Bushing or spacer for ball joint on front wishbone
Discussion in 'The Hokey Ass Message Board' started by Lawson Cox, Feb 22, 2011.
  1. Lawson Cox
    Lawson Cox
    Does anyone make a spacer or shim to compensate for wear in the ball joint at the end of the front wish bone on early (30's) flathead Ford. I have not been able to locate one. Does anyone have any suggestions as to how to compensate for wear when a new rubber ball doesn't quite get the job done? Thanks.
  2. brokenspoke
    brokenspoke
    I recall one of the model a ford dealers having a cupped washer..just for this
  3. tommy
    tommy
    Yes Macs and other Ford parts houses have the rubber insulator and a bushing/spacer. You do have the rubber insulator on it, don't you?
  4. Lawson Cox
    Lawson Cox
    Yes. I will check with Macs or our local dealer. Thanks.
  5. DD COOPMAN
    DD COOPMAN
    Lawson...Never thought we'd ever see you over here on "the dark side". Welcome to the HAMB. DD
