Cheesy Tech: Speedo cable housing repair
Discussion in 'The Hokey Ass Message Board' started by 61Lancerwagon, Mar 10, 2005.
  1. 61Lancerwagon
    61Lancerwagon
    Unfortunately I have no pictures cause I did this quite awhile back, but when I got my wagon one of the many things broken was both the speedo cable (end twisted off) and cable housing itself was screwed, broken in half. I got the generic replacement cable, a Help! item, but had to invent a way to fix the housing. After looking it over I noticed that a piece of leftover steel tubing, I think 5/16, about 3 inches long, fit over the outside of the housing. I chamfered the inside of the broken cable housing ends, slipped the two broken ends into the tube and put a pretty decent looking hex crimp on it with a pair of heavy duty tv cable connector crimpers, like Radio Shack part 278-238. The pair I had around looked a little heavier duty, crimped about a half inch at a time. It spliced the halves neatly and the cable lasted long enough that the speedo itself ****ped out next, about 2 more years.
    You could also use this to make up a cable to fit say a Ford speedo on one end to a Chevy trans end etc. Kind of feeble, but I want to contribute something, I've been learning a lot on here, you guys are pretty incredible.
    Randy
  2. Kustm52
    Kustm52
    Nothing cheesy about something that works! I used a similar method to mate a '52 chevy and a s-10 speedo cable...
    Brian
  3. Definitely NOT cheesy!! I NEEDED that tech! Trying for a while to figure out how to mate a SBC tach drive distributor to an English (Smiths) tach. Ditto for speedo. You've got me thinking now. Thanks!! -Keith
  4. 61Lancerwagon
    61Lancerwagon
    I'm glad somebody could use the idea, let me know how it turns out. I just meant that I'm under no illusion about how useful this is compared to some of the artists whose tech post's I have been reading since I got here. I stand in awe of the craftsmanship and useful info I see around here.
    Randy
  5. Hank
    Hank
    from Wisconsin
    This works great. I've done it in the past. I'd recommend adding a piece of shrink tubing over the joint to seal out any water that might get it. The one I did was about 9 years ago and still working good.
