CHEAP and Great Alternative Coil Springs '49 thru '59 Ford and Merc
Discussion in 'The Hokey Ass Message Board' started by Fairlane Dave, Apr 26, 2008.
  1. Lono
    Lono
    dropped the aerostar springs in, Cordoba front shocks and 73 camaro shocks out back.
    In total, it dropped the front 3 inches over the original ( worn out springs)
    and 7 in the rear with 4 inch lowering blocks. It still has a in rake.
    It drives out real nice, corners fine and no bumping around.
    I'm running 205 75 15's and the motor is a 302.
    A good thread, thank for starting it.
    This weekend I'm doing my fairlane the same way.. its running a 390, will be interesting to see the difference.
  2. carnut341
    carnut341
    I used these on my 53 Ford and they work great! Car rides like new and steers better than it did with the cut coils.
  3. rustdodger
    rustdodger
    probasbly not the MOPARS with torsion bar suspension
  4. lockwoodkustoms
    lockwoodkustoms
    I am going to get them for my 51 Merc Woody
  5. Mr.Hepcat
    Mr.Hepcat
    Here's a picture of my 1950 with Ford Aerostar coils in front, and 3" lowering blocks in the back with 51 shackles for 1" more drop and one leaf spring taken off.
  6. BAD ROD
    BAD ROD
    I put the Ford Aerostar springs on my '59 Ranchero and many hundreds of miles. I like them. Nice and low and they ride better than the stock springs with 1.5 coils cut. Plus they are inexpensive!
    Mike
  7. Lono
    Lono
    The coils improved the ride of the ranchero so much I did the fairlane as well.
    My fairlane runs a 390 auto and had a sloppy ride into the corners. That's all cleaned up now. It's 3 inches lower ( 4 inches in rear). Here's a before and after... ( I stuck me in to give an idea of ride height, I'm 6 foot).
    If you're thinking of doing it.... do it!
    ThunderRocket likes this.
  8. Strange Agent
    Strange Agent
  9. rafael
    rafael
    from Moody AFB
    I alos installed the aerostar coils and the 5821 shocks up front, looks good except there a loud clunk on slow deceleration, i rechecked everything and all is tight, any suggestions?
  10. chillywilly
    chillywilly
    Aerostar coil swere great! Imagine my surprise when the MOnroe PN5821 shock had the wrong mounting plate on the bottom and didn't "bolt in"
  11. 4Door54
    4Door54
    from Nor*Cal
    Man i am glad i found this, Ive been looking for an alternative to cut springs.
  12. Javier
    Javier
  13. elrobo818
    elrobo818
    has someone tried this... and then maybe cut a coil or half a coil to make it a little lower? what do you guys think?
  14. rafael
    rafael
    from Moody AFB
    i've done it, but your def. right either lower the front a skosh more with coils cut or maybe some of them blocks under the spring support. just to make it sit level. instead of back to nose high at***ude.
  15. elrobo818
    elrobo818
    did you cut coils after the swap rafael? i might do that... i think there should still be enough travel and dont think the ride will be compromised... anybody else have any feed back on this?
  16. rafael
    rafael
    from Moody AFB
    elrobo, im looking at it now and with the blocks in the back, and the coils (uncut) in the front it still has a slight nose high stance. i think i should have either cut a coil off or perhaps dissasemble the lower control arm coil set (sorry i don't know the nomenclature of that piece) and install 1'' square tubing to lower the nose a bit more that way.
    right now the ride is not compromised, i think it could use just a skosh bit more lowering in the front. other than that it rides nice.
    hope it helps
    Rafael
  17. FE2dr352
    FE2dr352
    from Lindley,NY
    I was looking for some new springs for my 59 and found your post. Was your car a V8 car? Mine was a 6cylinder and will have a period 352 in the next few weeks. The original springs leave some to be desired even with the 6. I don't believe a 352 with an aluminum intake manifold is much heavier then a Y block. :)
  18. lockwoodkustoms
    lockwoodkustoms
    Bob you used the aerostar springs and everything was good ?
  19. lockwoodkustoms
    lockwoodkustoms
    Has anyone else dropped there Merc using an alternative set of springs?
    51 mercules likes this.
  20. general gow
    general gow
    MODERATOR
    daddy-o's-diner did on his '54. you can pm him for his opinion, but i believe he is pleased.
  21. lockwoodkustoms
    lockwoodkustoms
    I am wondering about using them on a 1951 Merc wagon?
  22. ScottyB
    ScottyB
    from Alabama
    Thanks for the great information. I just got done installing the springs and shocks recommended in the first post. A few of the posts above seem to indicate that they wont work on a Merc but they worked out perfect for us. Went for a good 40 mile drive and the ride quality is real good. The rear has 3.5" of lowering blocks. Here are a couple pics.
    Squablow likes this.
  23. lockwoodkustoms
    lockwoodkustoms
  24. ScottyB
    ScottyB
    from Alabama
    Here is a picture of the box :)
  25. lockwoodkustoms
    lockwoodkustoms
    ScottyB you used the Aerostar springs that they mentioned in the first page?
  26. ScottyB
    ScottyB
    from Alabama
    Yes, we got them at Advance, took only 1 day to get them shipped in.
    When you take the old springs out and compare them to the new springs you will say to yourself "no-way" because they are so much shorter. We took the a-arm loose near the center of the car using the four bolts that go through the cross member then lowered the arm with the jack, really easy. I also took the the snubbers off the lower arms.
  27. desertdroog
    desertdroog
    Kind of like this:
  28. general gow
    general gow
    MODERATOR
    scotty, that sits soooo nice. wow.
  29. 49 Mercury
    49 Mercury
    I have a 49 Mercury with a Jamco ball joint front end on order. will the Aerostar coils be compatable with this kit?
  30. lockwoodkustoms
    lockwoodkustoms
    Thanks Scotty, I have to do this
