I see a lot of these with 289-302-351w in them. What is everyone using for motor mounts? Is there a conversion motor mount available? If y'all could help it would be appreciated.
Welcome to the HAMB. Ive got a 55 with a 272 but others have done the SBF swap. Come join the 52-56 Ford car social group. Here's the link: http://www.jalopyjournal.com/forum/group.php?groupid=332
I used the Gear Head Cruiser Products engine swap kit to put a 351W in my 53' Customline. They have kits for your application, as well as transmission cross members for C-4/C-6. They are a little heavy on the pocket book $$, but are well made. It was a fairly simple installation, but mine having had a flat head cross member it required a rear sump pan and oil filter relocation kit. I dont think you will have to go through that with a 55'. Thank you for keeping a Ford in a Ford!-Jim
I've wanted one of these cars for as long as i can remember, but the one i bought came with an inline 6 and thats not going to cut it. Im wanting to put a 302 with a 5 speed in it.
I know a guy who did one in a '54 which I think is the same as '55. Used Off the Shelf 351W Stock Motor mounts & it bolts in Direct to the Orignal Frame mounts, Late Mustang Dual Sump Pan & pick up, Moved the Stock Trans cross member & used trans mount for whatever trans you are planing on using. Its a Very Easy swap without the use of High Dollar kits. Why does everyone relie on Kits ????
I am using stock Lincoln Mark VII engine mounts . You should come over to the 52 to 56 Ford Group . We have discussed that many times and you can get all the information over in the group and find out all the best places to get the parts you need for the swap . Stop on by and see what you think . There is a ton of informations just for your car in our group . We are very helpful for anything you might run into to get your car up and on the road . Retro Jim
I used a kit because my fab skills are not what they should be. I did'nt have the tools, equipment, or know how, to get myself out of any jams I may have found myself in. I was also in a hurry to get it on the road. -Jim
If you send me a pm with your email address I can send you build pics and part numbers and parts sources,you will be able to buy the engine and trans mounts right over the counter at Autozone or O'Reillys for about $75.I also moderate the 1952-56 Ford social group here,you will find some great guys and gals and tons of info to help out.We just learned Hedman has a header that is a EZ fit with zero mods.
I used Anchor motor mounts #2220 & 2221 on mine.worked great and only about $15.00 each.I had Gearheads motor mounts and didn't like them.
I'm thinking of putting a 351C I have in a I-6 1955 Customline Tudor. I can keep the Fordomatic or change to a T-85 O/D I have. What parts or adapters do I need? Thanks!
Need help on converting my 1953 Ford to a 302. Any ideas on transmissions as well. It has a good three speed I'm it now but I'm not sure that it would work with a 302. Any ideas are appreciated.
Join the Ford social group here on the hamb and all of your questions shall be answered!! http://www.jalopyjournal.com/forum/g...hp?groupid=332
I moderate the Group,just click on this: http://www.jalopyjournal.com/forum/social-forums/1952-59-ford-social-group.282/ When you get there do a new guy intro and then post away and enjoy the ride.
will long tube headers go in a 55 customline 302 swap? I have a set, they were free, thought I might get them to fit.
Just get a set of 63 galaxie 289 engine mounts. put a hole in the center between the two holes in your 55 frame mounts. bolts right in.
Check out my post in this link. https://www.jalopyjournal.com/forum/threads/59-fairlane-engine-swap.1088325/ It's on page 2 right now.
Hi Jeff. I'm trying to put a later model 5.0 in a 55 Sunliner. Ran across your post and I too am having a hard time doing anything on the site. Could you send me that list of part numbers and parts sources too? I have the engine sitting in the frame but it seems to be offset to the drivers side a bit using 80's model Mustang mounts. planned on using factory headers, but they hit the steering gear mostly because of the offset. any help would be greatly appreciated... Don Milner donniemilner@outlook.com
Jeff here is my e mail leo_parada2000@yahoo.com want to install it with C4 transmission. Thank you so much for info. Leo Parada
