Which crossmember to use for AV8
Discussion in 'The Hokey Ass Message Board' started by 13, Feb 1, 2011.
  1. 13
    13
    from Sultan, WA
    Okay, I'm sure this question has already been asked, and yes I did try to search, with not much luck. So since everyone and his brother wants the '32 k-member, are there any 2nd choices? I am doing a typical AV8 build with '51 8BA motor w/ 3-speed trans, '48 rear axle :eek:
  2. JimA
    JimA
    Please specify- front, center or rear.
  3. Atwater Mike
    Atwater Mike
    He said "K-Member". (that's center)
  4. 13
    13
    from Sultan, WA
    I've corrected the post with updated info. Sorry!
  5. JimA
    JimA
    He edited after I asked.
  6. young'n'poor
    young'n'poor
    from Anoka. MN
    Can I ask why you don't want to use the 32 k member?
  7. 13
    13
    from Sultan, WA
    Money of course, and availability
  8. lugnutz9032
    lugnutz9032
    from Palatka,Fl
    Late F-1 / early F-100 if useing an early 3 speed. As stated it has provisions for early pedal set up and makes a good basis for a homebrewed "K-member" by adding some reinforcment.
  9. 13
    13
    from Sultan, WA
    I don't think it's an early 3-speed, it mates to a steel bellhousing separate from the motor. Or would that be considered early? :confused: Also what years F1/F100 are you speaking of? Remember, I'm as green as the gr*** on your lawn
  10. Corn coupe
    Corn coupe
    from CZ
    we used the original and fabricated it into a 'K' member.
    Probably the most cost effective if you've some steel and a bit of time.
  11. LSGUN
    LSGUN
    from TX
    Look up Chris' thread on his AV8 roadster build, I believe he shows how he used an F-1 crossmember.
  12. young'n'poor
    young'n'poor
    from Anoka. MN
    Vern tardel makes and sells 32 style k members that are made to fit a rails with no modification. I'm not sure on price though.
  13. lugnutz9032
    lugnutz9032
    from Palatka,Fl
    Sounds like a later ****** as my '40 "side shift" has a built in bellhousing. This is my first build (T on A rails,early caddy,etc) so I'm probably still green around the edges when it comes to this stuff.:D '52-'53 is when I THINK they changed from F-1 to F-100. Anything from late '40s to mid '50s should work.
  14. 13
    13
    from Sultan, WA
    $475.00
  15. my2nd40
    my2nd40
    from Tennessee
    That's a sweet looking ch***is.......more pictures please!
  16. lugnutz9032
    lugnutz9032
    from Palatka,Fl
    Yeah,what he said.
  17. need louvers ?
    need louvers ?
    Being that he is from England, I would have to gues that it is the trick copper plated steel stuff that they all run over there. It would be nice to have that available here in the states.
  18. Shaggy
    Shaggy
    from Sultan, WA
    if it is solid mtd like it is, there would be nothing wrong with it in my opinion
    As for crossmembers there is a semi cheap 32 K in maple valley, either on here or Craigslist, but you might be able to get by with any ford crossmember, with some work, i have a 37 X-member in my 32 frame, and anouther unmodified one you can stop by and measure, but i want to keep it for future projects.
    What trans are you going?
  19. 13
    13
    from Sultan, WA
    The trans is a 51 3-speed, I'll try to stop by this weekend. Thanks ****gy one...
  20. Mart
    Mart
    If I had a choice I'd use some sort of x-member, like a 34 or similar.
    Very strong and stiffens the frame well. The 32 style k-member really limits you to an early ford 3 speed gearbox. These days it's nice to run some sort of overdrive box. Using a 32 k-member pretty well rules that out.
    Mart.
  21. 13
    13
    from Sultan, WA
    Hmmm, well my trans is a 3-speed 1949-61 style, where the bellhousing is separate from the 8BA motor. I did not know that the 32 would limit the trans options
  22. 13
    13
    from Sultan, WA
    I suppose it will be to my advantage, to wait until I have installed the motor & trans to see what'll work best. You're right, so many options!
