i have a 65 c4 behind my 68 inline six in the 62 falcon. here recently the front seal blew back in december and i changed that out at the beginning of january. well, the front seal i guess blew again, leakin worse than before! i'm starting to get fed up with this mess. had the car at a shop to inspect it out, and they talked to a couple of other trans shops and they suspect that the torque converter is out. was hoping you guys might have an idea what the issue might be. she's spittin fluid out like she's niagra falls. the transmission was rebuilt back in may of last year too. any ideas will help out greatly! gettin tired of not drivin her everyday.
H3O Sounds like you either spun a pump bushing or have a crack in the torque convertor. I would suspect the pump bushing first. any way trans will have to come out to find out. Also check for a bent flywheel, that will also take a bushing out. kcl
