Hydromatic Hook Up?
Discussion in 'The Hokey Ass Message Board' started by Mr. Speed, Feb 28, 2011.
  1. Mr. Speed
    Mr. Speed
    from USA
    I have a 52 Pontiac Catalina, and did a clip swap, so I had to disconnect all the lines, linkage, etc to the ******. Does anyone know where to find (or have) any info on hooking it back up?:confused:
  2. Mr. Speed
    Mr. Speed
    from USA
    Thanks porkn******. Got me one step closer!
  3. squirrel
  4. I neede to get this stuff out for me anyway. It was just good incentive to do a search.
    if you do an advanced search on hydro there are a lot of threads about it including some stock stuff.
  5. jhogan
    jhogan
    from Aptos CA
    It should be kinda easy, spedo cable in the drivers side rear, right side 2 cooler lines, tv cable, and vac modulater. vac modulator to intake port, TV cable to throtle linkage, this can be a little tricky to adjust properly. Cooler lines to ****** cooler. I think that's all she is.
  6. JohnEvans
    JohnEvans
    from Phoenix AZ
    You obviously know nothing about early Hydros. They do NOT have vacuum mods., TV cables and as I recall no cooler lines. They do have a rod that works a a TV control.
  7. ljs05
    ljs05
    While everyone is on this subject. Anyone got info on where I can find a flywheel for a B&M hydro stick to a Chevy small block. I have the rest of the B&M torus, but need a flywheel.
  8. Look for a flex plate/flywheel for a later '50s Chevy truck with a hydromatic. They used a stock one and the later '50s trucks came with a hydro optional.
    Yoyu may even be able to get pieces from B&M if you ask. Its a long shot but worth the effort if you want to get on the road.
  9. ljs05
    ljs05
    Checked with B&M a while ago. They know nothing on these anymore. Also been checking the Chevy truck sites for awhile.
    Thanks.
    Still Looking.
