show me your engine test stand
Discussion in 'The Hokey Ass Message Board' started by youngster, Feb 14, 2011.
  1. youngster
    youngster
    from Minnesota
    I did a search but couldn't find a stand being built. Post some pictures of what you've put together please.
    Ron
  2. Skrap metal
    Skrap metal
    ya gotta checkout Easy run engine test stands out of so. cal
    they make the absolute best at a really great price.
  3. I just took the engine off this one. With some reconfiguring of the mounts, it will get an A motor next.
    Sent from my iPhone using TJJ ****a!
  4. J&JHotrods
    J&JHotrods
    P.O.S. from Harbor freight. Didn't have time to build, but knew I could modify as needed if I had to. Comes with gauges-throw them away. Supplied fuel tank was full of ****-used a 5 gal. can off to the side. Garden hose adapted to rad. hoses for cooling. Haven't changed anything on it, but I DO recommend checking all the fasteners before each fire up. I'll probably weld it all up solid once it is to my liking. It was too cheap to p*** up and time constraints kept me from building one. I wanted to hear that motor NOW!
    Here's a link of it running if you care-gives you a better idea of what it looks like.
    http://s724.photobucket.com/albums/ww248/JnJhotrods/?action=view&current=MVI_1863.mp4
  5. Moparhead
    Moparhead
    Here's the one I built.I built it for a mopar motor,but could be easily modified for a SBC.
  6. budd
    budd
  7. 57olds
    57olds
    from ohio
    Here is my 1957 Olds J-2 Motor "Test Stand".
    Ok Ok.... it's not a "Test Stand" but a "Display Stand". Actually it does have a remote start and the motor turns, crank, pulley, fan, etce.
    I have an eletric motor hidden in the oil pan that runs every thing.
  8. GOATROPER02
    GOATROPER02
    from OHIO
    I think thats called a shrine......
    Tony
  9. ^^^ That's awesome!^^^
  10. GOATROPER02
    GOATROPER02
    from OHIO
    The Old SuperFlow SF901T in use,Getting ready to install a new SF902 any day now,Just waiting on them to finish it and ship
    SBC, BBC, and our beloved Oldsmobile
    Tony
  11. Oldmics
    Oldmics
    What about engine torque flippin one of these over ?
    Or is that a dumb *** question :eek:
    Oldmics
  12. Russ B
    Russ B
    I built this one a few years ago
    I was also in the process of changing from carbs to efi, so I set it up to use both while the motor was still on the stand.
    The break in was with the carbs.
    I should have set up a muffler system, the megs were too loud to let anyone think, and as a result, we cut short the time spent with debugging the efi.
    rod1, MAW and Kiwi Kev like this.
  13. Mine... and Ive run them on the floor as well!!!;)
  14. RiKi5156
    RiKi5156
    The hemi reminded me of a "test run" we did in my shop back in 1990. A blown alky 467 inch early hemi,6-71 run 50% over. 1198hp, 1550!!!!!!!!!!!!!!!! ft/lbs torque. It was sitting on a homemade engine stand ($11) with ratchet straps running to various poles in pole barn. Buddys brought over a 5 gallon can of alky and we lit it up. Holy moly! It was a great night for a club gathering. Rich
  15. My 'redneck dyno' is a wooden pallet with wooden blocking and sometimes a ratchet strap.
    It's been used several times...:D
    alanp561 likes this.
  16. Mr48chev
    Test stand? don't need no freaking test stand.
    Actually I use to use several not too much different than what Cactus1 showed in his photos. Sp**** but they held an engine, radiator, battery and a couple of gauges and they were easy for the kids in the cl*** to work on the engines and could be shoved in the corner when they weren't needed.
  17. Nailhead Jeff
    Nailhead Jeff
    from fresno
    This stand is hommade and basic but it works good. Perfect for testing and tuning.
  18. hellerods
    hellerods
    This is my run-in stand, adjustable for different engines. BBC,SBc, Pontiac-------Blown flathead next!!
  19. FANTM58
    FANTM58
    I built this out of s****, works great !!!
  20. Pallets are for "pansies"... hahaha... Straps...???? Pure luxury I tell you!:eek:
  21. stainlesssteelrat
    stainlesssteelrat
    from ms
    right now i'm building a test stand that i can test any damn thing i want to on it ,
    it's legs are 3 1/2 in scd40 steel galv pipe and the cross supports are galvinised mini I beams, i want to be able to test a detroit 871 in it or a 460 ford or a 4cyl geo mill without problems. i'll post pics tomarrow.
  22. steel rebel
    steel rebel
    Made mine from an extra rebuild stand I has saying around. Added heavy duty wheels and it rolls around great. Not pretty but serves the purpose.
  23. mrpowderkeg
    mrpowderkeg
    Making a new one now, my old one was a pos.
  24. Oppy
    Oppy
    My engine builder friends test stand, w/ my 261 on it.
  25. J&JHotrods
    J&JHotrods
  26. roseville carl
    roseville carl
    Here's mine home made but works.....
  27. kardude67
    kardude67
    from Topeka, Ks
    Just finished this one. Took about 25 hours. I just fired it up today.
  28. nexxussian
    nexxussian
  29. nexxussian
    nexxussian
    I don't have any good pictures of it at the moment, but we built one on top of a flat cart we bought from Costco several years back (aluminum diamond plate deck, what look like large pneumatic caters, with solid rubber tires).
    We used angle for the perimeter of the frame, built a framework out of light tube s**** we had, and a knockoff brand "moon" tank for fuel.
    We used the radiator from our salt flat car, as it was the engine we were testing, Hilborn and all.
    Most of it was stuff we already had.
