Hemi in a Motor Home
Discussion in 'The Hokey Ass Message Board' started by Oldmics, Jan 21, 2011.
  1. Oldmics
    Oldmics
    So a buddy of mine who lives a good distance away tells me his Dad left him a motor home thats pretty well trashed.
    Says it has 424 (yes 424) Hemi in it.
    Of course it ran when it was parked (in 1985)
    Motor was supposedly rebuilt before then and had low miles (bla,bla,bla)
    Should I get it? Is it worth the effort?I"m a Ford guy so its a flipper.
    Motor home with Hemi-Did somebody actually produce these things?
    Oldmics
  2. 49ratfink
    49ratfink
    what's a 424 Hemi?
  3. EarlKann
    EarlKann
    Sounds like a lot of bad information.
    I'd get pictures first.
  4. Only MOPAR engine I've seen in an RV is a 440.
  5. NM Sandrail
    NM Sandrail
    Never have seen a hemi in a motorhome myself.. My 74 has a Dodge 440, but not a hemi.. duane
  6. Novadude55
    Novadude55
    from CA
    Cant find anything about a 424...
  7. I think it was a special motorhome hemi. :D
    My grandpappy had one with a 440 in it in the 80's.
  8. stude_trucks
    stude_trucks
    Some had 413's too, but never heard of one with a hemi and definitely never heard of a 424 anything, let alone a hemi.
    Was this guy or his father a crack head by any chance?
  9. ZomBrian
    ZomBrian
    from in IN
    A picture would be very helpful.
    As a side note...did you happen to purchase an old Stromberg-Carlson Bullet Mic on e*ay last year? 'Cause I sold one to a guy in Baltimore last year when times got tough and I sure do miss it.:(
  10. Ditto for my RCA 77-DX and my Sennheiser KM84, although I did get a ton of $$ for them.
  11. ZomBrian
    ZomBrian
    from in IN
    Yikes. Ribbon. I'd have gone for the money, too.:eek:
  12. Edelbroke
    Edelbroke
    Im thinking its a 413 wedge motor...
  13. 73RR
    73RR
    Depending on the motorhome, it could also be a 360...
    Ya gotta at least go look at the thing.
  14. I think it is a 454 chev motor
  15. George
    George
    Probably one of those Hemis that have plugs hanging out of the side of the heads....
  16. bulletproof1
    bulletproof1
    from tulsa okla
    whos to say the 426 wasnt sleeved to 424? ha ha !!! how about a 426 wedge
    i know where a 57 chevy school bus is with a 348 w motor in it...it didnt come that way ...
  17. newpy383
    newpy383
    Go look at it. 413's and 440's are getting scarce. Turn a buck on it.
  18. jdj9410
    jdj9410
    from Paris TX
    Probably 454 Chev. put a ton of them in Motorhomes at that time, the 80's. Worked at Chev dealership truck shop back then. I called them murder homes then. Probably blown up. Everyone I seen then was. But I was a heavy line mechanic then is probably why. 70's was the mopar motorhome era wasn't it. Winnebagos had a lot of them then I believe. Never heard of a 426 in one though.
  19. Deuce Roadster
    Deuce Roadster
    I had one with a 318 ... a 24 foot Winnebago Brave.
    Man was it slow :rolleyes:
  20. Hombre
    Hombre
    Just about the only Motorhome that possible could have come with a Hemi of any size would have been the old "Cortez". These came with in the begining with a Mopar Industrial 225 Slant Six. They were produced from 1963 until around 1979 or so. I could see one of these having someone install maybe an early Hemi in, MAYBE!!
    I did a lot of searching and even called a couple of real Hemi guys and if there ever was a 424 inch Hemi it is the mystery motor of all time. It's still worth checking out thats for sure. While I seriously doubt there is or ever was a 424 Hemi, look at the possibilities. It could be a 426 and that would be a real good find any place any time.
    RS
  21. seventhirteen
    seventhirteen
    from dago, ca
    the travco was a dodge motorhome made in the early 60's, none came with a hemi but going from a 440 to a hemi isn't that far fetched
    forget the 424 thing and go look at it, a hemi has to be one of the easiest motors of all time to tell from just looking at it
  22. rockable
    rockable
    You SHOULD have put a Hemi in it, Randy!:D
  23. 1941ihkb5
    1941ihkb5
    I worked on a 71 winnabago for a customer last spring. It had a 318! Most of them I saw over the years were 440s or 413s.
  24. Martys 55
    Martys 55
    my guess is probably a 0.60 over 413 cid
  25. 94hoghead
    94hoghead
    I had one just like it......only different.
  26. I have a friend that has a Cortez that he says has a HEMI.
  27. brad chevy
    brad chevy
    In the 70s motor homes Mopar powered most of the motorhomes I worked at a Dodge dealer and did all the big truck and motorhome work.The smaller ones had either 318 or 360s in them,but all the larger motorhomes had 440s in them. Chevy did power some motorhomes back then and mostly were 454s.When anybody finds this 424 Hemi posts some pictures cause they will have a one of a kind.
  28. starting to stray off topic but the Cortez 225 slant six had dual side draft carbs and 4 speed trans. I'd love one of those manifolds. My Cortez is a 73 and has the 375 horse 455 Olds front wheel drive
  29. mixedupamx
    mixedupamx
    ive got one in an 89 dodge window van and its also slow but its dependable as an anvil!
  30. I know it was stated. it was parted in 85, so the next statement does not apply.
    But I belive the newer SRT8 6.1 motor, with a stroker kit are 424 cubes
