34 pickup steering help
Discussion in 'The Hokey Ass Message Board' started by dirt slinger, Jan 18, 2011.
  1. dirt slinger
    dirt slinger
    Ive tried a search and really didnt seem to answer any of my questions. Im building a full fendered 34 Ford pickup and I am not sure as to what steering box to go with. I am going to use a frame that a fellow hamber is building at the moment. It will definitely have a drop axle and a flathead. What steering box do I need to be looking for? Ive seen examples of the vega, F1, corvair,or even a 34 box, What do you gents recommend? Pictures, measurments, and do's and don'ts would be greatly appreciated.
  2. 392_hemi
    392_hemi
    Vega's probably the most popular street rod setup. Plenty around although some of the new repo stuff is junk. Easy to install and gives you a lot of room to work with. F1 is probably the best for traditional setup. Very durable and works fine. But space may be a bit tight depending on engine choice and installation is a bit more complicated.
  3. tommy
    tommy
    My 34 has an F-1 box. Vegas with all their U joints look too streetroddy for my tastes now. I was building a 32 with a Vega but I never was satisfied with the look.
  4. What engine/trans header or exh. manifold combo will be used? That has a lot to do with steering box choice. when you set it up try to do the steering and motor mounts at the same time. My '32 truck has a Buick nailhead with stock exh. manifolds so the vega box worked best (still tight)...
  5. dirt slinger
    dirt slinger
    Hey tommy, With using the F-1 box, is this a case where you had to reverse the box? Were you or did you use the F-1 column? Do you have any pics? Pardon the ignorance. Im still trying to figure out the "interchangeable" hot rod parts and the tweeks you do to make them work.
