Can anyone help me ID this Chevy subframe?
Discussion in 'The Hokey Ass Message Board' started by UnIOnViLLEHauNT, Feb 19, 2011.
  1. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Long/short, I bought me a Merc awhile back and this came with it, since then I bought a new Merc and the front frame is trashed. Measuring the two, this seems like it will fit, but I have no clue what it is. I just really want to find out so I can order brake parts etc. Here is what I can tell you.
    The subframe is a front steer, drum brakes. It measures from wheel mounting surfaces around 58 1/2 or 59 inches. The distribution block/prop valve for the brakes is on the engine side of the frame, drivers side, and the brake lines to a funky thing. Its hard line, then its a brake hose, then more hard line into the backing plate. I dont know if thats standard procedure on Chevys of a certain vintage, but seemed odd to me. The column only reads Chevrolet in script, and has ignition on the column, as is shifter, but its not a tilt.
    Back in college my girlfriend at the time had a 70 Nova, and the steering wheel kinda reminds me of that.
    Here are the pics, if you guys can help it would be super appreciated, and if you need any measurements, pics, etc, just lemme know.
  2. Ratroddude
    Ratroddude
    Judging from the front steer steering box , I would think it was out of a Camaro , say , mabye '70-81 model , most people like the Nova sub due to the rear steer box , it's mounted behind the wheels instead of in front...:)
  3. hot rust
    hot rust
    from the looks of it (i cant see the rear of the rails) it looks like a front frame section rather that a sub frame. has the rails been cut in the rear instead of just bolts removed? maybe a chevelle/monte carlo front clip? i dont remember the front rails on a camaro being that shape either.
  4. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Hmm, ok, Camaro. The rear that came with it was a coilover, and 1st gen Camaro was leaf, but this front end is narrow, which is throwing me off. How late were Camaros offered with drums up front? It seems to really date the car to a degree. Thanks man!
  5. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Yes, it was a full frame, sorry for the confusion, not an unboltable subframe.
  6. maniac
    maniac
    Then it maybe a Chevelle, they all had front steering I believe
  7. 52 csb
    52 csb
    If those lower chairs are original its 69 or older. :)
  8. I think those engine mounts were discontinued around 1973.
  9. 68 and up chevelle or first generation monte carlo, drum brakes, front steer, full frame, frame horns, and a-arm upper a arm design will be the key to id
  10. Mark T
    Mark T
    Is the column from the same car as the front clip? The steering column looks like the one in a '70 Impala that I learned to drive in.
  11. dbradley
    dbradley
    My '69 Chevelle had the prop valve located where that one is.
  12. Larry T
    Larry T
    My folks had a 71 Chevelle with a steering wheel like the one in your post. Frame definately looks Chevellish (?????????).
    Larry T
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Chevelle, know that frame very well. 68' and up base model with 307 or 6 cly with drum brakes.
  14. dave lewis
    dave lewis
    from Nampa ID
    Yup , 68 to 72 chevelle .
    Dave
  15. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    Thanks a ton guys, you have been a tremendous help! Off to price out some brake schtuff.
  16. 64gtoguy
    64gtoguy
  17. birdbuilder
    birdbuilder
    Here's a list of wheel base and track width
    Wheelbase, front track, rear track
    [edit] American Motors
