HEMI Tech - Daimler Hemis
Discussion in 'The Hokey Ass Message Board' started by scootermcrad, Apr 22, 2009.
  1. scootermcrad
    scootermcrad
    Okay! Finally getting around to getting some things upgraded and have wanted to add this catagory for awhile now! Sooooo... let's go! This thread will be added to the Index page as well!
    Let's talk about anything related to Daimler Hemis! There's not a whole lot of information out there, but anything anyone can add would be appreciated. I have some information from Limey Steve that I will be scanning and adding to this thread, but I at least wanted to get it kicked off and running in the mean time so I can add it to the Index.
    Thanks everyone! Can't wait to see what you guys have hidden away!
  2. Just an FYI...ALL Jaguar/Daimler engines, I-6, V-8, and V-12 cylinders, are Hemis. My XJ6C is an inline 6, and my XJS is a V-12...and both my DeSoto engines are Hemis...:D
  3. plym49
    plym49
    from Earth
    Nope. The V12's are NOT hemis. The original XK is, with two valves per cylinder, is. The V12, both the pre-HE (with flat heads) and the HE (the May head, a high turbulence design, precursor to the Chevy Vortec head) is not a hemi (the V12s also are two valves per cylinder).
    The litle Daimler V8s in question are also hemis. They also look just like a miniature version of what is, IMHO, the only TRUE hemi that is out there, and that is the good old "392" and "426" MoPar iron.
    osut362 and dana barlow like this.
  4. Sounds pretty "Abby Normal" to me Scooter- looking forward to this thread growing!
  5. HEMI32
    HEMI32
    Limey Steve & Weasel should be chiming in any minute now!
  6. The37Kid
    The37Kid
    There was a Midget fitted with a Daimler HEMI here on the East Coast in the 1970's. I bought a flawless set of headers for one that may have come from the same car, eBayed them years ago.
  7. Weasel
    Weasel
    Damn - sussed:p. Limey Steve is asleep at the wheel - as usual....
    Okay, here's the big Daimler hemi (again) - this one is the factory experimental hot rod hemi bored out from 4.5L (270 ci) to 305 ci - hot cam forged pistons, high compression heads. Looks a lot like the baby 2.5L Daimler hemi, but no parts interchange. The big Daimler hemi was found in the Majestic Major saloon (1180 produced) and the DR450 limo (864 produced) from around 1959-1968, so these are tough to find. This big hemi is 26 ins wide by 27 1/2 ins long. The baby Daimler hemi is 23 1/2 ins wide by 25 3/8 ins long - tip of water pump to back of block.
  8. Dirtynails
    Dirtynails
    from garage
    A**** Daimler people it's known as the "Turner engine" and if you have ever owned an Arial Square or Triumph twin and had the head off you will notice something very familiar. They were designed by the same guy.
    heres a post from Wiki which says most of what i have known for ever...:D
  9. Great motors, I have three of them,
    Stock pistons have a slightly annoying habbit of breaking off just bellow the oil control ring if you rev them too much.
    Stock induction system is very limited, best bet is to saw the stock manifold through and get a holley plate welded on so you can feed the thing.
    Russ Carpenter has one in a dragster called Gl***ier Granaide (?)
    Making a full thousend Bhp, out of a mear 155 cubes,
    I put a blown one sidewinder style in a trike for giggle,
    and am building a 5/8's hot rod to take one.
    Only down side to the motor is that it is not very big,
    roughly two foot cube,
    however like bigger Hemi's it's heavy,
    Heads might be aluminum, but the block is iron and is a thick casting,
    means the block is strong enough to take the forces involved in making serious numbers, but it's heavier than say a nail head.
    Some improvement can be made by re-timing the stock cam so mid over lap is nearer TDC, but reduction of base circle and say an L14 profile will really hot things up when combined with some breathing improvements.
  10. GlenC
    GlenC
    Old Jag restorer/mechanic down the road from me retired last year and sold off all his stuff at public auction. I didn't know he had one of these under his workbench... Complete motor went to a s****pie for $35. The bloke apparently dragged it out to the truck and smashed it to pieces to separate the alloy from the steel. At the same auction Moss 4 speeds went for $1 and Jag suspension components for $5 a boxful, all to the s**** merchants.
    What a ****** waste!
    Cheers, Glen.
  11. 31whitey
    31whitey
    No idea...
    weird hemi coolness.
    those ****ers.
