Projects My 1929 Model A Ford AV8 truck build thread
Discussion in 'The Hokey Ass Message Board' started by INLAW MODEL A, Dec 12, 2010.
  1. It is a 48-52 Ford F1 truck transmission crossmember.
  2. This is the best build I've seen since Rolf's coupe. Brilliant!
  3. Red Ram Hemi
    Red Ram Hemi
    from Shack
    Looks like it will work pretty good!
    Red Ram Hemi
  4. Yes it is a good choice. The only thing better is a x member from a 32.
    You can see it now installed on page 4, Ryan accidentally deleted my pictures. I just uploaded them to photobucket and attached them.
  5. reece
    reece
    from NC
    Great build with good pictures. cant wait too see this one finished. I really like how the frame turned out.
  6. Thanks! I can't wait to see the frame painted!:D
    If it was above freezing I would paint the stuff outside.
    I decided today to pressure wash the engine. It ****s when it is cold out but I figured I would try it. It was 15 degrees and I made a lot of steam. It came out pretty clean though. I need to do a little brake clean cleanup and it should be ready to re***emble. The pan was the worst part. It was full of sludge.
    Another reason to pressure was was to clean out the block of rust. This is the second dust pan full of rust that I removed. I am sure there is still some in it. I ran water through it until it was clear.
  7. I couldn't resist bolting it together to see how it looks:
    I also managed to spray some etch primer earlier in the week:
  8. thunderbirdesq
    thunderbirdesq
    Awesome build, love it!!
  9. Angry Frenchman
    Angry Frenchman
    nice nice nice, I love all these home made thing you keep finding and that your using the parts from them. the radiator in the stationary power source looks like A 1932 v8 ford. if it is thats a real good score!
  10. rotenjon
    rotenjon
    Nice build! I am in the process of building a 27 T Tudor in an A frame with a 53 flatty and open drive. My engine is in the same condition as yours and i would like to know how you cleaned the the engine with in the short block configuration? especially the pistons and valves.
    P.S. Looks like you will have alot of fun when its done!!!!:D
  11. Thanks, I think it should be a fun little truck. To clean the engine I just used a grinder with a wire brush. When I was all done I used a hot water pressure washer with good soap. When the block gets hot enough, the grease releases. I also used a needle scaler for hard to reach areas on the block and in the p***ages.
  12. 29Jay
    29Jay
    from Ft Worth
    Very nice build! I will be comming into a '29 Sports Coupe soon... I would love to drop a flatty in it. I will be re reading your build severial times.
  13. rusty1
    rusty1
    ...are you gonna use this truck as a tow vehicle for you Fiat?
  14. cooljunk
    cooljunk
  15. I plan on making it the push truck with a board on front.
  16. wingedexpress
    wingedexpress
    I love what your doing with this truck.What color for the body.One more thing keep those kids involved my two love to go on joy rides.
  17. Thanks, They already have the bug. I was thinking semi-gloss maroon. It will not get painted probably until next winter. I hope to have it driving for June 2011. It will probably be call the r word until I can get paint on it.
  18. 97
    97
    You should be posting YOURS , Marty!!!
  19. -Brent-
    -Brent-
    Wow, this is a GREAT build!
  20. Retribution
    Retribution
    from Western PA
    I like your build, I'll be watching this thread!
  21. This weekend was not real productive for the truck. I did manage to get a oil pan that did not leak and get it cleaned up. I pressure washed the block and pan again and got it cleaner. I also fired up the sand blaster and cleaned up a few more parts. I found a pair of pumps that are better than what I had, plus I did not want to use the double pulley pump.
    Then today I managed to install the pan and water pumps and put on a coat of primer. Maybe by the end of the week I can have the engine ****oned up.
  22. NVR2ND
    NVR2ND
    Excellent, keep up the good work!!!
  23. lorodz
    lorodz
    looking good....
  24. Model A Mark
    Model A Mark
    from dallas
  25. aldixie
    aldixie
    A very nice build. Where did you get your inner driveshaft shortened? I'm in the middle of my Sport Coupe build and it's one of the only major jobs left.
    Thanks,
    Alex
  26. Thanks!
    I had a local machine shop that also drive shafts do it. I could have done it myself, but I could not hold the coupling centered in the lathe. Any machine shop can do it for you.
  27. 29ToyA
    29ToyA
    Great looking build!
  28. I did a little more priming and painting today. The red is still wet but I had to put on some goodies to see how it looks. :D I painted it red because I was told red is for racing.
    48fordnut likes this.
  29. lorodz
    lorodz
    looking good ,,,
  30. Thanks man!
    I picked up these tires for the rear 6.50-16 Firestones:
    Tim likes this.
