Wiring question
Discussion in 'The Hokey Ass Message Board' started by dynaflash, Feb 11, 2011.
  1. dynaflash
    dynaflash
    from South
    I am installing a It's A Snap wire harness. So far, I guess it has been a snap, but now I have a problem and they are closed for vacation ?
    The indicator light for the high beams is on all the time. It has 11 volts to it when on High and 6 when on low. I unplugged one headlight to see if the wires were crossed and it was feeding back through the bulb, but it is still the same.
    Any ideas? Where do I look for this?
    THANKS in advance for any help.
  2. cide1
    cide1
    Its Chinese new year....must be their vacation. (I did buy a Helix IFS, and it's good stuff, but it is chinese).
  3. Gator
    Gator
    from Statham Ga
    Sounds like a poor ground somewhere in the circuit.
  4. x2 on a poor ground try grounding the headlights back to ground and see if it cures the problem
  5. Sounds like it may be a bad hi beam switch. Are the hi and lo beams working correctly? Disconnect the switch (take it out of the circuit) and jump a wire from the pwr wire to lo, and then pwr to hi and see what the indicator lite does
  6. squirrel
    check grounds at the cluster and at both headlights.
  7. elcamino65
    elcamino65
    from washington
    as said check the grounds. but i like what groucho said remove the dimmer and run a jump to try and eliminate that problem
  8. joe_padavano
    joe_padavano
    ONE of the headlights has the ground and low beam wires swapped in the connector. What's happening is that with the dimmer switch in the low beam position, these swapped wires are grounding the high beam filament for that bulb through the high beam indicator bulb. Unplug all the headlights and the indicator should go off. If it doesn't you have a bad dimmer switch. If it does go off, plug the headlights back in one at at time and see which one causes the indicator to illuminate with the dimmer in low beam. That's the one with the wires swapped.
  9. dynaflash
    dynaflash
    from South
    Thanks so much everyone. I will be in the shop early tomorrow and will find the issue for sure. THANKS Again............to all
  10. Headlights ground through a SIDE connector, NOT the center. It's kinda counter-intuitive, and caught me out the first time.
    It's my bet.
    Cosmo
  11. dynaflash
    dynaflash
    from South
    You my friend are a smart man.....That is exactly what the issue was, THANKS SO MUCH!!
  12. Dirty Dug
    Dirty Dug
    Damn, if the Hamb isn't amazing! I was struggling with this issue for two nights, replaced the dimmer switch tonight with no improvement. Then I did a search and, BAM, I'm back in business. Thanks
  13. Dirty Dug
    Dirty Dug
    For the record the high beam is on the left, low beam on the bottom and ground on the right. Thanks.
