Hot Rod terms that are no longer in common usage
Discussion in 'The Hokey Ass Message Board' started by adjustablejohnsons, Feb 15, 2011.
  1. cavemag
    cavemag
    I use hopped up alot. Also about the whole 3/4 ,half, or full race cam just think about how streetable is it. At least thats what i've always thought of it as.
  2. Truckedup
    Truckedup
    Four and a halfs, board shift
  3. texas rattler
    texas rattler
    from texas
    **** box= junker.slow car nail it=floor it fish tail= sliding sideways an old dirt track driver use to say he was "stabbin and steerin" lincoln spool=weldded spider gears gun it=rev it marshmellow box=chevy 3 speed trans lay rubber.light em up,smoke em un spooled=break or blow up motor etc dump the clutch.side step the clutch,pop the clutch wound out=max rpm
  4. onlychevrolets
    onlychevrolets
    No heads get shaved , blocks get decked
  5. rustyford40
    rustyford40
    from Mass Bay
    Run the gears= wanna race
  6. Clik
    Clik
    Welded spider gears were called Lincoln Lockers 'cause they were usually welded with a Lincoln Welding Machine.
    Grandad used to always correct me when I used the word "motor" to describe an engine. He used to build electric motors and worked at a hydro electric plant as well as for the B&O railroad. He said "motors" were electric and engines had pistons and cranks regardless of whether they were gasoline, steam or diesel.
    alanp561 likes this.
  7. Muttley
    Muttley
    That has a completely different meaning here in California.
  8. Red Ryder
    Red Ryder
    "Cut-Outs" and "Lead Sled".
  9. Ratroddude
    Ratroddude
    4 pages , and not one mention of some the most popular sayings about custom cars...."*****IN' ".....or ..."SLOTS"......"M-50's"......."BIG & LITTLES"...:D
  10. texas rattler
    texas rattler
    from texas
    cut a doughnut,do a doughnut,
  11. Chief_Wannabe
    Chief_Wannabe
    from Ozark, MO
    It seemed like, at one time that all the hot set-ups were "de-stroked". Now of course everybody wants a stroker motor.
    When I was younger, "Cherry" and "Mint" were probably the most used terms to describe a nice car.
    You'd think terms like Police Interceptor would be dead by now, but I just heard that one a few weeks ago.
  12. coupeute
    coupeute
    " Put it on the wood ! " I had lots of " 3/4 race cams " after I " launched the motor ! " The other 1/4 is still stuck in the block !
  13. texas rattler
    texas rattler
    from texas
    blew his doors off= beat the other guy
  14. Slick Steve
    Slick Steve
    from Indy
    Love it!!!!!
  15. Dennis D
    Dennis D
    Dump tubes. A piece of pipe welded to the header pipe and capped off. Pipe wrench to take the caps off the dump tube. (wrench could also be used in a rumble) Dennis D
    God I'm gettin old...............
  16. texas rattler
    texas rattler
    from texas
    "rowin and goin" driving a 4 speed
  17. hotroddon
    hotroddon
    Come on Brad - That isn't an old Hot Rod saying and rednecks still get T Shirts at WalMart with it on it
    WTH? Never heard those
    Still VERY COMMON!
    So then it became "Pedal to the Metal"
    Some of us still say Thin Wall Henry
    That's cuz *****in, Slots and Big N Littles are still used and M-50's was a short depressing era duting the late 70's - 80's
    Used it just today!
  18. turdytoo
    turdytoo
    Remember when drag cars used to "boil the hydes"
  19. hotroddon
    hotroddon
    Don't forget Tijuana Chrome, for rattle can silver
  20. 19Fordy
    19Fordy
    Slush Box for auto transmission
    Slip and Slide with Power Glide referring to GM
    3 on the tree referring to 3 speed column shifter
  21. texas rattler
    texas rattler
    from texas
    may pops,baloney skins=wore out tires
  22. 296ardun
    296ardun
    Carburetors were "pots," or "jugs," cars lowered in front were "raked," different sized tires were "big-and-littles" ... anything done badly was "Mickey Mouse" (maybe that's still true?), dual exhausts were "twice-pipes," geez, are we really that old???
  23. Toby Denham
    Toby Denham
    from Georgia
    Nasty Nurstane - Nitromethane
    Spaghetti - Too much chrome
    Built - hopped Up ("That car has a built engine")
    Soup Job - Hot Rod, car with a hopped up engine
    Huffer - Blower, Supercharger
    Brain Bucket - Helmet
    Rail Job or Rail - Dragster
    Pop Up Pistons - Domed Pistons for raising compression ratio
    Bump Stick - Camshaft
    Smittys - Gl*** Packs
    Motor - Engine (I use to hear this all the time way back, not so much anymore)
    Propeller Shaft - Drive Shaft (not so much a hot rod term as it is an old automotive term)
    Meats - Rear Tires
    Put on the skids - Applied Brakes
  24. chopper526
    chopper526
    from Phila., PA
    Shoot a gallon: go cruising
    Door slammer: four door
  25. texas rattler
    texas rattler
    from texas
    my old man would call a junker car a "rolls can-ardly" he would say it rolls down one hill and can hardly get up the next. thanks for this thead , im having a blast!
  26. MIGHTY
    MIGHTY
    That car is ***s! It has Twice pipes and all sorts of do-hickeys
  27. hotroddon
    hotroddon
    Always knew Door Slammer to be a Draag Race car based on a regular production car with working doors (as versus a Rail job or Funny car)
    A four door was just your mom's car
  28. MeanGene427
    MeanGene427
    from Napa
    In the early '60's our neighbors had a "jitney" for hunting, a '54 Chebbie with everything cut off except except the hood to keep the rain 'n snow out, the dash, cowl 'n windshield, and the 4 seats- plenty of room for duck decoys, ice chest, etc., where the trunk used to be. Piece of railroad iron on each end for bumpers. No doors, no seat belts, no brainz
    "Dust 'im" meant knock that fool on his ****
    A "cut down" motorcycle had everything the didn't make it go faster removed- a "bobber" is similar in appearance, but more of a customizing effect than speed
  29. 296ardun
    296ardun
    Helmets were "brain buckets"
    Hydraulic brakes were "juice brakes," mechanical brakes were "press-and-pray" brakes
    Blowers were "lungs" or "huffers"
    and primer was "primer," never "suede"
  30. texas rattler
    texas rattler
    from texas
    showboat,all show no go
