Like to weld without a hood?
Discussion in 'The Hokey Ass Message Board' started by choptopdoc, Jan 22, 2011.
  1. EnglishBob
    EnglishBob
    It seems like some of you are proud of being ****in *****s.
    You get two eyes and one chance...try acting your age.
  2. Deuce Daddy Don
    Deuce Daddy Don
    Well said English Bob!!!!!! I can't believe some of these threads on welding!!
    Old welder since 1951--USN Korea
  3. gimpyshotrods
    gimpyshotrods
    I had this happen to me when I had a trigger short on a MIG unit back in the late 80's. It hurt like hell. My eye doctor can still see the scars.
  4. Damelot85
    Damelot85
    Are you guys ****in retarded? I'm young, dumb and full 'o c.....
    well you know. Either way I always grab my helmet before I even tack anything.
  5. shoebox1950
    shoebox1950
    Don't you know it's rockabilly to weld without a hood? Just look in Ol skool rodzzz! Welding without a hood has got to be the stupidest, laziest thing you can do...especially if you are a "professional"
  6. chaddilac
    chaddilac
    Look here Ray Charles... you close your eyes when you tack weld... and you use spf50 before you weld!! make sure you get it on your eye lids... Dang! It's like I'm playing with my brother's kids or something....
  7. THE_DUDE
    THE_DUDE
    Four times for me, Yep Im a *****.
  8. Gee, that would be a safety issue, kind of like driving a car with no fenders...............:rolleyes:
  9. Offy 220
    Offy 220
    I am not sure what is worse - fried eyeballs, flash burned skin or both. I have been welding for the past 30 + years and yes, potatoes and tea bags help relieve the pain. I have cut potatoes in half in a curved fashion according to the curvature of your face, or sliced them thin but the juices don't last long.
    Please wear protective clothing and eye wear. It bothers me when I watch these "car build" shows and no one wears PPE [personal protective equipment]. Five minutes of TIG welding can cause a lot of pain. At work I am involved with container crane repair which requires structural welding, we can have time off work if caught not wearing our protective gear. As others have said, you have only one set of eyes, please take care of them - you and your family will appreciate it!
  10. deano.33
    deano.33
    from Australia
    I dont know if Im an idiot just by myself or not, I do find it amusing that so many Hambers have just said that "Ive been burnt once and never again". Every now and then you seem to cop it again either with other welders around or when youre the guy holding the part to be welded. We all say never again!!
    Why does it always seem to hurt like hell when you try to go to sleep??
  11. DocsMachine
    DocsMachine
    from Alaska
    I have to admit I'm kind of surprised to hear that not only do people apparently actually try to weld without a hood, but also that, according to this thread, it's amazingly common.
    Weld without a hood? That's like an astronaut going EVA without his helmet because he's "only going to be outside for a second". :D
    I mean, you need three things to weld- the welder, the thing to be welded, and the stuff you wear when you're welding. Skipping one of the three is like skipping the fuel, spark or compression and hoping the engine will still start. :D
    I will admit that, in the dim years before the electronic hoods, I'd use a pair of safety gl***es, and do the "close your eyes and tack" trick with a MIG. But that was just for tacking, not for actually trying to run a bead, and even for the tack, I'd close my eyes.
    I got a good sunburn once after doing that for most of a day placing parts under a custom dashboard (along with the BBs in my ears) but since I never watched the arc, my eyes were fine.
    Hoods, jack stands, fire extinguishers. There's a reason we invented 'em. :D
    Doc.
  12. deano.33
    deano.33
    from Australia
    Yeah I agree totally, You couldnt seriously weld without a helmet could you? My last comment was more on "Welders flash" occuring. Auto helmets can cut in and out depending on lighting and dodgy batteries. I would guess that most guys tack without helmets but run full welds with helmets on. But you would always have youre eyes closed when youre tacking??? Deano
  13. johnybsic
    johnybsic
    from las vegas
    Yea.
    I dont like doin this...
    I tried tacking once without a hood, Not only could i not see anything, But i just said "Naaa dude not a good idea". did two tacks and put mu hood on.
    Did get hit once or twice welding under something, and an object would cover the optical sensor on my helmet **Ziiiip** Fu*king Aghhh.
  14. johnybsic
    johnybsic
    from las vegas
    Deffinately NOT run a bead.
    Its hard to be a bad*** when your blind.
  15. stude_trucks
    stude_trucks
    I can't even weld good with a hood on and seeing what I am doing. I can't imagine trying it without one, with my eyes closed no less. Maybe I'm lucky after all that I need a helmet to even just get the spark going.
