merc crank
Discussion in 'The Hokey Ass Message Board' started by threewindaguy, Feb 10, 2011.
  1. threewindaguy
    threewindaguy
    I think i ran onto a 4"merc crank and want to positively be able to i.d. it.It has 2" wide counter weights and a 7/8 hole in the rear counter weight.Also on the end of each counter weight it says 1CM, could that mean Canadien Merc?Any help appreciated.:D
  2. briggs&strattonChev
    briggs&strattonChev
  3. Bruce Lancaster
    Bruce Lancaster
    1CM means it is a '51-53 (American) crank with pilot hole in back for the front of a FordoMercoMatic...will be fine with stick too.
    Earlier cranks not numbered, so:
    First check to see 2 holes in each rod throw, cleanout plugs. Test will give wrong answer it it's an early crank!
    Then lay a 6" rule across front counterweight at widest point...Ford less than 6, Merc a bit more.
    Next...measure rod journals to see if it is a stock 4" Merc or Merc with small journals offset ground to make it 4 1/8. Necessary because need different pistons.
    Apparently there are variations (rare) out there, so cleanout size is perhaps not 100% certain ID.
  4. If it has 7/16" clean out holes it's 3 3/4" stroke, if it has 5/8" clean out holes it's a 4" stroke.
  5. Bruce Lancaster
    Bruce Lancaster
    Except...
    There are exceptions, Merc cranks with Ford sized cleanouts. They are allegedly Canadian production...
    Measuring the weight seems to be reliable, and if you have a wall, a yardstick, and several chunks of 2X4 you can measure actual stroke, crudely but well enough to tell the difference. The 1CM crank is of course a certainty as a Merc, but you would want to investigate the possibility of the common offset grind.
  6. threewindaguy
    threewindaguy
    Would you give a clarificlation of a cleanout hole?There is a 7/8 hole in the rear counter weight that is perpendicular to crank centerline,is that a 'cleanout hole'?It appears to be a forged crank.
  7. The "Clean out" hole is the one with a small soft plug in the end of the rod journal.
