suicide doors
Discussion in 'The Hokey Ass Message Board' started by JimV57, Feb 25, 2011.
  1. LOW LID DUDE
    LOW LID DUDE
    from Colorado
    I have seen a lot of nice cars ruined with guys trying to do it.A lot of them wish they didn't do it but it is too late now. Miss alignment.sagging looking when opened and not being able to open wide enough for entry and exit. Good luck with your decision.
  2. Bad Bob
    Bad Bob
    from O.C. Baby
    Sounds retarted!!!! Kinda like flaming a Chevelle. I've never seen a truck with suicide doors where it was an improvement to the looks of it.
  3. LOW LID DUDE
    LOW LID DUDE
    from Colorado
    My 70 year old dad said they called them suicide doors because in the old days when the doors flew open after hitting a bump the occupants of the car would grab the door trying to stop it and were pulled out of the car going down the road=== SUICIDE ! So ya still thinking about doing it?
  4. resqd37Zep
    resqd37Zep
    from Nor Cal
    I plan to have suicide doors on my Cadi when it's all said and done. I stand about 2 feet taller than the car so it'll actually make getting in and out easier. I say do what you feel but hey I like reverse opening hoods too. What can I say.
  5. Suicide doors can't be too bad.
    My Pontiac had them factory fitted back in 1935 ... :D
  6. Bigbillyrocka
    Bigbillyrocka
    At least he's not saying he wants "Lamborghini" doors! That would be horrendous.
  7. JimV57
    JimV57
    The thing about this build is, its all in pieces; the doors, the cab, etc. If it was built, I don't think I would even consider it. It appears, and this is probably a simplistic view, but from what I see on the truck door jams, I could remove the hinges from the front of the jam, create a tempate for the hole on the other side of the jam and install the hinges. Of course the alignment would be critical....that is a given.
    If I did decide to do this, and I'm still on the fence, I would use a dead bolt as well as the locking mechanism. By the way, the door handles will be shaved.
  8. JimV57
    JimV57
    No, lambo doors or gull wing doors are ridiculous in my opinion - with the exception of lambo doors on a lambo...lol
  9. Bigbillyrocka
    Bigbillyrocka
    I always heard they were called suicide doors cuz when u would be onthe side of the road and a car came and hit your door you'd be "done."
  10. JimV57
    JimV57
    I'm not sure I would really need any sort of kit to do this. The stock hinges I have are in great shape - no damage or slop in them at all.
  11. shocker998md
    shocker998md
    I wouldnt do it, but thats because getting my regualr doors lined up and closing on my F100 is kicking my ***.
    Your truck, do what you want.
  12. puckm2
    puckm2
    I don't know how it proves your theory, I have $60.00 bucks in mine and it sounds he like is going to have under $100.00 in his. I would also have to say having little money does not mean good taste hence the origination if the rat f***ing rod.
  13. willowbilly3
    willowbilly3
    from Sturgis
    Take perfectly good doors and make them open the other way? Why?
  14. michaelmoore
    michaelmoore
    .i like different. do the doors
  15. Take a look at a rocky hinge kit,this was one of the easiest things that I did on my custom build .
  16. chopt49
    chopt49
    I say do it... Hell it's your ride, build what you want.
  17. wizzard23
    wizzard23
    Suicide doors look like sh*t on anything that did'nt come with them , and some things that did!
  18. Obviuosly a vintage car/restorer type guy.:D
  19. Heo
    Heo
    why waste time to change a god solution over to a bad
    is it just to be different as all the other ones
    A green ***** glued to the hood is different to
  20. Mr48chev
    I did just that on my 48 the first time I did the doors. I cut out the whole door posts from a truck my grandfather had rolled and used those in the opposite corners and used pieces from spare doors to fit the hinges to the door.
    But and it's a big but, I could never get gl*** to fit in the doors because the hinge pockets intruded into the area where the gl*** goes. I didn't have the knowledge or equipment I have to work with now so that may have been a big part of the problem but it is something to think about.
  21. gnichols
    gnichols
    from Tampa, FL
    EXACTLY why you don't see them on most production cars. At highway speeds, you can't pull the door back closed. Instead, the door will fold backwards 180 degrees and pull the occupant out of the car if they try to hang on. Conversely, at highway speeds, the door might open and fold back so fast that you couldn't react to the situation anyway. Still, I like the "custom" look. If you do it, be sure to have a back-up lock pin (they have been sold for years). You might also try riding around for an evening in a car similarly equipped, to see how you like backwards doors. Gary
  22. demmals7ytriht
    demmals7ytriht
    from Speer lane
    Gotta agree on this, The wife wanted suicide doors on our 37 and since it was home built I got a bunch of work in the doors. Was it worth it, not really, would I do it again, probably not. It's just one of those things you gotta do to get it out of your system... that said good luck...
  23. I always loved the way they looked on the old Lincoln 4 door cars,,really cl***y looking.
    I hope I don't start a controversy,,but aren't they really called suicise doors .
    I thought that was the way the factory spelled it?
    I know some of the older guys here will know.
    Tommy
  24. The Shocker
    The Shocker
    Suicide them.I suicided a hood on a 54 Chevy just to be different and i was glad i did it afterwards .The look on peoples faces when i opened it backwards was enough to make it worth while .I saw a 49 Chevy sedan delievery once that had suiced doors and they used Camaro hinges flipped side to side and it worked out great.Only advise i can offer is to make sure you build up the rear of the door to hold the weight where the hinges attach to it ...
  25. 49ratfink
    49ratfink
    suicide, lambo, or gull wing doors are all about the same degree of stupid where I come from.
    I can't picture any car that looks better with the doors open. how is that an improvement?
  26. I agree 100%. Try jumping out one! I thought that this was why they were called suicide.
  27. terrarodder
    terrarodder
    from EASTERN PA
    My 37 4dr already had suicide rear drs.but I wanted hidden hinges. I used 55 F-100 hinges, just a though, may be you could just switch sides with the hinges. I had mine rebushed before I used them.
  28. Doc Squat
    Doc Squat
    from tulsa, ok
    I put them on my 56 F-100. People thought it was really cool. Was fun to show. Truck is now in Chino, Calif.
  29. davedeltadog
    davedeltadog
    I know why they call them suicide. I was riding in the back seat of my dads suicide rear door car when I was about two years old. There were'nt child car seats back then and I was allowed to wonder around the back. For some reason, I pulled the door handle on the drivers side at 50 mph. I was thrown into the on-coming lane, bounced between two cars and ended up in the ditch. My parents took me to a near-by house and after they washed the dirt off me, found I didn't have a scrach. I'm one lucky sum*****!!
    So much said for that. I own a suicide door car today and love it. It's easy to get in and out of. I'm building electric solenoid safety dead bolts and would advice everyone to think about it.
  30. 69f100
    69f100
    from So-Cal
    i say go for it, its not going to change how the truck looks or performs. and no one will ever notice till you get out. (just either shave it , or leave the origional door handles, dont put the handles off of a 1990's chevy truck like i see alot of)