    Scoot...great job putting all this hemi info together....these threads rule.
  12. junkyardgenius
    junkyardgenius
    from Kernow
    Here,s a couple pics of Russ Carpenters Glacier Grenade . 2.5 Daimler Hemi powered dragster ,regularly ran in the 7,s :eek:.The old Hot Rod & Custom UK mag did a series on the build up of the engine and blower set up (I must have still got it)If I remember right (it was a long time ago) it ran Triumph motorcycle pistons.
  13. scootermcrad
    scootermcrad
    WOW!! What a great response already!! Thank you very much for replying, guys!
    These engines are amazing! Steve had a couple heads in the car with him at breakfast one morning and they look like they should weight 100 pounds like all the other Mopar Hemis, but you can just about pick 'em up with one strong hand! These engines were way ahead of their time! They really do blow my mind!
    EDIT: Adding this link for a previous thread started here:
    http://www.jalopyjournal.com/forum/showthread.php?t=151281&showall=1
  14. Limey Steve
    Limey Steve
    Alliance Vendor
    from Whittier
    It's great to see the Daimler Hemi getting some recognition , I have 3 big Daimlers (from a production run of 2088 cars !! ) One in my roadster drives great , 2 rebuildable 1 only needs re ***embling. I have almost 2 small 2.5 engines , I need a crank to make up the pair. 1 were setting up with a 3.71 blower & 2 port with zoomies, came out of an unknown drag car in England .
  15. 39cent
    39cent
    from socal
    I heard about them, wondered if they were any good , but since nothing much was ever said about em I thought they were'nt very good? So thats how far outta the box, I get.
  16. metalshapes
    metalshapes
  17. plym_46
    plym_46
    from central NY
    Don't know too much about them had a ride in a Daimler sp250 roadster with one in it long time ago.
    I do know that there are two available at an estate auction this saturday. One as listed as race prepared and the other as being stock. At 2.5 liter they are small both physically and in power out put. 140 hp.
  18. fms427
    fms427
    Here's one I built for an SP250 race car - since sold and is now in Australia. Cool engine, and great sounding with no mufflers. I have also built Triumph tmototcycle engines - and there is a lot of design similarity !
  19. scootermcrad
    scootermcrad
    Being that I'm really into Triumph sickles AND Hemis, this engine sparked my interest immediately!
  20. Get lost.....
  21. the little history that i know.. the original casting for that motor was air cooled.. it didn't work so they added water jackets, and a lot of piping in the early motors... they were based of a bsa bike motor. there are some big hemi's found in Daimler limo's something like 4.5 liter.. the crank will swap over if you have a smaller cube block. aaaand the Daimler sp250 was what that motor was originally found in. Daimler called it a dart, but got sued by dodge because of their car with the same name. so it was changed to sp250.. also the front of that sports car has a V on the front of it due to the fact it was one of the first British cars to have a V style engine.. so it was different back in the day.. the sp250 was to avaunt guard for its day and sales were little to say the least. it was based on a triumph tr4 ch***is and also used a bunch of triumph running gear..
  22. falcongeorge
    falcongeorge
    from BC
    That is really cool. I remember one raced at westwood in the early days. Sadly, I think the guy crashed it hard at the esses and was killed.
  23. chopper york
    chopper york
    from England
  24. plumpcars
    plumpcars
    The 250 engine also came in the saloon body which was the same as the MK2 Jag. I ran one as a daily nearly 40 years back. One thing to watch is that you use a good corrosion inhibitor in your cooling system. They really suffer from head damage otherwise and were a little prone to head gasket failure anyway.
  25. Limey Steve
    Limey Steve
    Alliance Vendor
    from Whittier
    I got me another 4.5 Hemi , bought it of Jim Jacobs , complete take out from a limo. I have also made a new manifold for my roadster to use 2 97's , I'll post pix when finished, should work great .Make a change from the tri power.
    Your Hemi sounds good , 2.5 right ? . Love them Daimler Hemis
  26. chopper york
    chopper york
    from England
    yeah 2.5,its the second engine that i bought the first was completly knackerd the second needed a crank re grind and new rings.i struggled to get rings for it and ended up using cords rings allthough i've found ironhead sportster rings will fit with a bit of work.
  27. Whats that funnycar? A Mini?
  28. James D
    James D
    Yes, it´s a Mini estate (thats wagon to you). IIRC that car was later fitted with a complete gl*** body.
  29. I wanna see more of the "Estate"!
