Hot Rods Delta performance parts?
Discussion in 'The Hokey Ass Message Board' started by oldtin, Nov 17, 2009.
  1. oldtin
    oldtin
    I've been checking out everything I can find that involves old supercharger setups.
    I recently stumbled on to some images of a blower front cover and a timing cover/ crank support that have the name "DELTA"
    cast into them.
    Anyone got any info, history, or pictures of DELTA performance parts or blower parts?
    Any other odd duck blower set ups?
  2. Try searching for "Delta Machine Co."
  3. oldtin
    oldtin
  4. PBRmeASAP
    PBRmeASAP
    saw that too, but since the idler pulley is fixed, gotta make sure it will fit.
    Love Magnesium stuff
  5. oldtin
    oldtin
    PBRmeASAP, The idler isn't fixed, it rotates around the mounting boss/post to adjust the belt tension.
    Here is a little beter picture of the housing and adjuster.
  6. PBRmeASAP
    PBRmeASAP
    but the length of it and the length of the snout would make a difference. Size of the blower 4-71, 6-71, or 8-71 will effect the snouth length.
  7. oldtin
    oldtin
    I get it now...........brain fade on my part. The snout length would make a difference.
    Time frame of the part would probably make the part for a 4-71 or a 6-71, guessing 6-71. But the length would still vary from one engine to another.
  8. classic gary
    classic gary
    got this a while ago, Delta front cover, idler arm/pulley, blower pulley drive adapter and the crank hub and pulley. also a Delta rear cover. The front and rear bearing plates are "GT".
  9. Deuces
    Deuces
    Spammer reported!!
  10. classic gary
    classic gary
  11. 38FLATTIE
    38FLATTIE
    from Colorado
    What? Why? Who?
    Maybe too much eggnog?;)
  12. The Brudwich
    The Brudwich
    I'm guessing he posted in the wrong thread, there is NO reason for this thread to be closed.
  13. oldtin
    oldtin
    Gary, you wouldn't have any detail shots of the upper pulley attachment or the drive coupling under the front cover? The different ways the early drives transfered the power from the upper pulley to the blower iterests me, there was a lot less commonality between manufacturers than there is now.
  14. classic gary
    classic gary
    gimme a couple of days. i'm geting my new motor ready to fire for the first time. THAT TAKES THE NUMBER ONE SPOT ON MY LIST OF THINGS TO DO RIGHT NOW !!! :):)
  15. classic gary
    classic gary
    ok here are some pictures of the Delta drive.
  16. classic gary
    classic gary
    now for a question...are these bolts left or right hand thread ?
  17. landseaandair
    landseaandair
    from phoenix
    Correct, as in they are removed going counter clockwise. Good chance they have some Lock***e on them.
    Edit: oops right hand.
  18. Chucky
    Chucky
    I got this one that is a odd duck - I've been told "pete's engineering"?
    Mag pulleys - Cragar manifold - it's cool......
  19. landseaandair
    landseaandair
    from phoenix
    Yep, that looks like a Pete's Eng. drive. I'd think it should say Pete's between the ribs on the idler arm and have a riveted tag on top. They looked similar to Delta but had a fixed pulley hub.
  20. Piston Farmer
    Piston Farmer
    Theres a Delta Cam in tacoma wa, but dont think they do anything but cams
  21. oldtin
    oldtin
    Gary, thanks for posting up the detailed shots of your drive, that answers a lot of questions I had.
  22. classic gary
    classic gary
    that drive setup couldn't be much simpler could it.............
  23. oldtin
    oldtin
    Its a whole lot simpler and easier to replicate than the modern splined two piece couplers.
  24. classic gary
    classic gary
    well, if you do, spare parts are good to have !! and maybe with the "back the motor up" nut as a part of the shaft, not welded on as mine is....
  25. classic gary
    classic gary
  26. Weasel
    Weasel
    I don't know if this may be a clue, but here is Howard Johansen's personal jacket - one of allegedly about four made that had 'Delta Machine' embroidered on them.
  27. classic gary
    classic gary
    and i'd bet you wouldn't want to sell that jacket.........
  28. classic gary
    classic gary
    anybody care if i start posting pics of cars with delta blower drives on them?
    hmm ,i guess not, :)
  29. classic gary
    classic gary
    a small block chevy powered Fiat altered. DELTA drive.
  30. classic gary
    classic gary
    from a "Hero Parts" MOON Equipment Catalog dtd 1965:
