Projects Got a welder needed a cart - The zero $$ welding cart
Discussion in 'The Hokey Ass Message Board' started by daddy_o's_diner, Feb 8, 2011.
  1. Got a cheap 120v mig and needed a cart for it. Started looking around and found this
    and this
    and turn it into this
    Total cost zero dollars
    It's still a little rough , but works well. It is much more stable than it looks. The weight of the tank more than offsets the weight of the welder. I plan to add another chain for the tank and to hold a commercial fire extinguisher that will sit next to the tank. I'll tack on a couple of hooks for my helmet, gloves, and welders pliers. My buddy is a commercial blaster. I'll let him hit it and then give it a coat of paint.
    I have to get my regulator mounted and convert the welder over to gas. I did this with some .35 flux core. I haven't welded in years and it shows. This was good practice.
    sorry for not flipping the pics - couldn't right now.
  2. bobscogin
    bobscogin
    No problem. Can't see 'em anyway. :D
  3. Ravenwood
    Ravenwood
    from Texas
    Spent zero dollars. Got zero (invisible) cart. Sounds fair.
  4. No pics?? Really!?
    They show on my PC and my phone. Wtf
  5. DD COOPMAN
    DD COOPMAN
    No pics here, too! Would like to see it. DD
  6. flatheadpete
    flatheadpete
    from Burton, MI
    Take it inside outta the snow. The white paint really camouflages it.
  7. Buck Sharp
    Buck Sharp
    from nebraska
    Another shopping cart?
  8. Stu D Baker
    Stu D Baker
    from Illinois
    No pictures in Illinois. Stu
  9. Sir Woosh
    Sir Woosh
    No pics here either.................
  10. TIN INDIAN MAN
    TIN INDIAN MAN
    None here in the Southlands...................
  11. Try this:
    One old hand dolly
    S**** steel (old bedframe??)
    End result
  12. handyandy289
    handyandy289
    from Georgia
    Be careful trying to weld old bed frames. They tend to be very brittle and will crack next to the weld. Ask me how I know.
  13. Black Primer
    Black Primer
    What happens when you have to change a bottle?
  14. T-rev
    T-rev
  15. What happens when the bottle gets low?
  16. DD COOPMAN
    DD COOPMAN
    Pics now, loud and clear. Nice, simple cart...I like! Thanx daddy o. DD
  17. You can't tell in the pic, but the weight of the welder is centered over the axle. The cart does not tip over when the bottle is removed. It is very stable once the bottle is on. Also not shown is the support from the outer edge of the shelf to the center of the cart.
  18. KrisKustomPaint
    KrisKustomPaint
    I think that chain is a bit high for that bottle.
  19. 56sedandelivery
    56sedandelivery
    Go to a Goodwill type of store, and buy a very long belt to use in securing the bottle to the uprights. I used an old audio-visual cart from a former employer (tossed out), and all my welders are on it; just have to make a tank holder for the oxy/acet cylinders. Recycle and reuse works. Butch/56sedandelivery.
