Hot Rod terms that are no longer in common usage
Discussion in 'The Hokey Ass Message Board' started by adjustablejohnsons, Feb 15, 2011.
  1. Yea on the tire thing me and a buddy had a '59 belair for a while when i was in highschool. We put some fat dirt track tires on it and radiused the quarters for cleanance. I had dated a gal whose dad was a sign painter so I pulled it up to his shop and he lettered "The Big Meats" over the tires on both sides.
    It ended up causing us some problems with the local constabulary (what didn't), something about obscenity or the like and we ended up selling the car.
    We used to say an old sick woman off a bed pan or wouldn't pull the hat off your head.
    How about ya wanna hook 'em up? I say that to people now days and they look at me like a cow lookin' at a new gate.
  2. hotroddon
    hotroddon
    And the there was "Let's blow this Popsicle stand"
    "Hey man, give me four bits worth of Go Go Juice"
  3. Bobert
    Bobert
    Hit the hooks throw out the anchor = step on the brakes
  4. hotrod1940
    hotrod1940
    My car club in the fifties was the Trompers.
  5. Powerband
    Powerband
    'Gettin the traction, ridin' the clutch , my pressure plates burnin' and a' she's too much
    Sometimes terms evolve - like LSD ...
    Have Fun
  6. Enshrined in movie history is Robert Mitchum's remark to the effect of "I bought the car for the mill...". Thunder Road from 1958.
    dan c likes this.
  7. EEZI
    EEZI
    Nicely done!
  8. Rock Island Rocket
    Rock Island Rocket
    I have never understood the whole 3/4 cam nomenclature ?????????????
  9. Boydoggie
    Boydoggie
    How about-Haulin"A" or Churped-meaning a little tire spin noise after banging a gear ​
  10. It had to do with how radical the cam was a full race cam was pretty basically not streetable where as a 3/4 cam was just pretty stout.
    I have an Engle 153 296 duration .500 lift it was probably considered to be a 3/4 race cam.
    I'm guessing that it was easier than explaining the lift, duration, overlap, lobe separation etc to someone to whom none of that made any difference.
    Its like trying to explain Chanuka to a Baptist. :eek:
    Boneyard51 likes this.
  11. Ddooce
    Ddooce
    from Memphis Tn
    How about "a leg out of bed" to describe an engine block with a hole in the side and a rod poking out?
    I still have some older customers, mostly ladies from south of the state line, who refer to the throttle as the foot feeder - I am told to differentiate from a hand throttle as on T. They also use the term gas hand for the fuel gauge and every noise a car makes is a pop - doesn't matter what sort of noise it's a pop.
  12. GAL60
    GAL60
    What does it mean to "re-work" the suspension? At what point is your suspension "re-worked"? I heard that said of that Gary Howard/Jimmy Vaughn 54' Ford.
  13. falcongeorge
    falcongeorge
    from BC
    "Wont pull a fat girl off a tricycle"
  14. :D:D:D that sounds like S Carolina.
    The wife and I went for a drive when she got home from work, and she used one I haven't heard in ages. I was *****ing about not being able to see out of the little econobox we were in and she said, " It isn't any worse than that Hammered coupe we had when we were kids."
    hammered=chopped
  15. Thanks Don....I'm loving origins.......
  16. Road Rocket
    Road Rocket
    How about "pedal to the metal".
    Some cars don't even have metal any more, and the throttle is a sensor???
  17. 31ACoupe
    31ACoupe
    "flippin a *****" doing a tire burning cookie.
    "slammin iron" hitting the mechanical brakes hard (i know some of you had mechanical brakes).
    "yankin a brody" pulling the emergency brake hard when slammin iron isn't doing the job.
  18. If you wanted a "fine short" it had to be nosed, decked and shaved, dumped front and rear, runnin' twice pipes with dummie spots and four bars. Then you ready to cruise and listen to the Wolfman...
  19. Muttley
    Muttley
    Oh stewardess, I speak jive.
  20. ibarodder
    ibarodder
    The body is cherry.
  21. Skirts
    Connie kits
    Wolf whistles
  22. falcongeorge
    falcongeorge
    from BC
    Its a personal favorite...:D
  23. billsill45
    billsill45
    from SoCal
    "gimme 2 bucks worth of ethyl" - what you used to asked for at the gas station. Which now will get you a dumb look and enough unleaded gas (that you pump yourself) to get you to the end of the block.
  24. sr
    sr
    from Monterey
    Pagina and Gow job seem to be a match.............
  25. ford495051
    ford495051
    Wide Ovals (tires), Flop Tops(convertibles), Bubble Skirts, and Scavenger Pipes
  26. werntonb
    werntonb
    You are very tough man.
  27. gsport
    gsport
    at the gas station... "a couple of dollars of Ethyl please"
    i guess if i would've read all 11 pages, i would've seen that bill already said that...
  28. rustyford40
    rustyford40
    from Mass Bay
    How about the Bermuda bell
  29. 26 roadster
    26 roadster
    nosed; chrome removed from hood
    decked; chrome removed from trunk
    shaved; chrome removed from sides
    Thanks 1stGrumpy, I thought I had lost it!
  30. headaches = headers, as thats what we always got trying to fit them in
    put a deuce in the tank = $2 worth of gas (try that today)
    may pops = bald tires that may pop at any time
