Features The Official 60-66 C-10 Chevy Truck Picture Thread
Discussion in 'The Hokey Ass Message Board' started by TexasHardcore, May 8, 2006.
  1. krazy kory
    krazy kory
    Thanks. It's metal I split it at the body lines and rased the center section then plated the sides
  2. PRIMERDAVE
    PRIMERDAVE
    [​IMG][​IMG]
    When she was on Suprems ~
  3. PRIMERDAVE
    PRIMERDAVE
    How's that ~
  4. novatattoo
    novatattoo
    from Canton,OH
  5. FKNPOZER
    FKNPOZER
    from CALIFORNIA
    you da man!!
  6. creepyjackalope
    creepyjackalope
    Saw this truck on Los Boulevardos and it has been my screen saver for months....It is absolutely perfect!
  7. kustomkid18
    kustomkid18
    My 65 GMC, california rust free truck turned year round daily driver in New England....
  8. PRIMERDAVE
    PRIMERDAVE
    Thanks brother!
  9. jason65
    jason65
    Awsome trucks guys.
  10. Woogeroo
    Woogeroo
    from USA
    really? nice work... that hood is awesome.
    -W
  11. 64cheb
    64cheb
    Damn, that looks really slick. It looks like a factory cowl induction hood, spot on!
  12. TubularGoose
    TubularGoose
    Pease don't crucifie me but does any body know where some good 60-63 doors are? I know this should probably be in the parts wanted section, but I figured that this would be a little more direct.
    Thanks!
  13. C/Gas55
    C/Gas55
    Hey PrimerDave, what all is done to your truck lowering- wise?
  14. Bad Luck Engineering
    Here's a shot of my wife's '66. We had to sell it to close on our house. She still tears up when she thinks about it. Hopefully we'll be able to build her another one in the next few years.
  15. EL SOLDADO
    EL SOLDADO
    Brought my rig home... Now to put it back together.
  16. PRIMERDAVE
    PRIMERDAVE
    its a 6-4 dropped spring kit from Brothers and the lowerd drop shocks and an extra one and a half two inch block in the back(can't remember)...oh yeah shaved the bump stops off the lower A arms....if not they hit "all" the time....
  17. EL SOLDADO
    EL SOLDADO
    Super clean ride Dave...
  18. scrubby2009
    scrubby2009
    Daily driven, no show all go and homebuilt... smilin' every day
  19. newrider3
    newrider3
    Doing some more work on 64cheb's 283. Got it torn down to shortblock today, to prep for cleaning. Found an extremely stretched timing set, 3 dead plugs (may explain the poor mileage and low power? hmmm), some stuck lifters, and a completely rounded cam lobe. The pistons looked oversized, and in great shape. The bores are excellent, as are the cam bearings. No sludge whatsoever inside the motor, it was all stuck to the outside. ;)
    The timing set of SHAME:
    He is going to pick up a gear-drive timing set, aluminum timing cover, and possibly headers later this week. Also going to try to find an RV cam and lifters (Isky?). Has a 4bbl manifold already waiting. It should be pretty nice, and have a ton more power.
  20. jchav62
    jchav62
    X10!!! That thing is SICK!!! :cool:
  21. 65PANELRAT
    65PANELRAT
    Wow! Beautiful Truck!!! The Lady in the pic is beautiful too!!!
  22. weaponstroop
    weaponstroop
    from Missouri
    i think i own this truck now.
    the one i bought in Kansas came fron NC...
    if so here is what i have added to it
    and with my sidekick
  23. weaponstroop
    weaponstroop
    from Missouri
    maybe not. i see the other one has a five lug and big back window.... scary how similar they are though
  24. SOCAL PETE
    SOCAL PETE
    from Ramona CA
    Did you dig that out of a oil tank or what...geez!
  25. Brad54
    Brad54
    from Atl Ga
    That timing set looks cherry compared to the one that came out of the 283 in my Suburban. It was hanging off the bottom gear and only connecting on the up-side. I could pinch the sides of the chain between the gears, and nearly lay them the whole way around the gears.
    Green Mountain Boy's was even worse--his has so much slop in it, the slack came around and rubbed on the timing chain cover, wearing a small hole in it.
    I wouldn't put a gear-drive timing set on yours... it's loud, which will be cool for the first 1,000 miles, and then you'll want to rip the thing off with your bare hands. But worse, it chews up a BUNCH of horsepower.
    -Brad
  26. nachodog
    nachodog
    from socal
    don't remember if i posted but here it is
  27. PRIMERDAVE
    PRIMERDAVE
    Muchas thank you!
  28. newrider3
    newrider3
    The pic doesn't really show the slack very well, looked worse in person.
    The whole gear drive thing fell through, so he just picked up a standard Cloyes double-roller set. He also found out that most nearly every cylinder had broken rings (surprising since there was no smoke). So how exactly did a clean and re-gasket turn into a full rebuild?? :rolleyes:
  29. jason65
    jason65
    Nice truck Nachodog.
  30. roofer
    roofer
    from uk
    Cool c10 nachodog, sits just right
