has any one done a straight axle convertion on a trifive chevy?
Discussion in 'The Hokey Ass Message Board' started by cruzin55, Jan 21, 2011.
  1. cruzin55
    cruzin55
    from califorina
    im wanting to do a straight axle conversion on my 56 chevy but have never done one before. can anybody give me any suggestions on the best way to it? and or details about it? do i have to cut my front end off and make a new frame? what axle fits under and adapts best? how much caster should i have? whats the advantage of having the shackles in the back verses the rear? any suggestions on how to get it perpendicular with the frame? what steering box will work best? or do i have to change it?
  2. Killer
    Killer
    really? You should probably search dude!
  3. 1971BB427
    1971BB427
    from Oregon
    Yes. You can do it with the stock frame and a '55-59 Chevy truck axle works best if you're using a truck axle. Otherwise you probably want one of the aftermarket straight axles.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Actually the 48-54 axels track is closer to the cars track. The 55-59 are wider. Just say'n
  5. 1971BB427
    1971BB427
    from Oregon
    Well I've done 2 using the 55-59 axles, and they're perfect for the spring width. The early axles don't have parallel springs, and take way more work to build mounts. The late 50's are super easy to build mounts, and I like the slightly wider stance, since most g***ers use narrow front tires.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Just give'n the FNG some info as far as differant axels. Some like'm wide, some like'm narrow. Just like women :D. No right or wrong.
  7. braindamage
    braindamage
    from Arnold Mo
    Did a 55 for a freind and used speedways axle kit. Used the factory frame just unboled and removed the a arms and reused the steering box. Kit came with s10 type disk brakes and everything to do it . It was around a grand for everything.
  8. bowtie56jw
    bowtie56jw
    used a 68 chevy 3/4 ton van axle on a 56, 6 leafs worked great put her up in the air good. speeds over 85 she was a handfull but we wernt building a canyon carver to start with.
    whitey
  9. Retro Jim
    Retro Jim
    OH well lets see .....there must have been thousands of them built . Very common and if you do a search I am sure you will come up with plenty of information right here . If not just make a Goggle search and see how many hundred thousand come up there .
    If you ever pick up a Super Chevy Mag , I bet there is at least one in ever issue .
    Retro Jim
  10. Mac_55
    Mac_55
    Yes sir , I really prefer using the 55-59 truck axle .seems like it was built for it.and as long as you are running bigs n littles the wider track width isnt even noticable . I put 3.5 inch gyros up front and 11's out back , wheel wells are full and the only thing sticking outside the car is maybe an inch of the 11's outback, Nothing sticks out up front . I even had a set of 7 inch wide roll arounds on it and they didnt even stick out . Kinda like Pontiac , just tell people its a wide track g***er lol , Make em think
  11. Louver Dude
    Louver Dude
    I have a friend selling a rolling ch***ie for a tri 5 with straight axel up front, disc breaks the whole nine yards for 6k.
  12. Frapps
    Frapps
