Holy Crap It Works!
Discussion in 'The Hokey Ass Message Board' started by POLYFRIED 35, Jan 24, 2011.
  1. POLYFRIED 35
    POLYFRIED 35
    This is probably old news to those who do it a lot, but I just found out about it, tried it, and it works!
    Pilot bearing removal using paper and water.
    Tear up a sheet of old newspaper and get it wet.
    Find a socket or round stock that will slide easily into your pilot bearing. I used a 1/2 inch deep socket and placed it onto an extension. If you use a socket you have to stop the paper from going into it, so place a bolt in the end.
    Start packing some of the wet paper into the bearing until full.
    Place your socket with bolt, round stock or whatever your gonna use into the bearing.
    Pack the paper by hitting the end of your extension with a hammer.
    Take it out and put some more wet paper in there ... Pack it again with the hammer.
    Continue this process and the paper will start pushing the bearing out! The more you pack the more it comes until it falls right out.
    In my case, the half inch socket was a bit too small and metric to big. Once the wet paper started working it's way around the socket I put a penny in there. Perfect, that sealed it up nice and the bearing came on out.
    If you have to go this route, get as much paper packed in first or you won't have enough behind the penny to push the bearing out and I imagine it would be a pain in the **** to get the penny out before the bearing to add more paper!
    Hopefully this will help someone doing a pilot bearing for their first time ... It sure helped me.
    Google is your friend!
    Note ... a pilot bearing removal tool would be your best bet .... I used what I had.
    Sent from my iPhone4 using TJJ
    iPOLYFRIED 35
  2. 94hoghead
    94hoghead
    cool...............
  3. john walker
    john walker
    we used to use axle grease and a snug fitting dowel.
  4. I have always used grease, but this looks to be a much less messy method of getting the job done.
    Bob
  5. 57JoeFoMoPar
    57JoeFoMoPar
    Absolutely. Great trick. The fluid, whether it be grease or water, is incompressible. The bearing moves instead. Good work
  6. POLYFRIED 35
    POLYFRIED 35
    I saw that one online as well and it looked like it worked great but messy, especially if your dowel or socket was a bit small. I had wet paper splattering me in the face, I couldn't imagine grease LOL:D
  7. Tudor
    Tudor
    from GA
    Thanks for sharing
  8. propwash
    propwash
    from Las Vegas
    slide hammers can be used for so many other things, that I just can't imagine using anything else more than once. That being said - nice solution.
    dj
  9. Warpspeed
    Warpspeed
    This is fantastic !!!
    I have always used grease too, and made an awful mess.
    I believe child's play putty works pretty good as well, but wet paper is BRILLIANT.
  10. JimSwann
    JimSwann
    Cool, thanks.
  11. fleetbob50
    fleetbob50
    from Waco,Texas
    Use a short socket, or your long if its a straight thru and plug you extension in backwards, eliminates the bolt, get results quicker
  12. demmals7ytriht
    demmals7ytriht
    from Speer lane
    Thanks, great post...........
  13. POLYFRIED 35
    POLYFRIED 35
    It's the simple solutions that often elude us ... great idea, thanks!
  14. GREASER815
    GREASER815
    I was taught to just use grease. Beats wadding up a bunch of wet paper.
  15. Three Widow's Garage
    I'll have to try the wet paper, always used grease also and will have to agree with the mess. Another trick is to use a dowel / socket or roundstock that is slightly smaller than the pilot bushing, wrap it with electrical tape to bring it up to a tight fit. That way you wont squrit grease all over the place or damage the bushing if you were planing on reusing it.
  16. funk 49
    funk 49
    cool tip. i'll try this next time instead of the grease. thank you
  17. 40Standard
    40Standard
    from Indy
    always used grease, will have to try water next time
  18. Mr48chev
    A lot of us poor boys don't have a slide hammer and there is always newspaper laying around or wheel bearing grease and something the right size to stick in the hole and wack with a hammer. Actually, I've usually had better luck with the grease than a puller.
  19. rusty76
    rusty76
    from Midway NC
    Wheelbearing greese is what we usually use.
  20. JOECOOL
    JOECOOL
    Your going to laugh but I use a Tampax, go ahead you can laugh now!!
  21. burnout2614
    burnout2614
    That's cool joecool! Tampax, a hundred and one uses............now, a hundred and two...wait that's duct tape! peace
  22. thunderbirdesq
    thunderbirdesq
    I use peanut ****er, mmm...
  23. Warpspeed
    Warpspeed
    What exactly for ?
  24. Jagman
    Jagman
    I've used grease for over 40 years to do this and I never had it splatter on me. The thing I like about this method, whether it's with grease or paper or whatever is that it doesn't damage the hole. If a slide hammer's lug is a tiny bit too long it can s****e the sides of the hole. This method is pretty much foolproof and quick............
  25. ClayMart
    ClayMart
    There's got to be some way to do this job with dryer sheets. :rolleyes: They seem to work for everything else! :D
  26. 32-3 WINDOW
    32-3 WINDOW
    from utah
    we always used grease , and then just put the extra on the flywheel to keep it from rusting l.o.l
  27. RNess
    RNess
    Mr 48chev, I agree. Thanks ( Polyfried 35 ) for sharing.:D
    We poor boys had to use a lot of " ingenuity and what ever we had lying around". When I was a teenager, if I did not figure a way to fix my vehicle, I did not ride!
    "Do all you have agreed to do "
  28. BenW455
    BenW455
    I have seen this done but with a bar of soap. Shave pieces of soap and pack in the hole. Work pretty good.
  29. 56sedandelivery
    56sedandelivery
    Always used grease, and since it was always on a Chevrolet, the ratchet end of a Craftsman 3/8" drive extension; it's the same size as the pilot bearing shaft on the trans input shaft. Butch/56sedandelivery.
