What did you guys use for a brake booster or no booster? Really don't want to run a big booster on my shaved fire wall. Stock k member is gone also.
i used a 7" duel booster on a 47 ford i built for a guy and i looked real good on his firewall. we got the thing from performance online.
well if you want to do alittle more work and have power steering...hydro boost is the best damn thing running
My 6 inch booster from Master powerbrake fits under mine and is even with the bottom of frame. Did you channel yours?
im telling you go to your local junk yard get a hydro booster out of a 90s astro van 30 bucks and your golden
I,ve herd of people using geo-metro bossters. there small. i know they fit in the ford falcon very nicly.
were a kugle komponates dealer they have the bell crank pedal ***em. that fits under the dash thats whats on my car 408 561 5744
you could mount the booster inside and mount the master cly under the hood. It would be a lot of work to get the brake pedal offset toward the firewall but no booster hanging on your firewall