    • 100.0, 61.2, 60.2 -- 75 AMC Pacer
    [edit] GM Car
    • 122.0, 58.31,59.25 - 37 Buick Special
    • 126.0, 58.31,59.25 - 37 Buick Century
    • NA,,,, 59.1, 58.8 -- 68-74 Buick Apollo
    • NA,,,, 59.0, 58.8 -- 78-86 Buick Century
    • 111.0, 59.1, 59.7 -- 75 Buick Skylark
    • 115.0, 58.5, 60.0 -- 55-57 Chevy
    • 108.1, 58.7, 60.5 -- 67-69 Chevy Camaro (other source shows 1081/590/589)
    • 108.1, 60.4, 61.0 -- 70 Chevy Camaro
    • NA,,,, 61.3, 60.5 -- 76-80 Chevy Camaro Z-28, Pontiac Trans Am TA
    • 101.1, 60.7, N/A, -- 93-02 Chevy Camaro
    • 101.0, 60.7, 60.6 -- 86 Chevy Camaro IROC Z
    • 101.1, 60.7, 60.7 -- 98 Chevy Camaro
    • 112.3, 63.7, 64.1 -- 99 Chevy Camaro LS, LT
    • 112.3, 63.7, 63.7 -- 99 Chevy Camaro SS
    • 119.0, 62.5, 62.4 -- 65-70 Chevy Caprice
    • 121.5, NA,,, NA,, -- 71-76 Chevy Caprice coupe/sedan
    • 125.0, NA,,, 64.5 -- 71-76 Chevy Caprice station wagon
    • 116.0, NA,,, NA,, -- 77-90 Chevy Caprice
    • 115.9, 61.8, 60.7 -- 91-96 Chevy Caprice
    • 102.0, NA,,, NA,, -- 54 Chevy Corvette
    • NA,,,, 58.7, 59.5 -- 68-83 Chevy Corvette
    • NA,,,, 59.6, 60.4 -- 84-95 Chevy Corvette
    • 108.0, 58.5, 58.8 -- 78-88 Chevy Monte Carlo, Malibu, El Camino(117.1 wheelbase), Olds Cutl***, Pontiac Grand Prix
    • 111.0,59.8, 59.6 -- 68-74 Chevy Nova
    • 097.0, 54.7, 53.6 -- 71-77 Chevy Vega, 73-77 Pontiac Astre, 75-80 Chevy Monza, Buick Skyhawk, Olds Starfire, 76-80 Pontiac Sunbird
    • NA,,,, 58.9, 59.0 -- 78-86 Pontiac Grand Prix
    • 115.0, NA,,, NA,, -- 66 Pontiac GTO
    • NA,,,, 59.9, 59.6 -- 68-74 Pontiac GTO
    • 112.25, 57.5, 59.0 -- 39 Chevy knee action
    • 112.25, 56.375, 59.0 -- 39 Chevy I beam
    • 116.0, 57.6, 60.0 -- 42-48 Chevy
    [edit] GM Truck
    • 106.5, 64.5, 63.0 -- 73-91 Chevy Blazer 2WD
    • 106.5, 65.75, 62.75--73-91 Chevy Blazer 4WD
    • 131.5, 65.8, 62.7 -- 73-87 Chevy C-10, K-10
    • 131.5, 65.8, 62.7 -- 73-87 Chevy C-20, K-20, C30
    • 164.5, 65.8, 62.7 -- 73-91 Chevy C-30 Crew Cab
    • 129.5, 65.8, 62.7 -- 73-91 Chevy Suburban
    • 114.5, NA,,, NA,, -- 55 Chevy 2nd Series (1955 1st series was same as 54)
    • 116.0, 59.5, 60,, -- 47-54 Chevy AD 1/2 ton
    • 125.25,NA,,,,62,, -- 47-54 Chevy AD 3/4 ton
    • 137.0, NA,,, NA,, -- 47-54 Chevy AD 1 ton
    • 144.0, NA,,, NA,, -- 02 Chevy Silverado 1500 4WD
    • 102.4, NA,,, NA,, -- 72-80 Chevy LUV w/std cab and 731" box Unequal length A-arms with torsion bars was std front suspension on LUV
    • 104.3, NA,,, NA,, -- 81-82 Chevy LUV w std cab and 731" box Unequal length A-arms with torsion bars was std front suspension on LUV
    • 117.9, NA,,, NA,, -- 78-82 Chevy LUV w std cab and 901" box Unequal length A-arms with torsion bars was std front suspension on LUV
    • 100.5, 54.5, 54.7 -- 83-01 Chevy S-10 Blazer 2-dr, 83-01 GMC Jimmy 2-dr
    • 107.0, 54.5, 54.7 -- 90-01 Chevy S-10 Blazer 4-dr, 90-01 GMC Jimmy 4-dr
    • 108.3, 54.5, 54.7 -- 82-93 Chevy S-10 reg cab, 73" box, 82-93 GMC reg cab, 73" box STOCK Malibu and El Camino drop spindles are bolt-on
    • 117.9, 54.5, 54.7 -- 82-93 Chevy S-10 reg cab, 89" box, 82-93 GMC reg cab, 89" box
    • 122.9, 54.5, 54.7 -- 83-? Chevy S-10 ext cab, 83-?? GMC ext cab
    • 135.0, 67.8, 67.8 -- 08 Chevy Express Cargo 1500 Work Van
    [edit] Ford Car
    • 108 -- 64-68 Mustang
    • 096.2, 55.6, 55.8 -- 74-79 Ford Mustang II, Ford Pinto, Mercury Bobcat, Mercury Capri (have also seen track listed at 551/553)
    • 100.5, 56.6, 57.0 -- 86 Ford Mustang GT
    [edit] Ford Truck
    1953-1955
    • F100 1/2-ton - 110"
    • F250 3/4-ton - 118"
    • F350 3/4-ton - 130" (F350s were still cl***ified as 3/4 ton trucks up through '55.)
