said about that dang fence :)
    I am sure you will get it right, because the front and rear ride height is awesome on your car. Looks GREAT.
  6. pitman
    pitman
    Photoshop a top half of hood onto the pic. The side bead's angle, if bent at the cowl, will tell you straightaway, Go 4!
  7. steel rebel
    steel rebel
    Much better too low than level or too high. Look at the two most famous cars around. Gragowski's Kookie car and the American Graffiti yellow coupe. Both a little or a lot too low but both famous for their look. Sometimes you have to go a little radical in the right direction.
    Just my opinion but I don't mind voicing it. #1
    No guts No glory!
  8. Warpspeed
    Warpspeed
    I voted #4 don't like droopy fronts, it just looks wrong.
    If you want more forward rake, do it properly.
    Just my two cents.........
  9. striper
    striper
    4 is the first one that is even heading in the right direction. I'd like to see 5 and 6 for comparison.
    Use a string line or masking tape from the cowl to the shell to create the line instead of a stick 2" above that line. It's still a bit like guessing at the moment.
    Pete
  10. chaddilac
    chaddilac
    Should be level with the top of the cowl... Act like you're gonna run a hood... :)
  11. thunderbirdesq
    thunderbirdesq
    I agree with you on early T roadsters, later cars though? I always thought the AG coupe just looked weird.
  12. Ole don
    Ole don
    Do what Stiper said. Get rid of the bar, and used three or five lines of masking tape right on the surfaces. Then walk across the street and look back from a distance.
  13. bcharlton
    bcharlton
    from Buffalo NY
    #4 Not too slooped.
    BC
  14. Winged Avenger II
    Winged Avenger II
    from Wisconsin
  15. bp1971
    bp1971
    from Fresno, CA
  16. Troyz
    Troyz
    IMHO the line from the cowl to the grill looks best in pic #2. With a hood on you'd see pic #4 would look a little pig nosed & pic #1 looks a little short, think american graffiti coupe. I always use blue painters tape frome the cowl to the grill (fake paper hood)to make sure I like the line. Good luck!
  17. 067chevy
    067chevy
    Number four or just a little higher yet.
  18. F&J
    F&J
    One thing throwing off the look is that you must have the unshortened grille shell out in front of the front crossmember?
    Once you shorten the shell and get it further back in line with the front wheel, the look will change again.
  19. banginona40
    banginona40
    With a digital level mounted on the window opening I'd match that angle from the top of cowl to the grille shell. Especially if you plan to use a hood.
  20. Dave L
    Dave L
    from Idaho
    Thanks for the input all!, here is number 4 with a little tape, could not roll it outside today. I do not plan on running a hood.
