anyone know of a source for single wheel trailer parts? i've been trying to find an old single wheel on the east coast for a while with no luck. now i'm thinking if i just find the basic wheel ***embley then i'll build up the frame/box like i want it. i've went and looked at a coupla small utility trailers recently but they just aren't fitting to what i'm looking for. there is a ad in one of the local cl***ifieds for a small utility that the box is an old model a truck bed. interesting but the guy hasn't returned my calls. funny how people put **** up for sale but don't answer the phone or return calls. anyhow just looking into other options as all the ones i find for sale are on the west coast and it's cost as much to ship it here as they sale for. whatever i do it's gonna be small and light as it's to pull behind one of those cars we dare not speak of here...ken....
I am ***uming you mean single axle? The Tractor Supply Store is a great source for trailer stuff. Axles, wheels, springs, etc. Even torsion suspension axles so you can build one with a low deck. All at a cost equal to Northern Tool. If you go to their website you can search for the nearest store. Northern is also just a phone call away. MIKE.
not sure if it's what luckystiff is talking about, but they used to make trailers that clamped onto your bumper like a tow bar, only pivoted up and down, and had a single wheel mounted under the center of the cargo box that pivoted as you turned. i think the only real advantage was that you do not need to know how to back a trailer with one of those.
yep ray nailed it. i can post pics of some or you can see tons at www.singlewheel.com they are great for pulling behind VW's. there i said it you happy hahahhaha. their angle is much better for a really low bug which mine is now a good bit lower since i put the BRMs on and dropped it some more. and it's still not as low as it will be since i'm actyually making lowered springplates for it. anyhow can't talk to much about that here or it'll get canned. i really am curious to find out what the homemade trailer thats in the local cl***ifieds thats made from a model a truck bed looks like. if nothing else i may could modify it a bit to sit lower with a solid mount dropped axle or something. it's cheap so if it's cool looking but needs tweaking to fit my likes it'd still be worth it...ken....
Check around for some one selling an old popup style camper. I bought one for a couple hundred bucks about 10 years ago. the guy I bought it from had stripped off all the camper stuff. I had some diamond plate welded on, extended the hitch about two feet. I used it for hauling a 80's Honda civic to auto crosses and Ice racing. The axle was rated for 2000 lbs, it had electric brakes. The only problem is that the wheels are inboard of the fram rails, but I fashioned some "fenders" out of rubber conveyor material from a rock quarry, and drive over the tires/fenders when loading the car. The load height of these camper frames is pratty low so they actually work well for 4 wheeles dirt bikes, snomobiles, and of course small cars.
I know posie had a couple of these goofy things..maybe he still does? call posies in hummelstown.. ask for dutch sawzall
I have a couple of them. One is an AllState and the other one is a "I DUNNO". Both of mine are un-restored but use an 8" wheel. A Cushman Wide Whitewall looks pretty cool if you buff off the Cushman. The frame are generally made of light gauge 2"x2" angle iron and were either riveted or bolted together. If I were going to "re-invent the wheel", I would use a car dolly hub and mount a plate onto it and then let that be the side-plate. If you have ever had a flat on one of those bolt mounted wheels (--and you will), then you will appreciate the ability to remove four lugnuts and swap out a tire on the side of the road. If you use another spindle or dolly hub as your axis plate, then just make a pivot joint and maybe some old hood springs. If you really want to go the nostalgia route, then you could take two trailer springs and cut them to mimic a semi-eliptic pair, and then make you a mount for them on your axis plate hub and then fab a spindle for the wheel hub. Most of those original trailers also had a maximum of 45 mph. Payload was only 400-500 pounds too so as you probably already know, the original ones were not much IMO. Does this help you out some??
Wow, That brought back a memory of my Dad's Henry-J and the caster wheels bearngs locking up on the weird little trailer. I remember that I hadn't heard a curse word from him until that day. I also remember he decided he might as well drag it home, sending a shower of sparks up behind us as the 'J whined down the highway. Powerband
Hi, I have a 1936 single wheel teardrop trailer, and a teardrop trailer website. I was just today perusing single wheel trailers looking for parts. In the process I added a number of links to my links database. Go to www.tinytears.cc/links.html, click on the database link, and then search under Manufacturers. There are a number of great suppliers such as: http://www.doublehitch.com/ The Double Hitch Suspension rotates 360 degrees! Whether you're an OEM or a do-it-yourself builder, the Double Hitch Suspension enables you to build a Double Hitch Trailer which does not pivot or jack-knife and tracks with the towing vehicle, even while backing. Build a golf cart trailer for an RV. Build a motorcycle or ATV trailer which can be towed behind a fifth wheel trailer. Build a single wheel trailer. Good luck on your search!!!
I found one of these on the property we bought. Ive only found one of the brackets but haven't given up on finding it. I would like to get some idea of its value and if anyone is interested in it. http://www.google.com/patents?id=L2RWAAAAEBAJ&printsec=drawing&zoom=4#v=onepage&q&f=false
That is what I was thinking he was looking for and you could tell every car that ever towed one by the bent up edges on the bumper and the skinned up spots on the bumper on each side. I haven't see one in thirty year that I can remember. But: lookie here http://motorcycletrailer.com/sw/ also search for swivel wheel trailer rather than single wheel trailer. Found this too http://www.singlewheel.com/Auto/HeiliteFR.htma or http://www.cruiserlift.com/swivelwheel.html
I know I am not helping but thought I would share anyhow. Ever seen a double wheeler, 1930's Roto Rooter used trailer. 60MPH all the way to Billetproof
