what engine is this
Discussion in 'The Hokey Ass Message Board' started by 69ranger, Feb 24, 2011.
  1. 69ranger
    69ranger
    from mo
    i just got a 49 ford shoe box...
    it has a small block chevy in it.
    i got a picture of the head casting mark.
    can any one tell me what it is..
    i think its a 283 but not sure
  2. brad chevy
    brad chevy
    Going to need more than a picture of the head casting design. Look,if you can get to it on the drivers side rear of engine where ****** and engine meet,there will be a casting no. there that will tell you exactly what you have.Post the no.
  3. AssGasket
    AssGasket
    Boat anchor???
  4. fltnlow
    fltnlow
    from Burbank
    283 heads? not positive though...
  5. Diavolo
    Diavolo
    Uhm, not sure really, but we used to call them "power pack" heads. We believed they were not high flowing heads but more the stock economy type head. 2 bumps, camel hump. One bump or a triangle, power pack.
    This was long ago and we were kids so we didn't know much.
    OK, I googled it.. here is what I found
    http://wiki.answers.com/Q/How_do_you_identify_283_power_pack_heads
    the power pack head will have no acc. holes on the face and will have a casting mark shaped like a rectangle with a triangle on it, also know as the pyramid.
    Further reading show them as 283 heads and have higher compression due to a smaller combustion chamber. I hope that helps and that I am not lying out my ****...
  6. Lost in the Fifties
    Lost in the Fifties
    To confuse you further, they also came on early 327 engines. (210 and 250 hp versions
  7. 69ranger
    69ranger
    from mo
    im gonna pull a valve cover and get the numbers. ill post them on here. maybe that will help
  8. Abomb
    Abomb
    That will only tell you what the heads are from....they could have been swapped. Get the casting number off the back of the block, sort of behind the drivers side head.....
  9. squirrel
    in addition to the casting number and casting date on the back of the block. look for the stamped number sequences on the front of the block deck surface, just in front of the p*** side head. Post those numbers/letters, they'll tell us what it is.
  10. Howlin327
    Howlin327
    it's the pad on the front of the engine block, right bank that gives you the engine build date,engine size,as well as the bellhousing casting number,it's an early block
    up to '67 when you find the extra hole for the breather canister at the back of the block just behind the intake. no canister under the intake? 68 and later
  11. vtx1800
    vtx1800
  12. budd
    budd
    after looking that head casting mark up in my small block interchange manual, my money is on a mid 70's 350
  13. No way !!! No bolt holes.
    It's a 283 (or early 327) power pack (high compression)
    Maybe 520 or 896
  14. plymouth1952
    plymouth1952
    no hole for power steering and Alt pre 1968 it looks like a 68 cc head
    were the guide plates there when you got the heads or did you put them on
  15. Docs_Rubb
    Docs_Rubb
    Looks like a right triangle to me, that would make it a.....drum roll please....
    "Large chamber (76cc) light weight head" maybe off a 350 but I don't think it's from the '70's, I am thinking earlier. I found this link in an old H.A.M.B. post from 2008
    http://www.fastnuf.com/Headguide.html
  16. budd
    budd
    well, have you found the numbers yet?
  17. 69ranger
    69ranger
    from mo
    i found these numbers on the head 3947040.
    this number on the p*** side of the block v1029tck and ccj115303.
    i cant see the numbers on the back side of the block the way its been set in the car
  18. davidbistolas
    davidbistolas
    '040- 64cc 327 head circa 1968. Doesn't mean that's what the block is though. I've got camel humps on mine, that doesn't make it a '64 corvette motor.
    You need to get to that rear casting number to be sure.
  19. mjlangley
    mjlangley
    from SE MI
  20. davidbistolas
    davidbistolas
  21. davidbistolas
    davidbistolas
    ha ha beat me to it :)
  22. 1973 307 cid from a truck
  23. budd
    budd
  24. squirrel
    CCJ would be a 1982 chevy truck engine. C means chevy truck, second C is the model year (numbers in the 70s, letters starting with A in 1980), truck was ***embled in Janesville WI.
    If it were a 1973 truck engine, then it would be C3J....
    The suffix TCK could be from 73, or it could be from some other year. Chevy did use the same suffix for way different engines in different years.
    Without the numbers on the back of the block it's hard to say for sure what it is. I don't have truck suffix numbers from the 80s.
  25. First of all , does it have a breather hole in the back of the block behind the intake?
  26. squirrel
    With a 3 letter suffix, it should not have the breather hole back there. 1960s engines had a two letter suffix.
  27. mt shasta steve
    mt shasta steve
    As long as we are here I have a sbc block vin code VOI05KM. The KM doesn't show up in my motors manual. Anyone know what the KM means? I'm calling it a mid 60s' 327.
  28. squirrel
    67 full size chevy car 327
  29. Docs_Rubb
    Docs_Rubb
    V1029TCK
    V=Flint
    10=Oct
    29=29th
    T=Tonawanda plant
    CK='73 model 307cid from a C20-3500 series
