late olds 350-455, who runs them?
Discussion in 'The Hokey Ass Message Board' started by ***Area-51***, Nov 5, 2006.
  1. ***Area-51***
    ***Area-51***
    from Ohio
    just wanna know if i'm a loner...i think theres atleast a couple others
  2. Anderson
    Anderson
    I've got a 350 in my Cutlass. Love it...
  3. oldspert
    oldspert
    from Texas
    I'm building a 46 Ford coupe with either a 350 or 425 Olds with a four speed.
  4. skajaquada
    skajaquada
    from SLC Utard
    i'm dropping this 455 in my '84 delta88...:D
  5. Big Olds Dog
    Big Olds Dog
    Olds Power
    76 olds Cutlass .030 over 350/4spd
    72 455 in garage
    66 330 in garage
    70 350 in garage
    more frigging oldsmobile stuff than ive got cars
    you ain't alone
    just strange like us
  6. Big Olds Dog
    Big Olds Dog
    also pontiac stuff up the wazzoo
    48 pontiac is the car of choice
  7. purple
    purple
    I have a 350 Olds with a unisex 350 in storage waiting for the right project.
  8. Long story, but I ended up with a rebuilt olds 350 from my father-in-law and will probably use it in a future project.
  9. I'm running a buick 455 in my 46 chevy.
  10. Doug F.
    Doug F.
    I've got a 455 thats OEM in my 70 Olds 442. Does that count?
  11. 29AROD
    29AROD
    i am thinking of running a olds 455 in my 30 model a coupe. getting the engine from a friend. says it is a 35k mile engine out of a 1968- 70 car. has trans to.
    is the trans worth using or should i look for somthing diffrent. want to run a 5 speed but have to find an addaptor.
  12. dezaster
    dezaster
    from u.k.
    ive got a cammed and polished/ported 455/th400 combo that was in my '64 parisienne, i whipped it out before i sold the pontiac, and im now going to shove it between the rails of a '28 A tudor :D
    oh, and ive just bought a rather tall offy tunnel ram for it, jsut need a couple of 750s to sit on top of it now.....
  13. ***Area-51***
    ***Area-51***
    from Ohio
    i tend to stick with the big block olds...but the 350s got a bore/stroke combo...tempted to do one up, so i can harass my buddies that swear by the sbc
    keep us posted on a coupe with the 455..i had these same thoughts about a 31 pickup with a big olds
    two 750 on that tunnel ram, what else in that animal to support 2 750s
  14. bigDrew
    bigDrew
    I've got a 455 olds and muncie 4 speed left over from a previous build that is going into my '37 chevy truck project. I'm almost done with a 8x2 intake for it, which should make it even more unique! I'll post some pics of the lake-style headers I am building for it next time I make it out to the garage with the camera.
  15. Matthimself
    Matthimself
    This summer a buddy and myself unsiezed his grandpas 1970 delta 88 that had been sitting for about 15 years. Fired it up, filled the tires, couple brakes lines, and did one continuous burnout for the rest of the summer. 500 foot pounds stock with a 2 barrell can make that car move pretty good. Box those frames!
  16. I'm running a warmed up 455/th400 in my 55 Caddy. I figured a fat bastard like that needed a torque monster like that. A belly button motor would have been easier/cheaper but not "right". I already had the olds otherwise it would have been a 500 Cad
  17. hotrodladycrusr
    hotrodladycrusr
    I've got a '70 Olds 455 in my '47 Olds convert :D
  18. Hip
    Hip
    I had an olds 455 in my '59 chevy p/u till it spun the bearing, and did you know noone but, "Moneybags Mondello", is the only one that reproduces a crank anymore!? If i'm wrong please correct me so that i may be steered in the right direction, cause i aint buyin one of his (solid gold), cranks!
    A buddy of mine has two that he'll let go for
    500.00 that i think i'll pickup and part out the rest, (some brand new parts in one). Anyway, those things stock even,....ROCK!
