Projects would it be gay if I said I love my little hand held sandblaster
Discussion in 'The Hokey Ass Message Board' started by steel rebel, Feb 4, 2011.
  1. 21tat
    21tat
    It's only gay if blast your rat rod with it.
  2. steel rebel
    steel rebel
    Thanks guys just what I've COME to expect from you.
  3. falcongeorge
    falcongeorge
    from BC
    He said come...:D Infantile, purile, vulgar...theres times when I REALLY love this place!
  4. ClayMart
    ClayMart
    OK...Technically that's not gay, though I'm sure there is a word for what it's called. But I'm going to have to search the Urban Dictionary site to find out what it is. :D
  5. carcrazyjohn
    carcrazyjohn
    from trevose pa
    All depends where you stick it .The secret is we all know there great and have one .Shhhhhhhhhh
  6. Kerrynzl
    Kerrynzl
    Sorry, I didn't want too undermine your answer, but to share a simple solution that doesn't require any formulas.
    I used to race a MK1 Lotus Cortina that had no carpets or sound/heat insulation. [the heat was unbearable at the end of the race]
    It had plastic side windows, and the only ventilation was a 8" hole cut in one window [ for hand signals ]
    I won a few club races in that, in adverse weather purely because I had the advantage of visibility [ Race Cars fog up really BAD ]
    Another trick I've seen is to cut a potato in 1/2 and polish the windows, but I prefer the 2 in 1 shampoo in a bottle
    Try it! it works amazingly well, I'll never buy anti-fog again.
  7. elcamino65
    elcamino65
    from washington
    That thing looks pretty sweet how often do you need to refil it? I think i need to order one.
  8. 29pu
    29pu
    steel rebel,you have to admit some of these post are funny and no it`s not gay.i have one too so i can`t be.
  9. VonDad
    VonDad
    Make sure you don't breathe the dust. Silicosis is some very bad stuff. If you can figure out a way to make an air fed respirator it will help save your health in the long run.
    As for being gay using it.. Only if you think its FABULOUS!
    one ole farts opinion anyway
    have fun
    VonDad
  10. kenseth17
    kenseth17
    If you love your sandblaster and it turns you on, that may make you a mechaphiliac. Like this dude. http://www.telegraph.co.uk/news/new...899/Man-admits-having-***-with-1000-cars.html
    Not necessarily gay (the dude in the story is only turned on by machines, not men or women), but imo probably even more disturbing then being a rump ranger. I swear there was and episode of 1000 ways to die involving a mechaphiliac. Wait it was manswers. Claim there are an estimated 14,000 mechaphiliacs in the u.s. Someone in love with a sanblaster probably likes it rough, ouch.
    I have to sandblast big city trucks at work often, with a pile of sheet blaster, in a room with hardly no lights work and freezing cold, cause no heat in there. Lets just say I absolutely hate sandblasting.
    I bought one of the pressure feed sandblaster from harbor freight a few years back for home. Only used a few times. Thing surely didn't love me. When I ***embled it and hooked it up for the first time, the water trap regulator exploded where the poor threads barely screw together as the tank built up some pressure. Had I been nearer to it when it happened, very likely would be a goner now. The blasting valve that comes with the thing is a real pile too. That deadly regulator is now in the trash where it belongs and one of my water traps and regulators that have worked with no problems for probably 20 years for painting now is on it.
  11. falcongeorge
    falcongeorge
    from BC
  12. steel rebel
    steel rebel
    Thanks guys I love the hamb. Oh god I've said love twice in one day I MUST BE GAY! Not that there is anything wrong with that.
    One thing, the sand doesn't last too long in the hopper but not much problem.
    If you have a standard home compressor you'll have to wait for it to build pressure between blasts.
    Good idea about the trash bag to extend the sandblast box but it is still so restrictive.
  13. Deuces
    Deuces
    I got one of those portable blasters somewhere in the garage... I haven't used it in years....
  14. 383 240z
    383 240z
    I got that same little blaster. I fill it with soda to clean old carbs before they go in the Chem-Dip. Works great, haven't run any other media thru it yet was gonna use it to blast the little areas (belt lines, hinge recesses ect) on my '40. Keith
  15. thecockeyedwallaby
    thecockeyedwallaby
    from Kelowna
    Only if you said it with a lithp.
  16. mixedupamx
    mixedupamx
    when i used to scuba dive we would spit in our masks and rub it around if we were diving in cold water to keep them from fogging.
  17. I have a small sandblaster and the only sand that will work in it is Silica sand. Beware,prolonged use can and will cause silicosis (black lung) the good news is that a paper dust mask will be fine to protect you.
  18. BOWTIE BROWN
    BOWTIE BROWN
    yeah they are !
  19. rick finch
    rick finch
    Glad you finally came out of the closet Gary.....feel better now?
  20. 3spd
    3spd
    I just blasted a carb using sugar with one of those, worked great even with my little 12gal air compressor. Excepts for the hopper mine is all metal, sure surprised me, I though the handle would be plastic.
    Ryland
  21. steel rebel
    steel rebel
    Rick I really enjoyed riding behind you on your scooter that day. Now we are both out.
    I love the hamb. There I've said it again.
  22. gibraltar72
    gibraltar72
    from Osseo Mi.
    I use a leetle blaster and a pressure pot I also had a double fogging problem as I wear gl***es. My solution cut a piece of heater hose put one end in your mouth other end in rear pants pocket. breathe through hose. You'll kill two birds you won't be breathing into mask you also won't be ****ing in the sand dust particles. just don't fart!
