'54 chevy steering wheel
Discussion in 'The Hokey Ass Message Board' started by chato0824, Jan 22, 2011.
  1. chato0824
    chato0824
    Ok I need some help with this. I have a '54 chevy and I'm trying to remove my steering wheel to redo it. I feel like an idiot but, can anyone explain to me how to take this off? Any help would greatly be appeciated. Thanks
  2. flathead4d
    flathead4d
    Do you have the horn ring off yet? If so then there should be a nut to remove and you will probably need a steering wheel puller. Got any picture you can show us?
  3. sr808
    sr808
  4. chato0824
    chato0824
    No we tried last night and couldnt figure out how it comes off.
  5. lawman
    lawman
    It's been years ,But I think it has screws in the back toward the dash.
  6. gas pumper
    gas pumper
    I got a 54 and the steering wheel hub is the same as later GM up to maybe the 70's.
    The horn ****on part might be a snap on over the ring that is held on with the 3 screws after you get the horn ****on part off. The arms maybe have a screw in each arm.?
  7. Pop of the horn ****on and there are three screws that hold the horn ring on. Take it off and then all you have left is the big nut holding the wheel on the steering shaft. Best way to take it off is using a puller but if you don't have one there is a tried and true old method. Back the nut off until it is flush with the end of the shaft, but your knees against the back of the wheel and smack the nut square and hard with a hammer...should pop right off. Just make sure not to leave any exposed threads on the shaft to bung up.
  8. chato0824
    chato0824
    Thanks for the info Wild Willy. I will attempt this tomorrow and hope this works. I appreciate allof the help on here. I will try and post pics of the build process. Thanks
