Super t 10 Good Deal???
Discussion in 'The Hokey Ass Message Board' started by gear27, Jan 31, 2011.
  1. gear27
    gear27
    How does this sound Super t10 Nodular Iron Case $250.00 but it pops out of third should I p*** or grab it???
    27
  2. 65COMET
    65COMET
    If it will work for you it is a good deal.It probably needs synchros and freshening.They are fairly strong transmissions. ROY.
  3. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    id grab it.
    Neighbor sold a good one for $600
  4. Grab it if you can rebuild it. There are a few things to looks for. If its a 82-84 F body trans, the rear trans mount is at an angle for those cars. You would have to make a custom trans crossmember to match the angle. If its from an 80-81 F-body, it will have a standard trans mount. It also will be the 3.42 1st gear, the weakest gear set. I think its rated for 275 ft-lbs but I would have to check.
    Try to get the yoke with it since it should be the large TH400 yoke. The factory shifters are junk - go with a hurst. It should take a 26 spline clutch.
    Parts are not too expensive for a standard rebuild, but most shops really gouge you on the labour. The rebuild kit is about $150-200, and usually at least another $500 for labour. If it needs gears or shift forks, watch out - they are pretty pricey. I have a friend who has a trans shop who rebuilds these transmissions pretty cheap. In good usable shape, these transmissions usually get $500-600.
    I am in toronto - if you don't want it, I will grab it :p I have this exact trans in my 67' Camaro with its little 230ci six. The deep first gear makes it pretty peppy with the 3.08 rear gears.
  5. Fast67VelleN2O
    Fast67VelleN2O
    If it pops out of gear the gear will probably need to be replaced due to worn engagement teeth.
  6. cheap1
    cheap1
    If you don't buy it I will!
  7. Hi!
    Hi!
    from SoCal
    If its a true Super T10 grab it, they can be hammerd on better than most muncies do to the cast iron case and the gears. Make sure its not just a cast iron low horse borg.
  8. U sure it's a Super T-10 and not just a plain-jane T-10?
    Supers had 26 clutch splines and big TH400 rear yokes.
  9. cheap1
    cheap1
    If it's a 904 case it's nodular iron. Also, the number of rings on the input shaft indicate what gear set is in it. Mine has the two ring input which is a 2:64 first gear ratio. I've hammered on it pretty good and no problems yet :D. Also, an iron mid-plate will help in the strength department as well.
  10. Paid $500.00 for mine....working fine though.
  11. gear27
    gear27
    Thanks for all the help!!
    27
