Repairing Torque Thrust wheels questions
Discussion in 'The Hokey Ass Message Board' started by yoyodyne, Feb 14, 2011.
  1. yoyodyne
    yoyodyne
    I picked up a set of Torque Thrusts from another Hamber this week. One wheel has a crack that needs repaired, a couple have curb rash and one is corroded.
    1. What special requirements do these wheels have as far as welding? Can I just Vee out the crack and TIG weld it like any other cast aluminum? Any recommendations on rod alloy?
    2. To fix the curb rash, can it be welded and remachined or should I leave it alone and just file/grind/turn off the damage? Some is deep.
    3. You can see the corrosion in the photo on the left. This is inside and outside the rim, on both edges of the rim, probably from sitting on the ground. Can I remove that chemically or by some other means? I'm reluctant to gl***bead it and drive the corrosion deeper into the pores of the casting.
    Thanks for any help. I DID search before posting, came up with nothing after 8 searches...
    VANDENPLAS likes this.
  2. F&J
    F&J
    I am not quailfied on the crack issue, but as far as blasting the pits, I have done so with well worn sand in a blast cabinet. It worked fine. The aluminum corrosion is softer than the base metal, so it cleans up perfect. (What i mean is, On steel, the rust layers seem to be harder than the base metal)
    A good friend had two complete sets of Ansen slots spun on a large lathe to clean the rash, and clean the tire bead seat areas. They looked perfect. It all depends how deep the rash is, if there is enough meat to machine it out completely.
  3. bobby_Socks
    bobby_Socks
    from ǑǃƕǑ
    It looks like it could be tig welded. Might have to heat it with a torch first to get a little heat into it. The other wheel looks like it will clean up with just a little time on the lathe or you might be able to file it down and then work it with sand paper to get the file marks out if you do not have access to a lathe. Good luck and post pictures of the repairs.
  4. budd
    budd
    a couple of months ago i fixed the curb rash on some torque thrusts just by running the tig around, a little filler in one spot, the rest just flowed into a nice smooth bead, that crack should weld up fine.
    chevy57dude likes this.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I've seen them repair weld them and they cut out a small section to clean material as alum is porous and gets impurities in it.
  6. spooledup
    spooledup
    In a pinch i've stick welded them with pretty good success. Vee it out and burn it in.
    If you cant weld it pretty... Weld it HOT!
  7. budd
    budd
    heres a pic of my curb rash fix, both my wheels had a pretty good scruffing all the way around, i just remelted the edge with the tig and a little light sand and polish and this is what they look like.
  8. chevy57dude
    chevy57dude
    Resurrecting an old thread instead of starting a new one here. Torque Thrust wheels are my absolute favorites. Bringing a TT or clone back from the dead can be done at home. Unlike chrome vintage wheels, which require plating if they're rusty. Now, I'm talking about making them look good with hand tools and elbow grease. We're not welding aluminum here. Only corrosion removal and cosmetic restoration. I'm hoping pros with skills beyond mine can chime in with tips and full scale 100% perfect wheels.
    Sharpone and guthriesmith like this.
  9. chevy57dude
    chevy57dude
    Here's my starting point. 15x8.5 Chevy pattern clones. No cap screws broken off and only minor curb rash. Score!
    lothiandon1940, Fordors and Sharpone like this.
  10. chevy57dude
    chevy57dude
    Cleanup and a spin on my homemade "potters wheel" showed me the corrosion on the worst one was deep. Only a little hand file work took out all but the deepest scratches in the rim area.
  11. chevy57dude
    chevy57dude
    20241027_181954.jpg 60 grit paper and lots of spinning cut the aluminum deep enough to get past spider web corrosion. Don't forget the back, and tire seat area. 100, 150, 220, 320, 400, 600, 1000 all the way up to 2000 grit. The human lathe is tired!
  12. chevy57dude
    chevy57dude
    Mothers polish to make 'em shine.
  13. chevy57dude
    chevy57dude
    This is my choice of paint. It has a very slight gold tint. 20241106_095646.jpg
  14. chevy57dude
    chevy57dude
    Cleaned up the best 2 caps from my collection.
  15. chevy57dude
    chevy57dude
  16. ronzmtrwrx
    ronzmtrwrx
    Those came out looking really nice!
  17. Budget36
    Budget36
    No, they came out DAMNED FINE looking!
    Great work @chevy57dude !
  18. guthriesmith
    guthriesmith
    Those look great and I like the potters wheel! :cool:
  19. Greg Rogers
    Greg Rogers
    Wow, Excellent job!
    chevy57dude and Sharpone like this.
  20. Dave G in Gansevoort
    from Upstate NY
    An unique solution, the potters wheel. Worth remembering. Those wheels buffed up just fine. Great score, and the effort expended surely must be gratifying in that your out of pocket expenses remain small.
    seb fontana, chevy57dude and Sharpone like this.
  21. bowie
    bowie
    Nice work! That’s a good lookn’ pair of AP’s.
  22. chevy57dude
    chevy57dude
    20241107_151233.jpg just a spindle and hub lag bolted to a 4x6 with a plywood base.
  23. lothiandon1940
    lothiandon1940
    Great job, Steve. Lot of work, but they turned out great. Nice save.
    seb fontana and chevy57dude like this.
  24. DDDenny
    I haven't seen much discussion (or photos) on the HAMB about the aluminum center caps that American used on their early five spokes........almost like people never heard of them.
    It may be because many of our younger members came on the scene after the metal caps had already been replaced with the plastic versions, they have become quite collectible.
    So, show them if you got them.
    lothiandon1940 and chevy57dude like this.
  25. DDDenny
    What he said!^^^^^^^
  26. chevy57dude
    chevy57dude
    Thanks for the kind words, everyone. Denny brought up caps. There were a few different ones. The 2 I'm using on these wheels actually aren't matched, the center area for the long gone stickers are different sizes.
    lothiandon1940 likes this.
  27. Motorwrxs
    Motorwrxs
  28. Just Gary
    Just Gary
    Beautiful work, @chevy57dude !
    Reminds me of the old "tech week" threads!:)
    chevy57dude and lothiandon1940 like this.