  19. I bought a '69 Toronado just for the C-head 455. Set up, but I put some stuff in it, need to find a socket for the bolt on the balancer or else stick a battery in the car -
    Who knows, I'd swap it for a Pontiac, but from what I've read it's worth hanging onto even if I just stick it in the car hauler truck I bought -
  20. Kanaka
    Kanaka
    I've got a 1973 Olds Toronado 455 drivetrain in my dune buggy if that counts.
    Scotty
  21. The Vanderveldes friends of mine have several 455 olds powered vehicles. first was a 74 chevy 3/4 ton 4x4 . I built the engine , they had the trans case from the olds put in place of the original chevy case on the FWD unit. Bolted it in with Diesel mounts. They had a decal made saying 455SS. Truck is was sold but is still running almost 15-16years later
    Next we did a 455 and installed it in place of the 4100 in jakes 86 caddy coupe de ville. he has since made it into a roadster and drives it still . it was built in 1990 (My motor also)
    Then his youngest son Darren did a 56 GMC and I did a hopped up 455 for it. it was featured in Canadian Clasics last month but they inadvetantly called it a 55. Someone may have the magazine. It is the Corvette yellow truck.
    Then Jake V did a 57 caddy and called me for yet another 455 hop up. They are a good strong engine, make excellamt power and give zero nichts nada trouble. I prefer the 455 over the 350 personally. It is just a lot tougher . It is i believe the highest torque production engine at 500 FT lb in stock trim. It is a very practical engine for Hot Rod use and doesnt get the credit it deserves. I am a Mopar man so if i tell you this it is true not GM Prejudice.I am surprised there are not more of them out there.
    Don
  22. Big Olds Dog
    Big Olds Dog
    Hey hip check out www.442.com they might have some info for you
  23. ***Area-51***
    ***Area-51***
    from Ohio
    hip, used olds parts are still plentiful ...experienced olds guys stay away from that place
    a lotta cool rides here that are olds pwrd, glad to see em
    big olds motors are a lotta bag for the buck, all that torque sure puts a smile on my face
    heres a few websites to check if your into olds performance or need performance parts
    oldsperformanceproducts.com
    dickmillerracing.com
    rocketracingperformance.com
    mjperformance.com
    fcrperformance.com
    members.aol.com/gregsperformance/
    btrperformance.com
  24. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    425 in the Cutlass
    455in the other cutlass
    455 in the starfire
    3 more 455's as "spares":D
  25. 29AROD
    29AROD
    got a question for ya.
    i have decided after reading this post to run the 455 olds on my 30 coupe. i already have a 40 ford rear for the car, brakes all done wheels i want to run. will this rear handle the power form the big block. Seems to me that it would.... once. then i would be replacing it . any help would be great
    thanks
    29arod
  26. Ghostrdr
    Ghostrdr
    from Missouri
    ^bet that gets good traction and pulls the wheels off the ground up front. Color me impressed Kanaka
  27. ***Area-51***
    ***Area-51***
    from Ohio
    29AROD.....not sure how much power a 40 ford rear can handle , might not handle it especially if you have a heavy foot....might make an interesting new thread...
  28. rainh8r
    rainh8r
    I'd be thinking of a '57/64 Olds rear if you want to keep it old Olds. I've seen '40 rears go away with stock 283's.
  29. jsteph
    jsteph
    from phoenix az
    what do you think about a dual quad intake for a 455 and maybe switching from J heads to something better like C and putting in a thumpr cam from comp cams and I dead thouhgt knowledge any one have any of those parts like old school oldmobile valve covers
  30. spikeshotrods
    spikeshotrods
    Here's mine,
    It's a .40 over, 1971 455, XE294 Comp Cam, Iron G heads 2.07 intake/1.71 exhaust valves, a little port work, 200R4 trans, 3500 stall, 9" converter, 3.73 rear.......11.69 ET @ 112 MPH....... I believe I have about 4 more tenths I can get out of this current set up with some jetting and timing experimenting. It ran 12.49 ET @ 106 MPH with my last motor a bone stock 1976 low compression, J headed 455 with a 1969 grind, W31 cam, 232 @50 - 474 lift on 114 lobe centers. I love my Olds powered Chevy and will never go back to the "Dark Side":D.............Spike