    1956-1960
    • F100 1/2-ton SWB - 110"
    • F100 1/2-ton LWB - 118"
    • F350 1-ton - 130"
    1961-1963
    • F100 1/2-ton SWB - 114"
    • F100 1/2-ton LWB - 122"
    • F250 3/4-ton - 122"
    • F350 1-ton - 132"
    1964
    • F100 1/2-ton LWB - 128"
    • F250 3/4-ton - 128"
    • F350 1-ton - 132"
    1965-1966
    • F100 1/2-ton SWB - 115"
    • F100 1/2-ton LWB - 129"
    • F250 3/4-ton - 129"
    • F250 3/4-ton CrewCab - 147"
    • F350 1-ton - 132"
    • F350 1-ton CrewCab - 152"
    1967-1968
    • F100 1/2-ton LWB - 131"
    • F250 3/4-ton - 131"
    • F350 1-ton - 132"
    1969-1970
    • F350 1-ton - 135"
    • F350 1-ton CrewCab - 159.5"
    1971
    • F250 3/4-ton CrewCab - 159"
    • F350 1-ton - 135"
    1972
    • F350 1-ton - 135"
    • F350 1-ton CrewCab - 159"
    1973
    • F100 1/2-ton SWB - 117"
    • F100 1/2-ton LWB - 133"
    • F250 3/4-ton - 133"
    • F250 3/4-ton CrewCab - 161"
    • F350 1-ton - 137"
    • F350 1-ton CrewCab - 165.5"
    1974
    • F100 1/2-ton Supercab LWB 6-ft bed - 140"
    • F100 1/2-ton Supercab LWB 8-ft. bed - 155"
    • F250 3/4-ton Supercab - 140"
    • F250 3/4-ton CrewCab - 155"
    • F350 1-ton - 137"
    • F350 1-ton Supercab - 140"
    • F350 1-ton Platform/Stake - 161"
    • F350 1-ton CrewCab - 166.5"
    1975
    • F100 1/2-ton Supercab 6-ft bed - 140"
    • F100 1/2-ton Supercab 8-ft. bed - 155"
    • F150 1/2-ton - 133"
    • F350 1-ton - 137"
    • F350 1-ton Supercab - 155"
    1976
    • F100 1/2-ton Supercab - 155"
    • F350 1-ton - 137"
    1977
    • F150 Supercab - 155"
    • F350 1-ton - 137"
    1978-1979
    • F250 3/4-ton Supercab - 155"
    • F250 3/4-ton Crewcab - 155"
    • F350 1-ton - 137"
    [edit] Mopar Car
    • 115.0, 61.9, 62.0 -- 75 Chrysler Cordoba
    • NA,,,, 58.9, 59.0 -- 75-79 Dodge Aspen, Plymouth Volare
    • 111.0, 59.2, 55.6 -- 67-76 Dodge Dart/Plymouth Scamp
    • 108.0, 59.2, 55.6 -- 70-76 Dodge Demon/Dartsport, Plymouth Duster
    [edit] Mopar Truck
    [edit] Miscellaneous Car
    • 105.0, 58.0, 58.0 -- 51 Cunningham C-1, C-2R
    • 107.0, 58.0, 58.0 -- 53 Cunningham C-3
    • 100.0, 54.0, 54.0 -- 52 Cunningham C-4R, C-4RK
    • 100.0, 55.0, 55.0 -- 53 Cunningham C-5R
    • 100.0, 52.0, 52.0 -- 55 Cunningham C-6R
    • 086.0, 50.5, 50.3 -- 48-74 Morris Minor
    [edit] Axle to axle, rear differential
    [edit] GM Car
    • 58.0 -- 78-88 Mid sized GM Car, Malibu, Monte Carlo (82 up Metric Studs), Regal with 10-bolt, 65-67 Nova
    • 59.0 -- 68-83 Corvette
    • 60.0 -- 55-64 Chevy, 67-69 Camaro, 64-67 Chevelle, 68-74 Nova, 84-95 Corvette
    • 62.0 -- 64-77 Chevelle, 89 Trans Am
    [edit] GM Truck
    • 58.0 ---S-10
    • 60.5 -- 64-69 1/2 ton 2wd Chevy, Some GMC 6 lug rear end 12 bolt Coil spring set-up
    [edit] Ford Car
    • 56.5 -- 71-77 Ford Maverick 8"
    • 57.0 -- 71-74 V-8 Mavericks 8", All '75-77 6's & 8's Maverick 5 Lug 8", 49-51 Ford, 57-59 Ford 9"
    • 57.25 -- 64 1/2-65 Mustang
    • 58.0 -- 80 Granada & Lincoln Versailles, 67-70 Mustang/Cougar/Fairlane
    • 58.5 -- Granada (year unknown)
    • 60.0 -- 71-73 Mustang/Cougar
    • 62.0 -- 73-76 Torino
    [edit] Related resources
  18. Bruce Lancaster
    Bruce Lancaster
    The brake valve down there is a giveaway. You are the sort to be messing with the height of the thing, which leads to a connection: These Chevelles, up to '72, use the same basic spindles as '68 Camaro and Nova, but equipped with different bolt-on arms to make them front steer. All the F and R steer arms on this generation are bolt-on. This means that dropped spindles are available, ***uming no conflict with the arms...I think they will be moving AWAY from said conflict. Also, the A arms are basically the same, except in comparison with Nova-Camaro the rear rubber bushing is a fat thing on most to allow more compliance on bumps...ne stock, dropped, and narrowed A arms are available.
  19. caseyrod
    caseyrod
    73-74 nova.steering box in front of crossmember but it has drum brakes,probable,nova.
  20. THE_DUDE
    THE_DUDE
    Indeed
  21. ANDEREGG TRIBUTE
    ANDEREGG TRIBUTE
    from Bordertown
    100% correct....
  22. tmg24
    tmg24
    from Akron
    70-81 Camaro/Firebird to not kick out wider like that, they are straight. Possibly Chevelle?
