EMS ROCKERS- Why are Ovals not cut out/
Discussion in 'The Hokey Ass Message Board' started by fordstandard, Feb 26, 2011.
  1. fordstandard
    fordstandard
    QUESTION- Does it matter if ovals are cut out OR not a big deal?
    Am I to cut them out OR just leave them alone?
      84.5 KB
  2. 19Fordy
    19Fordy
    Not a big deal. In fact, I would prefer that they are not cut out. Provides more rigidity. Sill plate hides it all.
  3. fordstandard
    fordstandard
    Is it for drainage of some sort ?
    For- Water from ? To go ?
  4. Kinky6
    Kinky6
    Its a stiffener, makes the part stronger. With the sill plate on, no water should be getting in there, so no need for drainage.
    Later, *****6 :cool:
  5. kiwiandy
    kiwiandy
    Ive seen people cut them out. Not a major job. Im gonna cut mine out and pump some rust proofing in once its finished. Pays to note that those rockers are 1/8 inch longer than the originals.:)
    Andy.
  6. ems customer service
    it was for access for ***embly workers, paint and to hang on the conveyer
    not all features of a car are for looks or performance sometimes they are for ***embly line issue
  7. Finnrodder
    Finnrodder
    from Finland
    I had just the same idea than you,rust protection spraying is a lot easier when they are open.
    I cut mine open before welding them.I've planned to buy new scuff plates,so there wont go any **** in rockers when the scuff plates are bolted on..
  8. Jim Lohman
    Jim Lohman
    from Colorado
    Had to cut up my EMS rockers to fit, think they would come ready to go.
  9. ems customer service
    maybe something was out of alignement if you had to do more than minor trim to fit
  10. Jim Lohman
    Jim Lohman
    from Colorado
    Exact same surgery both rockers, must have something fantastically out of alignment....
  11. ems customer service
    it is possible do you have pics ?
  12. Jim Lohman
    Jim Lohman
    from Colorado
    So before this takes a turn for the worse, let me just say I am glad there is a company out there that actually offers chevy steel! I will pm you some pics tomorrow to show you the cuts I had to make. And as soon as the tail pan I need drops to a third of its current price I will be the first to order one! haha
  13. kiwiandy
    kiwiandy
    The shoebox EMS rockers are an 1/8 inch longer than the Ford originals. I have uns***ched the originals and sat them side by side. The overall length is the same but the length below the door area is different by 1/8. The pic shows the difference. It doesnt seem like much but it will be enough to bring on the old WTF....when trying to line things up! The longer area is where the front of the door and rear of the fender need to line up.
    I can get better pics if required.
    Andy.
  14. RPaciotti
    RPaciotti
    I installed EMS rockers as well and mine were about 1/8" too long. Heard this from a few other people as well.
  15. shoebox50
    shoebox50
    I used them on my car and they were to long and had to be shortened to fit.
  16. Slag Kustom
    Slag Kustom
    they are not too long. the corner is not as sharp as the factory. when you tune them up and hammer n dolly the corner they fit perfect
  17. ems customer service
    i will look into this. but if the rocker is to long? would it be easier to place the front of the rocker in the correct location and cut the extra off the back where it meets with the 1/4 and **** weld it there instead of tying to rework
    the front?
