Y-block 4 speed trans adapter
Discussion in 'The Hokey Ass Message Board' started by midcal48, Feb 6, 2011.
  1. midcal48
    midcal48
    from Hughson,CA
    I bought what i think is a 292 Y block and a sm420 granny 4 speed trans. My question is if that is some sort of adapter that mates the 292 to the 4 speed, and if it is an adapter can any other trans be used with that adapter? Thanks
  2. Mr48chev
    Unless you are planning on pulling a pretty good load I'd venture to say that old granny trans isn't what you want.
    That adapter looks a lot like this one on Ebay 300521617035
    You should be able to find a stock Y block bellhousing pretty easy for either a car or pickup with a three speed that will handle the regular three speeds or four speed car trans.
  3. 65COMET
    65COMET
    That looks like a serious piece! I don't think any p***enger or light truck trans will fit.I used a p***enger car bell housing on my 292 along with an early narrow bolt pattern T-10.The only mod was to nip about 1/4" off of the input shaft where it goes into the pilot bushing.I got the idea off of the y-block forum. ROY.
  4. budd
    budd
    i'm using a stock 3 speed bellhousing and a OD 4-speed from a granada.
  5. midcal48
    midcal48
    from Hughson,CA
    What kind of bellhousing is this?
  6. BLUECOLLARKUSTOMS
    BLUECOLLARKUSTOMS
    looks like a y-block truck bellhousing to me
  7. RAY With
    RAY With
    X2 what Bluecollarkustons says and the top pic is a set up you wont be needing for a street rod.
  8. JohnEvans
    JohnEvans
    from Phoenix AZ
    Not a SM 420 . Either a Warner T-9 or T-98.
  9. midcal48
    midcal48
    from Hughson,CA
    The motor and trans are going into a 1948 ford f-1. But im starting to rethink the 4 speed transmission. Can i use the other 4 speed truck bellhousing for any other transmissions? Thanks for all the help.
  10. Best thing if you are using a Y-block is to get the truck three speed bell, then you have a number of options including the T-5 five speed with a few mods. T-10 and early Toploader will fit the pattern with no mods.
  11. midcal48
    midcal48
    from Hughson,CA
    just got the numbers off the trans , on the drivers side the numbers are
    W G CO
    T 8 D-1A
    and on the p***enger side
    59T-7006
    N 10
    But it sounds like i need to source a three speed bell housing from a truck, cause i cant do much with the 4-speed bell housing that i have now.
    Does anyone know the years for the T-10 or Toploader? thanks
  12. hansde
    hansde
    from Texas
    I would be interested in that adapter if you don't use it and decide to sell it? Thanks, H
