Model A gurus, is a 28-29 w/s the same as a 30/31?
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Mar 16, 2005.
  1. Roothawg
    Roothawg
    This is on a sedan if it matters.
  2. Haystack
    Haystack
    from Wisconsin
    Yes they are interchangable.
  3. Roothawg
    Roothawg
  4. Murray or Briggs?
  5. briggs&strattonChev
    briggs&strattonChev
    dont try to impress us now tman...............
  6. alchemy
    alchemy
    No, they are not. I'm not an expert, but I do know they are different. I believe the main differences are the skirt are that goes under the dash rail, and the hinge on top.
    That being said, they may fit between years by swapping the hinges on top and grinding the skirt to eliminate interference.
  7. Roothawg
    Roothawg
    Hmmm. so they are different?
  8. joeycarpunk
    joeycarpunk
    from MN,USA
    Yes, but can be made to work.
  9. Jason455
    Jason455
    I used a 28-9 windshield frame on my 30 but I had to change the upper hinge. There may be other differences but it does work.
  10. GO-rilla
    GO-rilla
    Thanks Chris, Good looking out.
  11. Briggs, I could pick my nose and wow you.:D
