Hilborn help needed...
Discussion in 'The Hokey Ass Message Board' started by tarzanboy, Feb 21, 2011.
  1. tarzanboy
    tarzanboy
    from Reno
    Anybody ever tried to run a hilborn with an electric pump or a conventional cam driven one?
  2. Dale Fairfax
    Dale Fairfax
    Not enough volume.
  3. hotroddon
    hotroddon
    Mechanical Hilborn won't run right with an electric pump, even the high volume EFI types as they are designed for the pressure and volume to be controlled by RPM.
    Conventional stock types pumps won't even come close to supplying enough flow or pressure, plus you need to run return system.
  4. tarzanboy
    tarzanboy
    from Reno
    Thanks, I though so but had to ask...
    How about those belt driven ones... I think Crower makes one...
  5. RichFox
    RichFox
    My Hilborn pump, or sometimes Enderly, is belt driven. That's pretty normal.
  6. 1934coupe
    1934coupe
    Hilborn makes them too. The pumps are the same as the ones that go on the front cover and are driven by the came. It is just on a belt driven pulley and bracket.
    Pat
  7. SmokinBill
    SmokinBill
    I have a belt driven Enderle for the Hilborn set up. I would like to sell the whole set up for $800,Pump,Manifolds,Pulleys,Nozzles,Lines. This manifold sells for $2900 from hilborn #327-8c
  8. Pete1
    Pete1
    from Wa.
    I drove mine off the cam.
    Hilborn sized it for the application.
