Projects My First Custom - Shoebox Project
Discussion in 'The Hokey Ass Message Board' started by the-rodster, Aug 26, 2010.
  1. the-rodster
    the-rodster
    Springs are in.....
  2. the-rodster
    the-rodster
    Removing the pads from the S10 rear...
  3. Cyclone GT
    Cyclone GT
    Very nice build!
  4. the-rodster
    the-rodster
    Nice day yesterday.
    Stripped the subrame, and power washed it.
  5. Gator
    Gator
    from Statham Ga
    Love the tire / cap choice Rich...
  6. davidh73750
    davidh73750
    You got some great metal skills. Love your OLD car. I really like the 49-50 dash on those fords.
  7. davidh73750
    davidh73750
    and most here would agree that sounds so ghey
  8. Hotrod95
    Hotrod95
    Lookin' great! Beautiful metal work
  9. the-rodster
    the-rodster
    Mocking the rear end placement...
    With the springs de-arched three inches, I figured I would still need 1 or 2 inch lowering blocks, so I made some 1 1/2 inch biodegradeable blocks for testing.
    Looks pretty good, with the weight on the springs, the axle is 3 inches from the snubber.
    I like how the springs look with the weight of the car, not flat, still a little curve.
  10. the-rodster
    the-rodster
    The S10 track width is 3 inches narrower than the shoebox, so I figured I would get custome offset wheels made.
    Then I figured, why not just get a set of 49 chevy wheels, and reverse them.
    Reversing the chevy wheels gives about and inch and half more positive offset, should be just right. I haven't welded the centers yet, need to true them up this weekend and weld them.
  11. lowpunk
    lowpunk
    from berwyn, il
    This is one of those threads that i hope never ends when I'm scrolling through!!! Did you de-arch just the main or the others in the pack too? Patch job and trunk looks great. Can't wait for the next installment!
  12. the-rodster
    the-rodster
    I dearched all of them to match the main leaf.
    Rich
  13. '54Caddy
    '54Caddy
    Great work! Looking foward to seeing more on this one. My shoebox is a little worse than you started with and this thread is some great motivation. Will be starting in the spring. Ive also put a lot of thought into how to lower mine, Im looking foward to see how the s-10 clip works for you.
  14. ~pirate~
    ~pirate~
    Very cool! I just picked up a 49, keep up the good work! Subscribed.
  15. ratster
    ratster
    rich, nice work
  16. sololobo
    sololobo
    Impressive build, love the wheel, tire, and cap choice. Another sweet shoe box in the works. Thanx for the cool posts. ~sololobo~
  17. bobx
    bobx
    from Indiana
    looking good.
  18. the-rodster
    the-rodster
    Trued up the wheels last weekend, and welded them solid.
    I threw a dial indicator on them, and was able to get the runout within .020
  19. the-rodster
    the-rodster
    I rolled it outside, to turn it around in the garage, and take a look at how low the rear sat.
    Could go a little lower in the back, we'll see once the front comes down.
  20. chaddilac
    chaddilac
    Rearend is setting nice!!!
  21. choptop kid
    choptop kid
    looking awesome ! its cool your goin traditional springs and de arched leafs . hope this thread goes all the way
  22. the-rodster
    the-rodster
  23. the-rodster
    the-rodster
    The frame was absolutely filled with a fine dirt.
    So I took this opportunity, to put an 8 foot section of 3/4 pvc on then end of a vacuum hose, and ****ed all the dirt out.
    Every once in a while the pipe would clog...
    This is what I found.
  24. the-rodster
    the-rodster
    After all the measuring, I decided that I would not Z the clip, and try to match the clip as close to the ford frame as possible.
    I figured, if it needs to go lower, dropped spindles are only $100
    So, to mate the new clip, I pie cut the frame, to match the height and width of the shoebox, 3 X 4.5 inches.
  25. the-rodster
    the-rodster
  26. the-rodster
    the-rodster
    Once the frame was welded, I went to work on the fish plates.
    Inside.
    Outside.
  27. Mr Blue
    Mr Blue
    from Florida
    Looking great. You are building a car on my bucket list. Love th eshoebox for. Nice job on the build:)
    Don
  28. RG49MERC
    RG49MERC
    Looking good..it's coming together nicely!!
  29. the-rodster
    the-rodster
  30. the-rodster
    the-rodster
    Wheels painted.....
    Stones mounted
