History 1940's newspapers in roadster door panels
Discussion in 'The Hokey Ass Message Board' started by Deuce Daddy Don, Feb 12, 2011.
  1. Deuce Daddy Don
    Deuce Daddy Don
    Back in the 40's, guys used to use plain ol' daily newspapers wadded up & stuffed inside all the door panels & deck lids, quarter panels etc. for sound deadning, especially in the roadsters.
    When building my '32 roadster in 1962, it was a flashback in time as I carefully extracted these tightly compressed pages of the L.A. Times & opened them up to read the old time dates from 1940 to 1947!
    Made sure ALL the paper was removed before visiting the body man.
    How about you guys?----Find simalar stuff in your panels?
    Later, found out that a good item for sound deadning was a water mixed black substance from 3M that was easily applied with an old paint brush, & used under all my body, fenders, running boards, gas tank, front splash pan with tremendous results now still there since 1962.
    This works great under the fenders to resist gravel & "Starbursts" from stones too.----------Don:D:D
  2. EMPEROR CHUCKYBOY
    EMPEROR CHUCKYBOY
    yes sir.... my RPU was a dragcar inthe 60s and when i got it i noticed newspapers in the door so i carefully took a bit off the roll and found that it was dated 1962 LA times so there it will stay! thats cool that you have the same! chuck
  3. turdytoo
    turdytoo
    I found 1950's Phoenix AZ newspapers in the trunk lid of my '32 3 window and a 1957 church bulletin in the pocket of my original '32 5 window.
  4. Dirty Dug
    Dirty Dug
    My '30 roadster had 1938 Pasadena newspapers in the doors, took forever to get them cleaned out. They were as dry as a popcorn fart.
  5. rusty1
    rusty1
    friend of mine bought a deuce roadster that the Ayala bros. in Cal. used to own; he got several garbage bags worth of 50"s newspapers out of the nooks and crannies.
  6. tommy
    tommy
    Pieces that I scanned from my 32 Roadster. The doors and the rumble lid are packed solid with the LA Times and the LA Mirror...Jan and February 1951. I left it all but these pieces to do***ent it as being an early So Cal hotrod. It's packed so tightly that you can only peel small pieces off. The cl***ified section had 2 1949 Mercury convertible ads for 1500 each. They were dealer ads.
    I almost had a heart attack when I found the "insulation" in the p*** door and immediately pulled the rest of the panels.
    Mine
  7. Deuce Daddy Don
    Deuce Daddy Don
    Hey! thats neat Tommy---Bet they were all "Yellowed" out too!!!!
  8. My 1940 Pontiac had an entire June 7 1944 NY newspaper rolled up under the front seat. Headline is the D-Day invasion. Still got it...
  9. tommy
    tommy
    Not as bad as you might think. The pieces wouldn't lay flat for a picture so I put them in the scanner to get a good copy. The doors had been painted a few times over the years.
    So it was not exposed to to light. I took a friend with me to look at it when I was buying it. He pulled me aside and said the doors are fibergl***!! Listen to the way that they shut.:eek: I triple checked and they were indeed steel. The interior door panel was card board with loop pile carpeting glued on. The newspaper does make a difference.
  10. Deuce Roadster
    Deuce Roadster
    My roadster had LA Times in the doors ...
    1946 dates.
    And a few coins ... all before 1940.
    ( photo taken at Limework's Open House { Aussie's Steve's place :D }... 2010 )
    Wishing something REAL ... BAD on the guy who stole AussieSteves 32 California license tags :eek: :mad: :(
  11. 345winder
    345winder
    off topic car,but back in my HS days(late80'searly 90's),my buddy bought a 69 camaro,started to get it ready to repaint,took off the vents in the door jamb area on those cars and found an early 7o's ******* mag some one stashed in there,
  12. No kiddin? I wonder who woulda stuffed old newspapers in those new Brookville doors?
  13. Dirty Dug
    Dirty Dug
    Hey, I went to a lot of trouble to find that newspaper.
  14. Deuce Daddy Don
    Deuce Daddy Don
    "I think we have a communication problem here"
  15. EMPEROR CHUCKYBOY
    EMPEROR CHUCKYBOY
    Hahahah i guess this very common.....
