Steel Pipe A-Frame Engine Hoist: How To?
Discussion in 'The Hokey Ass Message Board' started by junquewerkz, Feb 19, 2004.
  1. LarzBahrs
    LarzBahrs
    from Sacramento
  2. pasadenahotrod
    pasadenahotrod
    from Texas
    I've used reinforced ceiling joists for years but have acquired a nice setup of pallet racking. With a 4X6 across the middle it holds up fine to the SBCs and bangers I've pulled. Wouldn't be afraid to pull a big block either.
  3. Deuce Daddy Don
    Deuce Daddy Don
    Don't be fooled by being "Chinsey", you go off in that EMT direction & you are gonna get hurt!!!--------Step up to reality & build a sturdy one out of .120 steel tube & gusseting angle pcs., make the top out of 2x3x.080 wall. If you want it portable, figure bolt up flanges!!-----------Don
  4. mgermca
    mgermca
    OK, maybe not the most inexpensive route but I thought I'd post it for inspiration value. This is a knock-downable aluminum version used by one of the Formula Continental teams at Watkins Glen last weekend. Pretty, no?
    Second shot is of the result when we tried to use a standard 2 ton asian cherry picker to move a Bridgeport mill. First lift to a height of 1 inch to get it off of the pallet went well, it failed on attempting the second lift to 1/4" to reposition it on the floor.
    Whatever material you make it of, just be sure to fully triangulate it, have a healthy respect for the force of gravity and don't forget to jump out of the way if it starts to fail! :D
  5. matt 3083
    matt 3083
    from Tucson, Az
    Don't even think of using a swing set. I know
    a lot of old timers will tell you that that's the
    way they did it. Ask how many wound up in the
    hospital. I had a friend try it, got the engine up
    and the set collapsed. Lucky no one was under
    it. Did a real number on the front sheet metal.
    I and a few others have never let him forget.
  6. GlenC
    GlenC
    Several years ago I scrounged a few lengths of fire sprinkler tubing off a demolition site. It was at least 2" in diameter and 1/4" wall, We cobbled together an engine hoist out of it using rope and chain to hold it together at the top, and it worked a treat. The tubing was free for the taking too.
    Cheers, Glen.
  7. plym49
    plym49
    from Earth
    Dude, you don't move a Bridgeport with a cherry picker! You move it with a long pinch bar. I have moved several by myself this way, including onto and off of trailers.
  8. mgermca
    mgermca
    Thanks, I guess I should have clarified a little more. The machine had been moved while it was on the pallet with a pallet jigger with no problems. We used the 'picker for lifting only to pull the pallet out from under it.
    Once the cherry picker was noodled on the second lift to 1/4", we ultimately used a 6' bar to pry against the wall to slide it on the shop floor.
    I guess the point I was trying to make was to be careful, even with a "2 ton" rated cherry picker, you cannot ***ume that it has the ability to safely lift its rated capacity.
  9. Jay Rush
    Jay Rush
    We used our swing set to remove a font end loader off our tractor but my dad was a pipe fitter and built or swing set out of 4 inch schedule 40 pipe it was stout
  10. Only in the better neighborhoods.
  11. plym49
    plym49
    from Earth
    Yeah, I was basically busting your balls.
  12. gearjam1
    gearjam1
    I was happy to find these posts. I have lots of s**** in the back yard, and a lifted truck w/swampers that I have to pull the motor out of... My cherry picker won't lift the motor high enough to clear the engine bay. Look like I'll be doing some welding this weekend. :)
  13. oldcarfart
    oldcarfart
    Harbor Freight and Northern Tool have versions starting @ $200.00 USD
  14. bobss396
    bobss396
    I actually did use an old garbage picked swing set once in a pinch. Slid a big diameter steel fence pipe through the top bar, shored it up with two 4 x 4 posts and car rims under the legs to get more height. It worked great for the one-time use. It was thrown out right after.
    Bob
