Underslung rods thread
Discussion in 'The Hokey Ass Message Board' started by Slimegreeeeeen, Feb 28, 2011.
  1. Slimegreeeeeen
    Slimegreeeeeen
    I'm curious how many HAMBers are running underslung suspension systems.
    Wondering it's a good way to go for a low ride height. Pictures appreciated.
  2. gnichols
    gnichols
    from Tampa, FL
    Me too. Gary
  3. Here is one I am quite partial to.
    '23 Dodge by the way.
    kidcampbell71 likes this.
  4. Doc.
    Doc.
    Yeah Rich's car is very cool. I wish he was still with us. RIP buddy.
    Doc.
  5. Ned Ludd
    Ned Ludd
    Underslung front ends are visible but hard to package. Underslung rears are usually invisible, but that's where the potential lies. Historically there have been far more underslung rears than fronts: Morgan's is still in production.
    The plan for the '31 includes an underslung rear axle.
  6. xderelict
    xderelict
    I'd build another one.This one was a blast.
  7. Mr48chev
    I've always loved the look of that little Dodge that Rich built but I couldn't make it to town without getting a scrub line ticket around here with it. Actually it wouldn't make it in or out of my driveway even with utmost care in driving.
    I thought about doing it on the boat tail roadster I am building as it would go along with the look but still think it would be too low to work for me right now.
  8. Slimegreeeeeen
    Slimegreeeeeen
    Educate me, brothers. Is the scrub line at its fixed lowest point at resting height?
    By that I mean, does the suspension only travel upwards? If so, does that mean that larger wheels and taller tires, and perhaps a shorter wheelbase with less overhang for and aft would be a good preventative measures?
  9. atomickustom
    atomickustom
    Scrub line means anything hard that will hit the ground in the event of a flat tire. There have been debates on this board about whether that means one flat tire or two on the same side or all three, but the short version is this: if you get a flat tire and all the sudden you can't steer because your frame is dragging on the ground, your car is too low.
    Overhand usually isn't an issue on rods, but kustoms can drag rear bumpers doing in and out of driveways and such. That's a whole other issue because you're not traveling at high speed when that happens.
    Yes, taller wheels could solve the problem, but only because they raise the ch***is an equal amount.
    If a car sits 3 inches off the ground and has tires with a 4-inch sidewall, it is a bad accident waiting to happen.
  10. TomCat 1
    TomCat 1
    So I know it looks kool but what I don't get is how like on the '23 dodge if you hit a bump in the road how that suspension is going to even do anything with the spring arch going the wrong way.......or am I looking at this all wrong?
  11. Beemer
    Beemer
    Not the best picture of it, but here's mine. Underslung front and Model A spring in the rear. I've had it on the road since '05, it rides pretty good. There were a lot of test drives and dis***embling/re***embling the front to get it right. Its great fun on curvy roads :)
  12. Kerry
    Kerry
    What are you talking about???!! Don't you know it can't be done!?!?! ;-)
  13. Doc
    Do you know what happened to Rich's cool little 23 Dodge roadster?
  14. terryr
    terryr
    from earth
    You're still bending the spring from its normal curve. It resists both up and down, no matter where the weight is located.
  15. Hotrodhell35
    Hotrodhell35
    heres my underslung setup.
  16. propwash
    propwash
    from Las Vegas
    I'd be more accepting of that "underslung" look if most of the cars I see didn't look like trashy R*t R*ds - rust, pisspoor welds, sloppy (or no) workmanship.
    I'm old...I was driving hot rods in the late 50s and beyond....read all the books....went to as many car shows as possible. I do not recall 'underslung' being all that traditional...on hot rods anyway.
    dj
  17. TomCat 1
    TomCat 1
    I don't know I'm still not too sure about that?????????????
  18. JEM
    JEM
    Not exactly a 'rod' but one of the more successful underslung suspensions ever put together, every so often I have thoughts of pinging the Brooklands Museum folks to see if there's any dimensioned drawings extant, someone needs to replicate this thing with, oh, maybe a well-tuned Duramax in it (okay, shoot me now, but there just ain't that many Lions around) or, if one had a lot of spare change, a crankcase and crank and cam-gear train to put together three old Offy blocks on in 'broad arrow' configuration:
    http://www.practicalmachinist.com/vb/antique-machinery-history/napier-railton-114485/
    Love that double cantilever quarter-elliptic-as-four-link in back.
    Was trying to find the pic of Cobb standing in front of the car with all the front-end sheetmetal off, shows the front suspension to great advantage, but I can't find a link for it anywhere and don't have time to look any further (it's probably on this board somewhere, for that matter), if you really care you could pick up a copy of:
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=130412579365
  19. Ned Ludd
    Ned Ludd
  20. mart3406
    mart3406
    from Canada
    There was at least one early-model
    production p***enger car that used an
    underslung suspension layout too - the
    'American Underslung' - circa 1905-1914.
    Mart3406
    (http://en.wikipedia.org/wiki/American_Underslung)
    (www.conceptcarz.com/vehicle/z9486/American-Underslung.aspx)
    (www.autos.ca/cl***ic-cars/motoring-memories-american-underslung-1907-1913)
    (www.remarkablecars.com/for-sale/g4426-american-underslung.html)
    (www.ultimatecarpage.com/car/3766/American-Underslung-Traveler.html)
  21. moparob
    moparob
    Ive only seen a handful of underslung ch***is cars, a few hot rods and a few early 1900's examples at shows. For me i could only imagine using this set up for a bonniville car. They're different but they look freaking sweet, maybe i should consider this for my 25dodge?
  22. mart3406
    mart3406
    from Canada
    Back in the 'teens and '20's of the last century,
    that was how racers got their creations 'down in
    the weeds', with the large-diameter wheels and
    tires of the time. Given the roads of the day,
    road cars usually needed all the ground clearance
    and suspension travel they could get, so very few
    actual production cars used underslung suspensions.
    But if the plan for your Dodge is to emulate an
    early track racer or speedster, an underslung
    suspension would be very cool!
    Mart3406
  23. moparob
    moparob
    Yeah, Ive been toying around with the idea for a bit and have considered multiple frame and suspenssion set ups and it looks more and more like im going to run an underslung set up. This will be a very challenging build, ive been working out the details for the last hour or so, trying to figure it out. i cant wait to get back to the states and start work. ill definetly start a thread so that you all can watch it come together.
  24. moparob
    moparob
    A mix between salt flats, speedster, drag and a few traditional touchs here and there
  25. JEM
    JEM
    Yeah, something like that:)
  26. Chuck U&R
    Chuck U&R
    from NC
  27. Fenders
    Fenders
    Poor builds, lotta **** hanging below the scrubline.
