Projects 1957 Chevy Pickup
Discussion in 'The Hokey Ass Message Board' started by TaylorCrawford, Jul 6, 2010.
  1. J scow
    J scow
    from Seattle
    Awesome build. I just stayed 10 minutes late at work so I could read the whole thing. Nice truck!!!
  2. TaylorCrawford
    TaylorCrawford
    Thanks!
  3. MJW
    MJW
    from NJ
    1. PA. NJ. local HAMBERS group
    Taylor,
    Tell your dad to get to work and learn how to weld :). That door isn't too bad just looks like someone kicked the door (cow maybe). Finish stripping the bondo and take a good pict and the guys here will get you some good advice. Might not be too bad to fix.
    Looking good so far...Did you get the oil leak above the filter sorted?
    Mark
  4. TaylorCrawford
    TaylorCrawford
    I already chipped out the parts that were cracked and filled it in. Turns out bondo is kinda fun. And now I havnt touched that yetMy dad was tellin me what you said and I dont see what your talkin about...
  5. TaylorCrawford
    TaylorCrawford
    Oh ya and if anyones learnin to weld around here its me, not my dad! Haha.
  6. Red Ryder
    Red Ryder
    Don't feel bad about your door, mine are lots worse than that (Rust City)! I hope to be able to save mine with the help of some resin & fiberglass, but that remains to be seen. Maybe this coming summer?
  7. TaylorCrawford
    TaylorCrawford
    Ya I know. Now I have to paint it. Way to much bondo for bare metal...
  8. TaylorCrawford
    TaylorCrawford
    Today I tried to get my speedometer working and had some problems. The old speedo cable spun all the time, and looked like it worked, but the end was broken, so I went and got a new cable. I pulled the old one out and hooked up the new one without a problem. I backed out of my drive way and started to go down my street, and the speedo climbed up to 15MPH, and the needle dropped. It never came back up. So I turned around and tried re connecting it to the gauge cluster and tried again with no luck. I re connected it to the trans and made sure it was tight. I then tried with out the gauge cluster to see if the cable was spinning. It started spinning but once i got out of second at a lil higher speed it stopped. So I made sure it was connected tight a few more times and still had no luck. So Im stumped....
  9. chevpickup
    chevpickup
    from Australia
    things a fucking weapon - congrats!
  10. TaylorCrawford
    TaylorCrawford
    Thanks! Anyone wanna buy an original 57 Chevy pickup rearend? :D
  11. TaylorCrawford
    TaylorCrawford
    Pulled the old fenders off so I can start sanding the bed down and fixing some dings here and there. I have other fenders that are going on, and the old ones are for sale if anyone wants em. Looks goofy without fenders....
  12. TaylorCrawford
    TaylorCrawford
    Oh ya you can see the cool shiny new rear bumper now!
  13. TaylorCrawford
    TaylorCrawford
    Nothing major lateley, just lots of sanding and bondo work. Progress has slowed a bit because I got to school most of the week now.
    As of right now Im gonna hold off on paint. I was getting ready to paint it soon, but I decided I'll save that for later. Im just gonna nurse the engine an trans until summer when I start working full time again, then I'll do some work on the engine and swap out the trans for a 5 speed or the automatic I have layin around. STill havnt decided yet. Until then Im just gonna sand the whole thing down. I also have to cut out and re-weld a cab corner. Im gonna keep the fenderwell headers, but cut out the mufflers and run straight pipes with fish tails coming out the back. After then engne work and trans is done Id like to paint it, but I wanna find a new drivers side door. Anyone wanna trade a fedner or 2 for a door thats in decent shape?
  14. TaylorCrawford
    TaylorCrawford
    This is how she sits as of a few minutes ago. Ive been kind of tight on money so all I have been doing is sanding and bondo, haha. You can see the new fenders in the bed that will be going on soon. Just gotta sand em down. Gotta get rid of the old ones too. Anyone wanna buy some orignal fenders? :D
    Note all the bare metal...
    Still driving the piss out of her!
  15. TaylorCrawford
    TaylorCrawford
    Im thinking I wanna put 2" drop shackles in the back. Whos done this? More info please! :D
  16. 57 3100
    57 3100
    taylor, i have used a set 2" drop shackles when i first lowered my 57. used them in conjunction with pulling 4 of the 7 leafs. (now my rear is flipped).
    the shackles are a very easy swap. here is where i got mine from.
    good luck...
    http://www.brotherstrucks.com/prodinfo.asp?number=RES5559
    leonard
  17. TaylorCrawford
    TaylorCrawford
    Okay thanks. Im running 4" drop mono leafs, Ive heard I may have to C-notch my frame if I go any lower. Is this true?
  18. terd ferguson
    terd ferguson
    I'm running 4" drop monoleaves along with 2" drop shackles and new shocks. I have about an inch of travel. I don't hit the frame unless I'm hauling something heavy, like an engine.
  19. xhotrodder
    xhotrodder
    Sweet, the 55-57 Chevy truck is one of my favorite vehicles. Good luck on your build.
  20. TaylorCrawford
    TaylorCrawford
    Is this what your using?
    http://www.brotherstrucks.com/prodin...number=RES5559
  21. 57 3100
    57 3100
    taylor,
    right now all i am running is the flipped rear and original shackles. this gives me right at 1" of clearance. with the newer shocks i have, it dont bottom out unless its a big dip in the road.
    when i flipped the rear and put all the leafs back in, it was right on the frame, thats why i put the original shackles back in. that gave me the 1" clearance i now have of travel.
    too bad i already got rid of my dropped shackles, i could have sent them to you.
    leonard
  22. terd ferguson
    terd ferguson
  23. TaylorCrawford
    TaylorCrawford
    No worries, just wanted to know if you were using something simalar. Thanks!
  24. TaylorCrawford
    TaylorCrawford
    Right now Im running the mono leafs with the axel mounted under, so I should be fine right?
  25. 57 3100
    57 3100
    i think TERD is running that setup, so you should be real fine.
    i dont have nay experience with mono's....
    you got a cool truck, .... get it down man. LOL.
    leonard
  26. TaylorCrawford
    TaylorCrawford
    Rad! Gonna be a real ass dragger now! I think Im gonna add another leaf up front, I pulled 3 and I smack the axel on the frame a lot. Not fun...
  27. 57 3100
    57 3100
    yea, i got 3 pulled from the front also. i put a strip of old rubber boat trailer mud flap onto the frame, so at least it aint metal to metal contact....
    have fun man.
    leonard
  28. TaylorCrawford
    TaylorCrawford
    Hmm..is it really that bad to be slapping the axel? I may just do that.
  29. 57 3100
    57 3100
    dont think it will really hurt anything, but it sounds a lot better with the 3/16" thick rubber in there...
    leonard
  30. TaylorCrawford
    TaylorCrawford
    Blew out another header gasket today...
