Hot Rods 1932 pickups
Discussion in 'The Hokey Ass Message Board' started by Hank-MOON, Jan 19, 2011.
  1. Hank-MOON
    Hank-MOON
    from Sweden
    Just joined and wants to see some cool -32 trucks !
    Here's some picures of mine.
    /Hank
  2. propwash
    propwash
    from Las Vegas
    nice looking ride - your sister is attractive too
  3. krylon32
    krylon32
    from Nebraska
    Your truck is really nice but your a little late. There's been a picture thread on here for a long time for 32/34 PUs. Do a search. Ops I see your new!
  4. Corn coupe
    Corn coupe
    from CZ
  5. Max Gearhead
    Max Gearhead
    from Wisconsin
  6. HOTRODPRIMER
    HOTRODPRIMER
    Good looking truck,,HRP
  7. Troyz
    Troyz
    welcome & nice truck.
  8. Shifter
    Shifter
    Welcome aboard.....very nicely done truck!
  9. budge nova
    budge nova
    really lovin that truck would have one meself i just dont fit [need shorter legs]
  10. Deuces
    Deuces
  11. DANA RED
    DANA RED
    Great lookin truck, how bout some spec's wheel @ tire sizes, etc.
  12. Ironswims
    Ironswims
    from Illinois
    Excellent ride!
  13. Mr. Jean
    Mr. Jean
    Welcome, you've got a great ride there.:cool:
  14. Hank-MOON
    Hank-MOON
    from Sweden
    Thanks !!
    Spec's :
    Wheels and tires are Halibrands 15x4.5 with 155 R 15 and 15x8.5 with 235/75-15
    Otherwise slightly flattened front crossmember, 4" dropped axle, c'ed front and rear, 8" rearend with shortest Aldan coilovers.
    Cab is chopped 2½" but I took out 1" under the windsheild frame to get the windsheild to line up better with the sideglas. So that makes the windsheild frame chopped only 1½".
    Lots of work but I felt it was worth it, I don't like the way these look when they're chopped otherwise. But that's just me beeing picky I guess.
    Home made bed with So-Cal cowl spears combined with a Focus emblem on the tailgate.
    I have a -33 firewall in there, that gives me 3" more leg room, and a custom made seat, so I can fit "okay" to be honest even though I'm over 6'. Otherwise these are hopeless to fit into, specially when they are chopped.
    And,,, that's not my syster.... ;)
  15. BISHOP
    BISHOP
    If you ever come to Texas, bring your sister.
    Nice truck too.
  16. rebstew187
    rebstew187
    Welcome to the site.
    Here's Wethington's truck. Fellow HAMB'er.
  17. deucetruck
    deucetruck
    from Missouri
    Welcome to the HAMB. Very nice truck......but I'm kinda partial to highboy trucks!
  18. Rem
    Rem
    Is this based on a sedan?
  19. Shifter
    Shifter
    I really like the chop. I have a '34 cab that I want to chop similar to the look you have. I understand your description of the chop.... "Cab is chopped 2½" but I took out 1" under the windsheild frame to get the windsheild to line up better with the sideglas. So that makes the windsheild frame chopped only 1½". So where did you cut the rear of the cab to get 2 1/2"?? Did you go through the window and remove all 2 1/2" there or did you remove some above or below the window? Can you explain in more detail, please. Your proportions are fantastic!!
    Thanks, Shifter
  20. Hank-MOON
    Hank-MOON
    from Sweden
    Hi Shifter
    I cut straight through the rear window opening.
    So I basicly took the top of the cab, as it's bolted together, chopped the rear of the cab 2½", then on the front of the cab I cut 1" out across the body just under the windsheild opening, ( the dash will come down too ) then took 1½" out of the posts, bolted the top on again and then cut the doors and frames to fit, DONE :)
    Good luck with your truck !
    // Hank
  21. vrod64
    vrod64
    from Katy,Texas
    Super nice ! Need one !
  22. hot rod pro
    hot rod pro
    from spring tx.
    you get my vote! looks nice.
    here is mine.
    -Danny
  23. hot rod pro
    hot rod pro
    from spring tx.
    brian, we have some to spare!
    -danny
  24. Shifter
    Shifter
    Thanks Hank,
    When I get a chance, I'll do some measuring to see how this will work out. Sounds pretty straight forward. Again......great looking truck!
    -Dave "Shifter"
  25. krylon32
    krylon32
    from Nebraska
    Hank: The more I look at your truck the more I think I will a full set of Brookville fenders and rubber boards for sale!
  26. da34guy
    da34guy
    My newest 1
  27. GaryB
    GaryB
    from Reno,nv
    ^thats clean,I like it....alot
