270 GMC altered motor build part 1
Discussion in 'The Hokey Ass Message Board' started by marshall, Feb 15, 2011.
  1. marshall
    marshall
    from tacoma/wa.
    The frame is done now its time for the motor. Were are using a 270 GMC block ,
    302 crank (6 bolt crank)
    Venolia 300 pistons made for a wayne horning head
    4" bore
    milled the block .125 to get 13.47 to 1
    polished rods & the block
    billet roller cam .514/.513
    roller rockers
    12 port horning head
    we are casting the injection
    I'll try to keep this up to date as we go along
    Marshall
  2. Mr48chev
    This looks like it is going to get interesting.
  3. xderelict
    xderelict
    Drool cup required when following this post.
  4. Rock Island Rocket
    Rock Island Rocket
  5. butcherted
    butcherted
    from hagerstown
    Awesome, keep us posted on the progress.
  6. quicksilver
    quicksilver
    Very cool! Please keep us updated with lots of pics!
  7. cant wait to hear it scream!
  8. retromotors
    retromotors
    I love to see an engine with the cylinders aligned the way God meant 'em to be!:D
  9. David Chandler
    David Chandler
    Those rods look too good to use! Put them where they can be admired.
  10. katesdad
    katesdad
    from Illinois
    Dont see that everyday. Polished rods I always liked those.
  11. marshall
    marshall
    from tacoma/wa.
    The rods got sent to the shot pener today. Tom did a very nice jod polishing them.
  12. marshall
    marshall
    from tacoma/wa.
    We resized and balanced the rods and pistons lsat week. This is the first set I've ever done, let me tell you I will never ***** about buying $600 set of rods.
    Mike made the prototype for our fuel injection, It will be 6 single injectors bolted to
    a plate than bolted to the head , We had Collin make the mold and cast them.
    The block is at Mikes getting machined for the roller lifters.
  13. marshall
    marshall
    from tacoma/wa.
    prototype
  14. marshall
    marshall
    from tacoma/wa.
    mold
  15. marshall
    marshall
    from tacoma/wa.
    casting
  16. marshall
    marshall
    from tacoma/wa.
    The part
  17. Pir8Darryl
    Pir8Darryl
    You got my attention! :D
  18. mike budniewski
    mike budniewski
    that is going to be a very nice engine!i enjoylooking at handwork-handmade parts . is there a harmonics problemwith these engines like the 250-292 and 240-300 sixes? i am really impressed mike
  19. marshall
    marshall
    from tacoma/wa.
    There is big problems with harmonics , Thats we are going over board on the balance of the rods and crank, and adding a big ATI balancer and the stall converter sould help some too.
  20. quicksilver
    quicksilver
    It's looking great! Are you bringing it to the March Meet? What roller lifters are you using, and where are you getting the billet roller cam?
  21. RichFox
    RichFox
    I ran a 270 and a 302 at Bonneville and the Lakes and the Drags for a while. Never any harmonic problems doing LSR. Drags were tough on the crank. Don't know why. Horning heads? Are they from Bill Fisher or Charlie Baker? I ran stock head, Howard head and Horning heads. One Horning I got from Charlie and one from Don Kincaid. Big fight with all three of those heads.
  22. marshall
    marshall
    from tacoma/wa.
    The motor we got had billet cam in it , and we just had it welded and reground , the
    lifters were a swap meet find and I dont know who made them .
    You can still get a roller cam and lifters from crower.
  23. marshall
    marshall
    from tacoma/wa.
    Rich, what was the big fight with the heads?
  24. Hnstray
    Hnstray
    from Quincy, IL
    You have a great start......am anxious to watch the build progress.
    May I ask about the use of a 270 block vs a 302 block? I have a complete '56 270 and access to a 302 block and crank. I read somewhere that a 270 crank is considerably lighter than a 302 shaft, though the stroke is the same, and I was wondering about using the 270 shaft in a 302 block. Any thoughts?
    Ray
  25. marshall
    marshall
    from tacoma/wa.
    I had 270 pistons for a horning head. If I were you I would use the 302. I think the cranks are the same in the later motors .
  26. RichFox
    RichFox
    The heads that Charlie had made were out of the league of the foundry that cast them. They all leaked badly and despite never ending work I never could get mine to stop leaking. Poor quality aluminum. They were all so warped that a few he cut in half and welded back together to try and flatten out the deck surface. Don Kincaid had the only one that I know of running much. Mine ran for a little while before launching a spark plug, still screwed in, at Bob Dalton. I ran Dons head at Bonneville and blew a head gasket. Gave up.
  27. marshall
    marshall
    from tacoma/wa.
    We blocked off the flow of oil in the middle of the main oil line and drilled below the plug
    and put a fitting and now we can hook up a oil filter that starts at the oil pump.
  28. marshall
    marshall
    from tacoma/wa.
    O rings in the block
  29. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I don't know what gasket you are planning to use on the head. Copper? I think that is the best (only?) choice when using an O-ringed block. My experience (albiet with 300 Ferds) is that a block O-ring will not be compatible with a composition gasket that has a fire ring in it (e.g. Felpro).
    Nice prep work.