  16. Gsnickets
    Gsnickets
    I weld for Holland 1916 in KC, I'll usually tack stuff together without a hood, but I'll be damned if you ever catch me running a bead without a hood. the new auto darkening hoods are just too good for anyone to complain about... like a shade 6 pre arc(plenty light enough to see well), and most are adjustable from shade 8-12. even at a shade 8 you can still get flash burn. I like to keep mine anywhere from 9 to 10 1/2. with the miller's you just have to remember to turn the damn things back on if you haven't been using it for awhile, I think it's like 20 minutes and it turns off.
  17. Docco
    Docco
    from Ippy
    No ones mentioned this so i thought i would....
    You know the sand feeling you get with flash burn is actually little popped blisters on your eye ball.
    Thats why it feels so **** when you blink.
  18. Fe26
    Fe26
    Re: Like to weld without a hood?
    No, I don't.
    Three days ago I was tack welding (ch***is repairs on my '36' Pickup) which was on the hoist. I always close my eyes and turn my head away from the arc, this time I should have closed my mouth, yeeow!!! Spark in the mouth, the ******* thing stuck to the roof of my mouth, near the back. **** it hurt.
    My mechanic was dumbstruck when I went into 'mad gesture mode' and went for the water very, very quick.
    I suppose that's why he asks me to come over and do the ****ty work.:D
    Note to self: Close eyes and mouth when tack welding. Hold breath while waiting for hot stuff to fall into crotch and down workboots onto feet and toes.
  19. <!--[if gte mso 9]><xml> <w:WordDo***ent> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:punctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDo***ent> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> I could never understand why anybody welds (or tacks) without a hood. Just not worth ****in up your eyesight.
  20. hippy killer
    hippy killer
    i try to take care of my eyes and back the most.....im young gotta make them last 40 more years or so
  21. edwardlloyd
    edwardlloyd
    from Germany
    Only last week I bought a nice new automatic hood. Spent quite a bit on it but it was worth every penny. Now I can see a whole bunch easier. Older automatic hoods can be quiet dark and slow. Try a good new one!
    Ed
  22. LotsToLearn86
    LotsToLearn86
    from Norco, CA
    I keep the lens clean and get up close and personal when I'm on the bead... Lighting usually helps me when I have a hard time finding my penetration line. But, everything is preference and opinion in this line of work.
  23. scott 351 wins
    scott 351 wins
    The potato trick really does work like said before.
    I was grinding a ****py weld and my saftey gl***es were out of my reach and i decided to just squint my eyes real tight to tiny slits thinking that will work. I got a nice peice of steel in my right eye and was off work for a few days. Took me 2 days to figure out that it was not welding burn as i originally thought. The steel in my eye had rusted and the eye doctor had to grind the rust out of my eyeball with a dremel like tool.......fun.
  24. donut29
    donut29
    from canton MI
    WTF!! Are you guys thinkin not wearing a helmet. Thats about the stupidest thing I have read on here
  25. brad chevy
    brad chevy
    Welder-wear eye protection. Garbage disposal- do not stick hand in . Which one you want to lose? your site or hands.To the idiots that weld without eye protection ,damn!
  26. willowbilly3
    willowbilly3
    from Sturgis
    I did it once when I was about 8-9 years old. I see some of the tv show guys doing it, and also welding in short sleeves.
    It's just frikken retarded, no matter who you are.
  27. 55 dude
    55 dude
    not only are your eyes at risk but exposed skin can be a great starting spot for cancer. spoken with old time welders and their exposed arms had some nice scars where skin cancer had been removed and the areas were really ugly because sometimes its not just on the surface and they dig until it's gone!!
  28. zman
    zman
    from Garner, NC
    lol, that's exactly what I was thinking.
  29. english rob
    english rob
    I agree with you there
  30. carcrazyjohn
    carcrazyjohn
    from trevose pa
    One time I had to weld without a hood ,I could not get car High enough ,At 300 am I woke up in agonizing pain ,Couldnt wear my gl***es or contacts the tears just kept tearing from my Eyes ,Went for a walk to get smokes ,The cool air felt good on my eyes .When I got home my wife was sitting on the couch wondering what went on .I told her welders flash ,She asked me,Were you wearing a mask ,I said no.She said Dumb ***
    I also had a steel sliver in my eye from grinding and they grind your eye ,Weird feeling You have to stare at them while there doing it,Now I grind with my sungl***es on
