Boxing a frame for a Flat Head V8?
Discussion in 'The Hokey Ass Message Board' started by Model A Fan, Jan 20, 2011.
  1. Model A Fan
    Model A Fan
    I am looking at putting a flat head V8 into a Model A frame. Would I need to box the frame for durability or is it not going to have enough power to really tweak the frame? Flat heads have a lot less power than Chevy 350's, but I want to be sure my project doesn't end up looking like spiral pasta. :eek:
    Thanks!:D
  2. Having owned flathead powered Model A Fords, I vote no.
  3. scottybaccus
    scottybaccus
    Not really needed. I would box firewall forward, but more for appearance sake...
  4. xix32
    xix32
    yes, box it - especially in the area of the rear engine / trans mount, and for quite a ways forward and rearward of there.
    i would say torque has nothing to do with the fact that the model "A" frame side rails aren't deep enough for even the weight of the stock 4 cyl. to be bouncing up and down on it.
    that's why the `32 was such an improvement.
    i spent many years restoring a '31 roadster. most of the frames i found were bent or cracked in the area of the rear engine / trans mount.
    i've seen many restored model "A"s with a big gap at the bottom of the hood where it meets the cowl, because this.
  5. junk yard kid
    junk yard kid
    my banger model a moves around all over the place.
  6. Morgan91
    Morgan91
    from Australia
    Yep Box the **** out of it. Better to be safe then sorry. Plus if you so it right it looks good aswell.
  7. It sounds like you've answered your own question. You probably don't HAVE to, but do you want to chance it?
  8. AJofHollywood
    AJofHollywood
    That doesn't make any sense. The last thing you want to see on a tradition Model A is boxing plates.
    No, don't box with a flatty. I never have, and never will on an traditional rod. Although if your crossmember rivets have loosened up some, you may need to take action. Weld your crossmembers in permanently.
  9. Will Kimble
    Will Kimble
    I would box for open drive (modern ******), not box for closed drive (torque tube rear).
    Will Kimble
  10. Russco
    Russco
    from Central IL
    It certainly doesnt HAVE to be for the flatty, I did not box mine, and guys have been running them that way forever without issues. But I bet ride and handling would be improved by boxing and adding a decent center crossmember structure compaired to the stock ch***is. Maybe step boxing would be a comprimise if you decide to box it.
  11. Checks and Balances
    The torque required to twist the frame is just slightly higher than that required to shear the banjo's axle key.
    winduptoy likes this.
  12. J'st Wandering
    J'st Wandering
    I have one and no you don't.
    Neal
  13. 94hoghead
    94hoghead
    better safe than sorry, box it! I'm abou tto do the ame thing. I have a flathead V8 thats going in a model A. I'm boxing mine.....
  14. Raven53
    Raven53
    from Irwin Pa
    Hey check with wethebmx here on the H.A.M.B. he cut me a set of box plates for my A they were a perfect fit .....and yes I would box it ...
  15. If you ever get the get the chance to twist on a 32 frame rail with the front cross member removed it is FAR more flexible than an A. This is a factory V8 car. I think most people boxing AV8 frames are only succeeding at making the frame ugly, especially when boxing the front frame horns...
  16. Groovybaby6
    Groovybaby6
    from Denver
    I boxed my frame with a flathead & closed driveline because it wasn't that good of a frame and I'm glad I did, there's a lot of torque around the steering box area, it would be easy for it to crack there. That's a disaster waiting to happen!
  17. Shaggy
    Shaggy
    from Sultan, WA
    What middle crossmember are you using?? if it is a 33-48 x-member i certainly wouldnt worry
  18. bobbooth
    bobbooth
    from limeyland
    dont see the point in boxing the front part only, but if you have the skills to weld in the plates I would defineatly go for a "K" member over the stock centre crosmember or a 32 / Tardel copy to go with the stock centre crossmember.This is a 34 trimmed to fit
  19. I say box it if the frame has had rust in the rear eng. mount area.I boxed from front cross member to the center cross member and did a k-frame behind the center cross member.Stiffened things up a lot and I also have piece of mind Knowing it is stronger.Pete.
  20. the-rodster
    the-rodster
    NO.
    Hell, NO.
    Rich
  21. rat farm
    rat farm
    from mn
    im a newbie on hear but id box it
  22. GOONZ
    GOONZ
    I personally would not box the frame with a flatty motor in it. I would just make sure you have a good center cross member such as a 33-34 x member or a 32 k member, those will stiffen it up nicely. My two cents on the boxing situation is if you are going to box it, box the whole thing. If you partially box your frame you have now placed all the stress at the end of your boxing plates which could result in excessive stress on the unboxed frame.
  23. nifty
    nifty
    from UK
    Friend of mine runs an AV8 roadster unboxed, driven hard,raced and some hard off road driving too, no issues at all.
    I bought my AV8 coupe which someone had boxed and when we put the ch***is on the table it was twisted, probably due to someone boxing the rails and not knowing what they were doing.
    I wouldn't worry about boxing it but if you do keep an eye on it.
