Ok, who has quad headlights on their Model A..etc..pics??
Discussion in 'The Hokey Ass Message Board' started by bradberry00, Mar 14, 2005.
  1. bradberry00
    bradberry00
    Ok im still planning out all the stylings of my "A"...i'm kind of thinking Quad headlights but without a custom fibergl*** grille/headlight combo but just a clean look with a 32 grille and some cool lights....any pics for inspiration? or ideas what cars i should look at for parts?
    here is my drawing with the usual headlights but would like something fresh and different...
  2. Marko
    Marko
    My thoughts would be to augment "normal" headights on stands with a couple of close mounted lights (clear or yellow) close togeather on spreader bar. The quad mounted headlights I've seen seem to add a lot of visual bulk to an otherwise clean nose. Maybe a quad set of the new, small projector beams might be small/sleek enough to be slick. Good luck on it!
  3. The37Kid
    The37Kid
    I don't see any unusual headlights, I do like the looks of the twin headers, and reversed door hinges.
  4. topdeadcenter
    topdeadcenter
    Check your late 50's little pages. (Edit:October of 1958 Rod and Custom. The ad is on page 5. The install story is on page 70) There was a company that was selling Quad headlight stands for your "early ford".... It was a cast piece on each side that instead of just a flatspot on top, it made a "T".
    There has to be some in someones collection. I personally think they look great! Very cool 58-60 look...
    Mike
  5. Kinky6
    Kinky6
    I dunno, I don't think that quad headlights are an improvement for a lot of rods or customs that didn't come with them from the factory - sort of like putting square headlights on a '40 Ford. Sometimes changing the look is simply changing the look, without improving it.
    And canted quads, well they are the harlequin gl***es of the automotive world. They were a fad for a while, and they definitely don't look good on everybody.
    That's not to say that it don't always work; the "Little Duece Coupe" of the albumn fame is one example that does because it is part of a coherant look, instead of something just stuck on there. I like the look that Marko described, to use Zibo's RPU as an example.
    Later, :cool:
  6. scarylarry
    scarylarry
    At the risk of sounding like a total dumb*** this morning, I've seen a big early 60's Chrysler??? maybe??? at the junkyard that the front end was "scooped" out and the headlights sat in there. Chrome headlights connected together and have a cool fluted edge around the front. Anybody have a clue of what the hell I'm talking about? They might look cool on a nerf bar, at least different.
  7. rusty210
    rusty210
  8. GO-rilla
    GO-rilla
    As long as they ain't them square ones it whould be ok.
  9. Kustm52
    Kustm52
    This the ones you thinking about? '61 Chrylsler Imperial.....
    Brian
  10. scarylarry
    scarylarry
    Yep, thanks Kustm52.
  11. DrJ
    DrJ
    Cal Custom probably is the one that sold the quad stands. They had something like them on some big trucks too, maybe stands for them are available, places like JC Whitney, Speedway probably still have themon their shelves even if they aren't in the catalogs any more,
    First rod I remember with quads was George Barris' TwisterT http://www.barris.com/gallery_twistert.html
    If you mount some side by side, mount them even with the axle, otherwise the wheel/tire might hit them when turning if they are forward or behind the axle.
  12. tinyelvis
    tinyelvis
    Yep, here's mine! You can have them for $12,500 I'll throw in the rest of the car for free! :)
  13. leadsleadolds
    leadsleadolds
    What I think would look good is if you find some with the bigest amount of metal around the lense and slice off a bit and weld them together. Like conjoined twins. It would look like a W.
  14. Mutt
    Mutt
    Lee's used to sell the brackets back in the 50'-60's.
    Mutt
  15. bradberry00
    bradberry00
    thanks guys, it isnt set in stone that i am going to use quad lights. But, i wanted to see my options. I was also thinking about some mid 30's bullet headlights.
  16. bradberry00
    bradberry00
    just noticed that old catalog page....$22.50 for a dropped axle!!
  17. abe lugo
    abe lugo
    Bradberry,
    just add a zero to the price and you make up for inflation and it's about right.
  18. Mutt
    Mutt
    That was 1958 - minumum wage was about .50 an hour.
    Mutt
  19. Plowboy
    Plowboy
    I've been looking for a set too.
    Let me know if you find anyone who still sells them!
  20. yngrodder
    yngrodder
    Not sure if this is what your looking for but this is what My coupe has for headlights. the headlights are 5 1/2 outside bulb and 4 inch inside bulbs the small ones are Guides 2004A
