Metal Working Guys,,what is this table called and where can I find one
Discussion in 'The Hokey Ass Message Board' started by Little Wing, Mar 6, 2011.
  1. Little Wing
    Little Wing
    from Northeast
    Looking for an old table like this one ,,but not sue what it's called,,a jig ?
    thanks
      266.8 KB
  2. That looks like a sub plate to me.
  3. ayer
    ayer
    They are usually called a fixture table. several companies sell the. they are usually quite expensive for hobby use. Dagger Tolls has smaller ones.
  4. Pat Pryor
    Pat Pryor
    its kinda like a welding table.
  5. Little Wing
    Little Wing
    from Northeast
    I would like to find a 3x3 or so,,I'm thinking they are quite heavy
  6. 37mj
    37mj
    you can have the table ...i'll take the springer ! :cool:
  7. Little Wing
    Little Wing
    from Northeast
    have a bunch of springers ,,thats why I'm looking for a table,,and to repair other things as well
  8. Little Wing
    Little Wing
    from Northeast
    any idea what that post was called ?
  9. For hobby use you can make one out of a sheet of plate steel. 1/2" works good. If you can get your hands on a magnetic base drill making the holes is not that big a deal. I'd drill and tap.
    Commercial plates are usually ground flat after machining. That is what makes them so expensive. For most hobby applications the mill surface should be fine.
    We are currently in the process of building a 3" x 5" welding table out of 1/2" plate. It will be drilled and tapped on a 4" grid.
  10. Roadsir
    Roadsir
    I've got one. Mine was a Machine Base without the drilled and tapped holes. The top is precision ground 1" plate, and it has 6"X6" Square tube framing. It's about 4' by 5' and weighs close to 2000 pounds. I plan on adding a set of drilled and tapped holes for work-holding.
    They are offered as fixture tables with t-slots as well. We have some of these at work, and they work really well for clamping.
    Check your local used machine tool equipment houses, and s**** yards.
  11. richman1969
    richman1969
    helli built mine for 865.00........ hit the metal shops see if the have any 2 x 4tubing for the legs and top.. used 1 x 2 for the supports..4ft wide 5.5 ft long nice steel rollers on bottom has a custom cycle frame on it right now but it held a buddies 79 firebird body(frame off sale) and his dodge durango while he cut it up (off roder project)..
  12. Irrational Metalworks
    Alliance Vendor
    from DFW
    I believe Trick Tools sells them.
  13. Little Wing
    Little Wing
    from Northeast
    and to be clear I'm just looking for the slab with the holes
  14. lownrusty
    lownrusty
  15. bobscogin
    bobscogin
  16. roundvalley
    roundvalley
    Acorn plate or table is correct. There was one at a local fab shop that was 20'x20' and had 10" square holes. They bent some big dog stuff.
  17. shawnspeed
    shawnspeed
    from Attica Mi
    If you live in an area with some industrial base , keep an eye on C/L, you may be able to find many sutable items ,from layout tables,to surface plates,to machine tables(old cast iron tablesaw tops are good ,cheap surface plates) keep your eyes open and you will be amazed what you find...I have a 3'X5' overarm roter table that is now my frame fixture/surface plate...bought for a 100 bucks ....with stand...Shawn
  18. Little Wing
    Little Wing
    from Northeast
    Philadelphia ,,Allentown, and NYC all within an hours drive might get lucky
  19. Slag Kustom
    Slag Kustom
    look on ebay in business and industrial under platen or welding table
  20. Xdrag48
    Xdrag48
  21. Little Wing
    Little Wing
    from Northeast
    Thanks all,,hopefully I can find one used
  22. rustyford40
    rustyford40
    from Mass Bay
    I had a acorn table, It had square holes in it. You could make or buy all kinds of pages for it. vary handy
  23. Little Wing
    Little Wing
    from Northeast
    Seems most are larger,,guess folks hold onto the smaller ones
  24. Its called a platten. Some are plate with holes drilled and others are cast with a waffle pattern. Pretty pricey better look for an old weld shop or fab shop going out of business.
  25. Little Wing
    Little Wing
    from Northeast
    hopefully I'll get lucky :)
  26. There used to be a really talented motorcycle builder around here in the 70's that had one of those. He called it a "perfect" table. Ironically enough, he straightened a springer on it for me that I bent in a crash. He said, I'll just fix it on the "perfect" table
  27. bct
    bct
    i've been lookng for something like this table aswell....i found some steel pieces that are used to splice I beam on bridges ect.....the ones i found are 16" x 48" and have a 1" hole every 3" or so.....they aren't machined flat but i'm not that accurate anyhow...i've also seen the tables with the big X shape cut into them commercially available .
  28. zman
    zman
    from Garner, NC
